Software Archive
Read-only legacy content
17060 Discussions
MIC0 device fails after installing MPSS 3.8.2
Charles_S_1
Good Afternoon,
My MIC card isn't working with the newly install MPSS 3.8.2 driver. I followed the instructions in the readme to install MPSS on a new RHEL 6.9 system. Below are some of the errors that I continue to receive:
[mpss-3.8.2]micctrl -s
mic0: reset failed
[mpss-3.8.2]# micctrl -rw
          mic0: resetting
  [Error] Timeout booting MIC, check your installation
I also cannot update the firmware/smc upon installing the MPSS driver and rpms:
[mpss-3.8.2]# /usr/bin/micflash -update -device all -smcbootloader
No image path specified - Searching: /usr/share/mpss/flash
mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_C0_0391-02.rom.smc
micflash: mic0: No compatible SMC boot-loader image found
micflash: micflash: mic0: Failed to switch to maintenance mode: write: /sys/class/mic/mic0/state: Input/output error
My hardware is a Supermicro workstation:
[mpss-3.8.2]# dmidecode -s bios-version
3.0a
[mpss-3.8.2]# dmidecode -s system-product-name
X9DRG-QF
Thank you for any insight or input on this issue. I've been beating my head into the ground over this.
JJK
New Contributor III
is the device visible to the OS? try
# lspci | grep copro
# lspci -v -s `lspci | grep copro | awk '{ print $1 }'`
which should list something like
02:00.0 Co-processor: Intel Corporation Xeon Phi coprocessor 5100 series (rev 11)
	Subsystem: Intel Corporation Device 2500
	Flags: bus master, fast devsel, latency 0, IRQ 32
	Memory at 21c00000000 (64-bit, prefetchable) [size=8G]
	Memory at cb900000 (64-bit, non-prefetchable) [size=128K]
	Capabilities: [44] Power Management version 3
	Capabilities: [4c] Express Endpoint, MSI 00
	Capabilities: [88] MSI: Enable- Count=1/16 Maskable- 64bit+
	Capabilities: [98] MSI-X: Enable+ Count=16 Masked-
	Capabilities: [100] Advanced Error Reporting
	Kernel driver in use: mic
If not, then your card is not functioning normally - this usually points at a cooling problem.
If you do see the card, then we'll proceed to debugging the mic driver itself
Charles_S_1
Hello JJK,
Yes, I'm able to verify that the coprocessor card is visible on the system:
[~]# lspci | grep copro
84:00.0 Co-processor: Intel Corporation Xeon Phi coprocessor 3120 series (rev 20)
[~]# lspci -v -s `lspci | grep copro | awk '{ print $1 }'`
        Subsystem: Intel Corporation Device 3608
        Flags: bus master, fast devsel, latency 0, IRQ 64
        Memory at 383c00000000 (64-bit, prefetchable) [size=8G]
        Memory at fba00000 (64-bit, non-prefetchable) [size=128K]
JJK
New Contributor III
good, that means it is most likely a software installation issue and not a hardware issue. I've got a very similar setup over here,. Next, run 'micinfo' as root:
# service micras stop
# service mpss stop
# micinfo
MicInfo Utility Log
Created Mon Jul 31 10:49:25 2017
	System Info
		HOST OS			: Linux
		OS Version		: 2.6.32-696.3.1.el6.x86_64
		Driver Version		: 3.8.2-1
		MPSS Version		: 3.8.2
		Host Physical Memory	: 64388 MB
Device No: 0, Device Name: mic0
	Version
		Flash Version 		 : NotAvailable
		SMC Firmware Version	 : NotAvailable
		SMC Boot Loader Version	 : NotAvailable
		Coprocessor OS Version 	 : NotAvailable
		Device Serial Number 	 : NotAvailable
	Board
		Vendor ID 		 : 0x8086
		Device ID 		 : 0x2250
		Subsystem ID 		 : 0x2500
		Coprocessor Stepping ID	 : 3
		PCIe Width 		 : x16
		PCIe Speed 		 : 5 GT/s
		PCIe Max payload size	 : 256 bytes
		PCIe Max read req size	 : 512 bytes
		Coprocessor Model	 : 0x01
		Coprocessor Model Ext	 : 0x00
		Coprocessor Type	 : 0x00
		Coprocessor Family	 : 0x0b
		Coprocessor Family Ext	 : 0x00
		Coprocessor Stepping 	 : B1
		Board SKU 		 : B1PRQ-5110P/5120D
		ECC Mode 		 : NotAvailable
		SMC HW Revision 	 : NotAvailable
	Cores
		Total No of Active Cores : NotAvailable
		Voltage 		 : NotAvailable
		Frequency 		 : NotAvailable
	Thermal
		Fan Speed Control 	 : NotAvailable
		Fan RPM 		 : NotAvailable
		Fan PWM 		 : NotAvailable
		Die Temp		 : NotAvailable
	GDDR
		GDDR Vendor		 : NotAvailable
		GDDR Version		 : NotAvailable
		GDDR Density		 : NotAvailable
		GDDR Size		 : NotAvailable
		GDDR Technology		 : NotAvailable
		GDDR Speed		 : NotAvailable
		GDDR Frequency		 : NotAvailable
		GDDR Voltage		 : NotAvailable
Now, start the mpss daemon and check the status:
# service mpss start
# micctrl -s
mic0: ready
and check /var/log/messages and dmesg for any error/warnings. You can also run 'micdebug.sh' and post the output file here - that will tell theh Intel support people a lot more.
