Software Archive
Read-only legacy content
17060 Discussions
Loading some data from database using $.post method through webapp not working
kulkarni__sameer
I built app using Inappbrowser plugin that accessing  dynamic page from server , within  page i am having  text box loading doctors list from server.I am loading doctors name using $.post method, it's loads  when page open in chrome browser and in xdk emulator but it's showing undefined index val error in actual app on mobile.I have attached two screenshots.Please help me .
Sameer kulkarni.
PaulF_IntelCorp
You probably have a Cordova whitelist problem. See this doc page for some help > https://software.intel.com/en-us/xdk/docs/using-cordova-whitelist-rules-with-intel-xdk < and also be sure to read the inAppBrowser doc page for any limitations there that may be imposed by that plugin > https://github.com/apache/cordova-plugin-inappbrowser <
kulkarni__sameer
Paul F. (Intel) wrote:
You probably have a Cordova whitelist problem. See this doc page for some help > https://software.intel.com/en-us/xdk/docs/using-cordova-whitelist-rules-... < and also be sure to read the inAppBrowser doc page for any limitations there that may be imposed by that plugin > https://github.com/apache/cordova-plugin-inappbrowser <
As per your suggestion . i made changes to Network whitelist .still it's showing same error 'undefined index val'.I am using two more $.post method in jquery , these are working fine.only causes problem which used within keyup event , but it is working fine in simulate tab and in external web browser.Please tell me is anything to change still .Please it is very necessary to me
Sameer Klkarni
PaulF_IntelCorp
In general, the problem you are describing is caused by either a whitelist issue or a CSP rules issue. To get a handle on it, I recommend you try debugging a built app using remote CDT. See this page for some help > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview
kulkarni__sameer
Sir i have analysed that i have put alert for debugging .All data are display in alert and in div tag.I used datalist with text box for autocomplete.I thought that it is problem with datalist , but it's working fine in chrome browser.Please help me .Code Snippet as below
Jquery
$("#doc_search").keyup(function(e) {
             var val=$(this).val();
             //alert(val);
             $.get('doctor_loading.php',{val:val},function(response){
             //alert(response);
               $(".doctor_list").html(response);
HTML
 <input type="text" class="form-control" id="doc_search" list="doctor_list" name="doc_search"
<datalist id="doctor_list" class="doctor_list">
 </datalist>
PaulF_IntelCorp
