Software Archive
Read-only legacy content
Loading Notification/Loading Circle
Patrick_C_1
Hello!
I've searched the whole internet about just that thing. I absolutely don't know, how to access the native loading circles of the device. Is there maybe a way to show and hide them? It would be nice, because when you, for example, log in and it takes a bit longer, you should see that the progress is going on.
Greetings
Ad
New Contributor III
We have just implemented in our App! B.T.W. We are using the Ionics Framework.
If you are using the Ionic Framework too, search for $ionicloading, e.g. http://codepen.io/gnomeontherun/pen/EAmqD
You don't get the native loading symbols, but the output looks good.
Patrick_C_1
Hm, unfortunately I'm using the App Framework. But maybe I can take that from Ionics Framework?
Ad
New Contributor III
Is maybe a little bit of overkill, add Ionics Framework + AngularJS for only one circle.....
Patrick_C_1
Yes, you're right. Maybe there is another solution for my problem?
Anusha_M_Intel1
Hi Patrick,
<div id="splashscreen" class='ui-loader heavy'>
        App Framework - Flip View
        <br>
        <br>
        <span class='ui-icon ui-icon-loading spin'></span>
        <h1>Starting app</h1>
    </div>
This is the loading code for splashscreen we use in the app framework templates. You could most probably leverage from this.
Dale_S_Intel
You might want to try this Cordova plugin:
https://github.com/mobimentum/phonegap-plugin-loading-spinner
I haven't tried it, but if I understand what you're trying to do, it might be your best bet.
Dale