Charles_S_1
Attached is the output from the 'micdebug.sh' script. I didn't see any errors in the messages file, but can confirm the following error message under 'dmesg':
[~]# dmesg |grep -i error
ERST: Error Record Serialization Table (ERST) support is initialized.
Error! Card not in offline/ready state. Cannot change mode
Below are the results from the other commands. Should I also restart the "micras" service?
[~]# service micras status
Intel(R) micras is stopped
[~]# service mpss status
mpss is stopped
[~]# micinfo
MicInfo Utility Log
Created Mon Jul 31 05:27:55 2017
        System Info
                HOST OS                 : Linux
                Host Physical Memory    : 516840 MB
        Version
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225d
                Subsystem ID             : 0x3608
                Coprocessor Stepping ID  : 2
                PCIe Width               : x16
                PCIe Speed               : 5 GT/s
                Coprocessor Stepping     : C0
                Board SKU                : C0PRQ-3120/3140 P/A
        Cores
        Thermal
        GDDR
[~]# service mpss start
Loading MIC module:                                        [  OK  ]
Starting Intel(R) MPSS:                                    [FAILED]
mpss is running
[~]# micctrl -s
mic0: reset failed
Charles_S_1
MICDEBUG.SH output attachment
JJK
New Contributor III
the micdebug files show (in host_dmesg.txt) a continuous cycle of:
   1776 mic0: Resetting (Post Code F2)
   1777 Reattempting reset after F2/F4 failure
   1778 mic0: Transition from state resetting to resetting
   1779 mic0: Resetting (Post Code 3C)
   1780 mic0: Resetting (Post Code 3C)
   1781 mic0: Resetting (Post Code 3d)
   1782 mic0: Resetting (Post Code 3d)
   1783 mic0: Resetting (Post Code 3d)
   1784 mic0: Resetting (Post Code 3E)
   1785 mic0: Resetting (Post Code 3E)
in this post it  is suggested to power down the box, unplug the cable, then power it up again:
 https://software.intel.com/en-us/forums/intel-many-integrated-core/topic/535257
Also, make sure that only a single version of the mpss stack is running (but since you're installing on a new host, I doubt that this is causing the problem).
Charles_S_1
I don't see any other versions currently running on this system please see below for current installed MPSS rpms. (FYI - I had to reinstall MPSS twice on this system to test a script that would automate this install on other systems in the environment).
I will power down the system, unplug both power cords and power back on; then reply back with my results. Thanks.
