Software Archive
Read-only legacy content
17060 Discussions
Linking to C DLL
Deleted_U_Intel
I am trying to understand how to link a DLL, created in C, into a fortran executable. To this end I have made very simple source code given below.
// AddIt.cpp //
#include "Addit.h""
extern "C"
_declspec(dllexport)
void _cdecl AddIt(float A, float B, float &C)
  C = A + B;
// Fortran Code //
	PROGRAM MAIN
	IMPLICIT NONE
      INTERFACE
      SUBROUTINE ADD(A,B,C)
!DEC$ ATTRIBUTES stdcall, DLLIMPORT, ALIAS:'_AddIt'::ADD
      REAL*4 A,B,C
	end subroutine ADD
	END INTERFACE
	real*4 x,y,z
	x=2.0
	y=3.0
	z=0.0
      CALL ADD(x,y,z)
END PROGRAM MAIN
The Addit library is included in the compliation of the Fortran code. When I compile and link the Fortran routine I get a linker error as follows:
Searching Libraries
Searching c:CodeTestAddItAddItDLL.lib:
Found _AddIt
Referenced in FORADD.obj
Loaded AddItDLL.lib(AddIt.dll)
c:CodeTestAddItAddItDLL.lib : fatal error LNK1106: invalid file or disk full: cannot seek to 0x3b611128
Error executing link.exe.
It appears that the procedure contained in the DLL is being found, but the linker does not like it. I have plenty of space on the disk (>20 GB). The C DLL was created using Microsoft Visual C++ 6.0.
Any thoughts?
Yep - you're using a MSVC 6-created import library with a version 5 linker. MS changed the library format in an incompatible fashion. Solutions: 1) Upgrade to CVF 6.5, 2) Use the MSVC 6 linker to link, 3) Install VS97 SP3 (see the CVF FAQ for details.)
Steve
