Software Archive
Read-only legacy content
17060 Discussions
Low micprun performance on a Xeon Phi 7250
maicon_f_
Maybe I'm missing something so I would appreciate a lot if someone can point a mistake. I have a system with a 7250, Centos 7.3, intel parallel studio xe 2018, xppsl-1.5.4 installed. I have just one DIMM slot populated with a RDIMM 2400MHz 32GB. After several tries on a FFT code with low performance I suspected that there is something wrong with my system. I try the micprun suite to make syntectic tests and compare with reference ones.
For small matrices I got good performance:
RESULT: 512 x 512 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 512 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 512 --s_step 512
2475.76      GFlops
REFERENCE: 512 x 512 MKL SGEMM with 0 threads and 3 iterations
2598.68      GFlops
But for 1024 x 1024:
RESULT
1024 x 1024 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 1024 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 1024 --s_step 1024
732.5      GFlops
REFERENCE: 1024 x 1024 MKL SGEMM with 0 threads and 3 iterations
1776.22      GFlops
For bigger matrices the results are even worst:
RESULT: 16384 x 16384 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 16384 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 16384 --s_step 16384
638.05      GFlops
REFERENCE: 16384 x 16384 MKL SGEMM with 0 threads and 3 iterations
4321.84      GFlops
I'm aware that for bigger matrices I would relay on DRAM but with 16GB MCDRAM I thought be enough to run 1024x1024 (1GB) matrices. I'm considering buy more RDIMMS to complete the six-channels but I'm not totally sure that this will solve the problem.
Do you guy have some consideration? I'm doing something wrong?
Best Regads,
Maicon Faria
Abax HPC
P.S:
Full result:
benchmarking: sgemm
timer       : native
num_threads : 0
min_niters  : 3
min_t       : 3.000000
first index : 16384
last  index : 16384
step        : 16384
fixed M     : -1
fixed N     : -1
fixed K     : -1
data transf.: maybe (depends on MKL AO setting)
threads used: 68 (autodetected)
threads/core: 1
affinity    : KMP_AFFINITY (if any)
MKL         : 2017.0.2 build 20170126 (Product)
processor   : Intel(R) Advanced Vector Extensions 512 (Intel(R) AVX-512) for Intel(R) Many Integrated Core Architecture (Intel(R) MIC Architecture) enabled processors
CPU freq.   : 1.48 (may float due to scaling)
# cores aval: 68
max threads : 272
# of co-proc: 0
#0: NN
testing XGEMM( 'N', 'N', n, n, ... )
          n        min        avg        max     stddev
      16384     634.50     638.05     641.10  2.723e+00
*     16384     634.50     638.05     641.10  2.723e+00
[ DESCRIPTION ] 16384 x 16384 MKL SGEMM with 0 threads and 3 iterations
[ PERFORMANCE ] Task.Computation.Avg 638.05 GFlops R
***********************************ROLLED UP************************************
*************************************sgemm**************************************
*****************************local__mcdram_example******************************
2475.76      GFlops
732.5      GFlops
1536 x 1536 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 1536 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 1536 --s_step 1536
922.04      GFlops
2048 x 2048 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 2048 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 2048 --s_step 2048
1004.52      GFlops
2560 x 2560 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 2560 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 2560 --s_step 2560
1026.21      GFlops
3072 x 3072 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 3072 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 3072 --s_step 3072
916.68      GFlops
3584 x 3584 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 3584 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 3584 --s_step 3584
828.52      GFlops
4096 x 4096 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 4096 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 4096 --s_step 4096
1015.26      GFlops
4608 x 4608 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 4608 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 4608 --s_step 4608
1073.56      GFlops
5120 x 5120 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 5120 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 5120 --s_step 5120
1160.63      GFlops
5632 x 5632 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 5632 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 5632 --s_step 5632
