Software Archive
Read-only legacy content
17060 Discussions
MPEG-2 DXVA Not Decoding
gowthamhk
Hi
I am facing a problem in making my MPEG-2 Video Decoder filter to work using DXVA (essentially hardware decoding). My system supports MPEG-2 off-host bitstream processing. Here is my problem.
Following is the sequence of APIs I have called on XP, DXVA1.0 for MPEG2_A(probed and
locked for off-Host bitstream parsing):
- BeginFrame()
- GetBuffer( for PictureParameter buffer)
- Execute() (for PictureParameter buffer)
- ReleaseBuffer() (for PictureParameter buffer)
- Loop 3 times - (for InvQuantization, SliceControl and Bitstream data buffers sent together)
{ GetBuffer()
- Execute()
{ ReleaseBuffer()
- EndFrame()
- QueryRenderStatus()
All these APIs returned S_OK. but when I call DisplayFrame() with the same surfaceIndex, output is blank.
Experiments carried out :
1. - Called BeginFrame()
- Got the pointer to buffer through GetBuffer() with TypeIndex as 0xFFFFFFFF and
BufferIndex as surfaceIndex after BeginFrame and memset with a known value. (set with value 128)
- Called Execute() with necessary buffers
- Called EndFrame()
- Called QueryRenderStatus()
- Again got the pointer to buffer through GetBuffer() and checked the values, It was not modified
and the value was exactly equal to what i set previously. (it was still 128)
This means even if all the APIs return S_OK, the surfaceIndex is untouched. I am stuck at this point.
2. I also carried out one more experiment by sending InvQMatrix, SliceControl and bitstream data
buffers through separate Execute calls. We Initialized *lpPrivateOutput to 128.
Here lpPrivateOutput of Execute() returned '0' while sending InvQmatrix and slicecontrol buffers.
But when bitstream data buffer(bitstream starting from slice start code of 1st slice) was sent
lpPrivateOutput was not updated. Does this mean that there is some problem in sending the bitstream buffer?
Please help me if I am missing something. If any addition information is required please let me know.
Any Input or thoughts is greatly appreciated.
Cheers,
Gowtham
gowthamhk
Quoting - gowthamhk
Hi
- BeginFrame()
{ GetBuffer()
- Execute()
{ ReleaseBuffer()
- EndFrame()
- Called EndFrame()
Cheers,
Gowtham
No response from Intel???
gowthamhk
I got it, anyways.
htq
Hello gowthamhk,
I'm facing a similar problem using DXVA2 in VLD MPEG2 decoding mode (the output surface is blank/green).
Could you please explain how did you manage to fix the blank output problem?
Thank you in advance!
gowthamhk
Add 32 for MB bit offset in SliceInfo buffer. The doc doesn't mentions it properly. And let me know.
htq
Thanks a lot!
Got it working. MS should correct the doc after so many years... It seems that adding 8 for the MB bit offset and removing the slice start code prefix also works.
Thanks again and best regards.
gowthamhk
WC
Yeah. That doc is a little ambiguous at places.
jacky_yue
hello Gowtham, have you solved the problem? I have got the similar problem. thanks jacky
shin
Hi all i have the similiar problem too, anyone can help ?