 [~]# ps -ef|grep -i mpss|grep -v grep
root     17451     1  0 05:29 pts/0    00:00:00 /usr/sbin/mpssd
[~]# rpm -qa | egrep "intel|intel-mic|libscif|glibc2.12pkg|netperf|mpss"|sort -u
glibc2.12pkg-libmicaccesssdk0-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libmicaccesssdk-dev-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libmicmgmt0-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libmicmgmt-dev-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libmicmgmt-doc-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libodmdebug0-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libodmdebug-dev-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libsettings0-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-libsettings-dev-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-mpss-flash-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-mpss-memdiag-kernel-3.8.2-1.glibc2.12.x86_64
glibc2.12pkg-mpss-rasmm-kernel-3.8.2-1.glibc2.12.x86_64
intel-composerxe-compat-k1om-3.8.2-1.x86_64
libscif0-3.8.2-1.glibc2.12.x86_64
libscif-dev-3.8.2-1.glibc2.12.x86_64
libscif-doc-3.8.2-1.glibc2.12.x86_64
mpss-boot-files-3.8.2-1.glibc2.12.x86_64
mpss-coi-3.8.2-1.glibc2.12.x86_64
mpss-coi-dev-3.8.2-1.glibc2.12.x86_64
mpss-coi-doc-3.8.2-1.glibc2.12.x86_64
mpss-core-3.8.2-1.glibc2.12.x86_64
mpss-core-dev-3.8.2-1.glibc2.12.x86_64
mpss-daemon-3.8.2-1.glibc2.12.x86_64
mpss-daemon-dev-3.8.2-1.glibc2.12.x86_64
mpss-eclipse-cdt-mpm-3.8.2-1.glibc2.12.x86_64
mpss-license-3.8.2-1.glibc2.12.x86_64
mpss-miccheck-3.8.2-1.glibc2.12.x86_64
mpss-miccheck-bin-3.8.2-1.glibc2.12.x86_64
mpss-micmgmt-3.8.2-1.glibc2.12.x86_64
mpss-micmgmt-doc-3.8.2-1.glibc2.12.x86_64
mpss-micmgmt-python-3.8.2-1.glibc2.12.x86_64
mpss-micsmc-gui-3.8.2-1.glibc2.12.x86_64
mpss-modules-2.6.32-696.3.1.el6.x86_64-3.8.2-1.x86_64
mpss-modules-dev-2.6.32-696.3.1.el6.x86_64-3.8.2-1.x86_64
mpss-modules-headers-3.8.2-1.glibc2.12.x86_64
mpss-mpm-3.8.2-1.glibc2.12.x86_64
mpss-mpm-doc-3.8.2-1.glibc2.12.x86_64
mpss-myo-3.8.2-1.glibc2.12.x86_64
mpss-myo-dev-3.8.2-1.glibc2.12.x86_64
mpss-myo-doc-3.8.2-1.glibc2.12.x86_64
mpss-offload-3.8.2-1.glibc2.12.x86_64
mpss-offload-dev-3.8.2-1.glibc2.12.x86_64
mpss-sciftutorials-3.8.2-1.glibc2.12.x86_64
mpss-sciftutorials-doc-3.8.2-1.glibc2.12.x86_64
mpss-sdk-k1om-3.8.2-1.x86_64
mpss-sysmgmt-micdiagnostic-3.8.2-1.glibc2.12.x86_64
mpss-sysmgmt-micras-3.8.2-1.glibc2.12.x86_64
mpss-sysmgmt-python-3.8.2-1.glibc2.12.x86_64
netperf-2.6.0-r0.glibc2.12.x86_64
netperf-doc-2.6.0-r0.glibc2.12.x86_64
Charles_S_1
I have powered off my system and left both power cords unplugged for ~15 minutes before plugging both power cords back in and booting back up. I've attached a new micdebug output for reference. The device seems to still be in the same state in the 'reset failed'.
[~]# dmesg |grep -i mic0|tail -4
mic0: Transition from state resetting to reset failed
[~]# micctrl -s
mic0: reset failed
JJK
New Contributor III
From the MPSS Userguide, section "Troubleshooting and Debugging" (I.2):
The POST codes are defined as follow:
"3C" Begin GDDR read training with CDR enabled
"3d" Begin GDDR read training with CDR disabled
"F2" GDDR failed memory training
"F4" Memory preservation failure
this suggests that there is a problem with the GDDR memory on the Phi board.  I'd recommend talking to your sales rep here, or perhaps someone from Intel support can help out here - unfortunately this DOES look like a hardware problem.
Charles_S_1
Just to followup with this thread after some time, it was indeed a hardware issue with the coprocessor. After swapping it out for a newer coprocessor and updating the supermicro bios the card is now functional and the 'mic0' device is showing as ready:
[~]# micctrl -s
mic0: ready
Charles_S_1
So I spoke too soon. I just rebooted my system and now the mic0 device is missing:
[~]# dmesg|grep -i mic0
Should I uninstall/reinstall mpss3.8.2 to resolve the issue? Attached is my micdebug output. Thanks.