1205.76      GFlops
6144 x 6144 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 6144 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 6144 --s_step 6144
1254.58      GFlops
6656 x 6656 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 6656 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 6656 --s_step 6656
1314.4      GFlops
7168 x 7168 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 7168 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 7168 --s_step 7168
1366.14      GFlops
7680 x 7680 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 7680 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 7680 --s_step 7680
1344.64      GFlops
8192 x 8192 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 8192 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 8192 --s_step 8192
745.78      GFlops
8704 x 8704 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 8704 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 8704 --s_step 8704
739.81      GFlops
9216 x 9216 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 9216 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 9216 --s_step 9216
701.58      GFlops
9728 x 9728 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 9728 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 9728 --s_step 9728
721.16      GFlops
10240 x 10240 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 10240 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 10240 --s_step 10240
679.92      GFlops
10752 x 10752 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 10752 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 10752 --s_step 10752
677.37      GFlops
11264 x 11264 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 11264 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 11264 --s_step 11264
684.59      GFlops
11776 x 11776 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 11776 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 11776 --s_step 11776
656.25      GFlops
12288 x 12288 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 12288 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 12288 --s_step 12288
692.47      GFlops
12800 x 12800 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 12800 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 12800 --s_step 12800
624.84      GFlops
13312 x 13312 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 13312 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 13312 --s_step 13312
558.92      GFlops
13824 x 13824 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 13824 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 13824 --s_step 13824
664.77      GFlops
14336 x 14336 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 14336 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 14336 --s_step 14336
694.58      GFlops
14848 x 14848 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 14848 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 14848 --s_step 14848
684.85      GFlops
15360 x 15360 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 15360 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 15360 --s_step 15360
678.84      GFlops
15872 x 15872 MKL SGEMM with 0 threads and 3 iterations
Parameters:  --f_first_matrix_size 15872 --i_num_rep 3 --T_device -1 --n_num_thread 0 --m_mode NN --l_last_matrix_size 15872 --s_step 15872
657.59      GFlops
638.05      GFlops
***********local__mcdram_7250_redhat-7.2_micperf-1.5.2_local_scaling************
2598.68      GFlops
1776.22      GFlops
2408.19      GFlops
2753.62      GFlops
3157.43      GFlops
3324.94      GFlops
3488.82      GFlops
3810.68      GFlops
3967.6      GFlops
4023.72      GFlops
4094.68      GFlops
4132.83      GFlops
4082.72      GFlops
4147.48      GFlops
4146.49      GFlops
4195.76      GFlops
4250.19      GFlops
4263.39      GFlops
4229.29      GFlops
4255.04      GFlops
4247.74      GFlops
4274.98      GFlops
4258.92      GFlops
4299.45      GFlops
4283.56      GFlops
4295.48      GFlops
4283.7      GFlops
4316.61      GFlops
4282.81      GFlops
4286.2      GFlops
4321.02      GFlops
4321.84      GFlops
McCalpinJohn
What mode is your system configured in?   (The performance issues are likely to be different in "flat" vs "cache" modes.)
maicon_f_
Hi, that result was for SNC-4, flat.
Trying cache, I got a nice result. I was not expecting that since I saw flat was recommend for SGEMM in documentation.
KERNEL, OFFLOAD, TAG
sgemm, local, ddr_example
