Software Archive
Read-only legacy content
17060 Discussions
Loading page never ends
Mohamed_S_1
As I mentioned before, I have many troubles and here's a new one.
When I click on DESIGN, I get this Loading page and it never ends!
I closed XDK and restarted my computer several times and I still have the same problem.. I leaved it for 3 hours and it haven't ended.
I copied the whole code and paste it in a new project but the project doesn't work correctly.
How can I access the DESIGN page again to continue working on my project?
Thank you!
Chris_P_Intel
Take a look at the page in Code view. My guess is that some code change has been made which is messing things up.
Do you use source control, like Git?  That'd make it easy to go back to the last working version.
Chris_P_Intel
Can you .zip up and post your project, or at least its HTML file? I'd like to see the file that prevents the 'loading' from signaling completion.
FREDERIC_L_
did you have an issue for this problem as i'm facing the same...
thank you
Fred
Michael_O_2
Guys, kindly stick with the code view.
It saves a lot of time and "headaches".
FREDERIC_L_
still have the problem, even with the upgrade to last version
any clues ?
thanks
Fred
PaulF_IntelCorp
Frederic, please see Chris' earlier comment regarding posting a project or the index.html file from the project. If he can look at that file it might shed some light on what is going wrong.