DESCRIPTION, f_first_matrix_size, i_num_rep, T_device, n_num_thread, m_mode, l_last_matrix_size, s_step, Task.Computation.Avg (GFlops)
512 x 512 MKL SGEMM with 0 threads and 3 iterations, 512, 3, -1, 0, NN, 512, 512, 2201.68
1024 x 1024 MKL SGEMM with 0 threads and 3 iterations, 1024, 3, -1, 0, NN, 1024, 1024, 1794.76
1536 x 1536 MKL SGEMM with 0 threads and 3 iterations, 1536, 3, -1, 0, NN, 1536, 1536, 2383.83
2048 x 2048 MKL SGEMM with 0 threads and 3 iterations, 2048, 3, -1, 0, NN, 2048, 2048, 2596.83
2560 x 2560 MKL SGEMM with 0 threads and 3 iterations, 2560, 3, -1, 0, NN, 2560, 2560, 3540.39
3072 x 3072 MKL SGEMM with 0 threads and 3 iterations, 3072, 3, -1, 0, NN, 3072, 3072, 3740.34
3584 x 3584 MKL SGEMM with 0 threads and 3 iterations, 3584, 3, -1, 0, NN, 3584, 3584, 3928.0
4096 x 4096 MKL SGEMM with 0 threads and 3 iterations, 4096, 3, -1, 0, NN, 4096, 4096, 3936.0
4608 x 4608 MKL SGEMM with 0 threads and 3 iterations, 4608, 3, -1, 0, NN, 4608, 4608, 4263.12
5120 x 5120 MKL SGEMM with 0 threads and 3 iterations, 5120, 3, -1, 0, NN, 5120, 5120, 4247.05
5632 x 5632 MKL SGEMM with 0 threads and 3 iterations, 5632, 3, -1, 0, NN, 5632, 5632, 4363.59
6144 x 6144 MKL SGEMM with 0 threads and 3 iterations, 6144, 3, -1, 0, NN, 6144, 6144, 4357.05
6656 x 6656 MKL SGEMM with 0 threads and 3 iterations, 6656, 3, -1, 0, NN, 6656, 6656, 4374.95
7168 x 7168 MKL SGEMM with 0 threads and 3 iterations, 7168, 3, -1, 0, NN, 7168, 7168, 4399.82
7680 x 7680 MKL SGEMM with 0 threads and 3 iterations, 7680, 3, -1, 0, NN, 7680, 7680, 4302.77
8192 x 8192 MKL SGEMM with 0 threads and 3 iterations, 8192, 3, -1, 0, NN, 8192, 8192, 4376.13
8704 x 8704 MKL SGEMM with 0 threads and 3 iterations, 8704, 3, -1, 0, NN, 8704, 8704, 4389.37
9216 x 9216 MKL SGEMM with 0 threads and 3 iterations, 9216, 3, -1, 0, NN, 9216, 9216, 4388.52
9728 x 9728 MKL SGEMM with 0 threads and 3 iterations, 9728, 3, -1, 0, NN, 9728, 9728, 4357.71
10240 x 10240 MKL SGEMM with 0 threads and 3 iterations, 10240, 3, -1, 0, NN, 10240, 10240, 4396.34
10752 x 10752 MKL SGEMM with 0 threads and 3 iterations, 10752, 3, -1, 0, NN, 10752, 10752, 4388.54
11264 x 11264 MKL SGEMM with 0 threads and 3 iterations, 11264, 3, -1, 0, NN, 11264, 11264, 4385.23
11776 x 11776 MKL SGEMM with 0 threads and 3 iterations, 11776, 3, -1, 0, NN, 11776, 11776, 4336.85
12288 x 12288 MKL SGEMM with 0 threads and 3 iterations, 12288, 3, -1, 0, NN, 12288, 12288, 4362.61
12800 x 12800 MKL SGEMM with 0 threads and 3 iterations, 12800, 3, -1, 0, NN, 12800, 12800, 4351.96
13312 x 13312 MKL SGEMM with 0 threads and 3 iterations, 13312, 3, -1, 0, NN, 13312, 13312, 4379.92
13824 x 13824 MKL SGEMM with 0 threads and 3 iterations, 13824, 3, -1, 0, NN, 13824, 13824, 1268.28
14336 x 14336 MKL SGEMM with 0 threads and 3 iterations, 14336, 3, -1, 0, NN, 14336, 14336, 4402.25
14848 x 14848 MKL SGEMM with 0 threads and 3 iterations, 14848, 3, -1, 0, NN, 14848, 14848, 4383.5
15360 x 15360 MKL SGEMM with 0 threads and 3 iterations, 15360, 3, -1, 0, NN, 15360, 15360, 4370.94
15872 x 15872 MKL SGEMM with 0 threads and 3 iterations, 15872, 3, -1, 0, NN, 15872, 15872, 4372.85
16384 x 16384 MKL SGEMM with 0 threads and 3 iterations, 16384, 3, -1, 0, NN, 16384, 16384, 4373.31
McCalpinJohn
SNC-4 mode is a pain to control properly.   It works well when you can run 4 MPI tasks per node and can launch these via a script that computes the correct NUMA node number for binding the memory to correct MCDRAM NUMA node.  A single shared-memory executable is not going to be able to use the MCDRAM in all four quadrants without ugly explicit code to place data using the "memkind" library (http://memkind.github.io/memkind/) or the NUMA APIs (e.g., http://man7.org/linux/man-pages/man3/numa.3.html).
For a single shared-memory executable, Flat-Quadrant mode almost always gives the best performance.  The default memory placement is DDR4 (NUMA node 0), but in this case there is only one non-default location (MCDRAM) so that is referred to as NUMA node 1.   If the job will fit entirely in MCDRAM, then it can easily be launched with
numactl --membind=1 ./a.out
If the job requires more memory than is available in MCDRAM, you either need a very detailed understanding of the access patterns and a carefully controlled explicit staging of data, or you can just use cache mode and accept whatever speedup is available for "free".
maicon_f_
Thank you Dr. Bandwidth, that will help know that we are working with real application tests.
Maicon
