I am trying to run application from host machine on coprocessor but when i execute the command
mpirun -n 2 -host host-name /tmp/test.mic
it hangs on command line and does not show any output.
However when i run directly on coprocessor/host , it works fine. What could be the issue?
Are there any messages printed before the hang?
Can you please confirm that the environment variable I_MPI_MIC=1 is set before issuing mpirun?
Waht is the output of
$ mpirun -V
Could you try
$ mpirun -n 2 -host mic0 -env I_MPI_DEBUG=3 <your_mic_binary>
Could you try
$ mpirun -n 2 -host localhost -env I_MPI_DEBUG=3 <your_host_binary>
Leo.
Thanks for your reply.
mpirun -V
Intel(R) MPI Library for Linux* OS, Version 4.1 Update 3 Build 20131205
Copyright (C) 2003-2013, Intel Corporation. All rights reserved.
this works fine for localhost. but
mpirun -n 2 -host mic0 -env I_MPI_DEBUG=3 <your_host_binary>
after entering this command, it seems that it waits / hangs.
Hi Roshan,
I think Leo suggests you to run
% mpirun -n 2 -host mic0 -env I_MPI_DEBUG=3 <your_mic_binary>
but not
% mpirun -n 2 -host mic0 -env I_MPI_DEBUG=3 <your_host_binary>
You may need to compile your mic binary with the command
% mpiicc -mmic <source code> -o <your_mic_binary>
For example:
% mpiicc -mmic test.c -o test.mic
Besides, you need to transfer the MIC binary to your coprocessor (or NFS mount):
% scp test.mic mic0:/tmp/.
And also pmi_proxy and all MPI libraries
% scp /opt/intel/impi/<version>/mic/bin/pmi_proxy mic0:/bin
% scp /opt/intel/impi/<version>/mic/lib/* mic0:/lib64/.
After enabling the env variable I_MPI_MIC
% export I_MPI_MIC=1
Now you should be able to run it:
% mpirun -n 2 -host mic0 -env=I_MPI_DEBUG=3 /tmp/test.mic
Perfect. I definitively recommend following Loc’s guidelines step-by-step as described above.
If you still see the silent hang issue after trying these, I’d suggest a step back and making sure that the environment is actually prepared to run MPI:
1. Would you confirm that it is possible to execute ‘hostname’ on mic0 via ssh? (a fail here would be equivalent to "scp" failing in the above guidelines)
$ ssh mic0 hostname
2.If OK, then can you please try to use mpirun to execute only ‘hostname’ on mic0? (that is, without any user-compiled binary)
$ setenv I_MPI_MIC 1
$ mpirun -n 2 -host mic0 hostname
Thank you,
Leo.
I followed the instructions given by Loc by no success.
when i
"ssh mic0 hostname"
I can see the hostname. Also scp for copying binary works.
When i
" mpirun -n 2 -host mic0 hostname"
it hangs or does not show any o/p.
Did i miss to set any variables here? I doubt because I can run the application directly on mic0
Let's me take a look at your /etc/hosts files on host and coprocessor. Would you please display the output from the following commands:
[cpp]
% hostname
% cat /etc/hosts
% ssh mic0 hostname
% ssh mic0 cat /etc/hosts
[/cpp]
hostname
gauss
cat /etc/hosts
127.0.0.1 localhost
127.0.1.1 gauss
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
172.31.1.1 gauss-mic0 mic0
172.31.1.254 hostmic0
ssh mic0 hostname
gauss-mic0
127.0.0.1 gauss-mic0 mic0 localhost.localdomain localhost
::1 gauss-mic0 mic0 localhost.localdomain localhost
172.31.1.254 host
Hi Roshan,
Look at your /etc/hosts on your host system, there are two additional lines that makes me wonder
127.0.1.1 gaus
and
I am not sure how you have these lines in your /etc/hosts
And in the /etc/hosts in the coprocessor, it looks like it misses one line
My suggestion is to remove the above two lines in /etc/hosts in your host system (save it first for backup) . Also, try the following commands in your host system and see if there is any output:
[cpp]
mpirun -host mic0 hostname
mpirun -host 192.131.1.1 hostname
mpirun -host gauss-mic0 hostname
[/cpp]
For all three commands, i get "gauss" output. I removed 2 lines from hostmachine /etec/hosts file and added "172.31.1.1 gauss-mic0 mic0 " on co-processor.
After doing this I still not able to run it.
If you run
export I_MPI_MIC=enable; mpirun -host mic0 -n 1 hostname
It should respond with
gauss-mic0
this doesn't give any output or it seems that it hangs which is same behaviour as my problem.
It might be worth to verify if your mpirun command is at least issuing the ssh command for the connection. Would you please add the "-v" verbose option to the mpirun command as shown below and post the output here?
% export I_MPI_MIC=enable; mpirun -v -host mic0 -n 1 hostname
Also: can you confirm you can ssh without a password to mic0 ?
Thank you,
Leo.
Need to set up passwordless SSH to the coprocessor.
Passwordless SSH is a prerequisite for MPI.
Now i have setup passwordless ssh. But when i run mpirun command i still get an error messgae:
"[proxy:0:0@gauss-mic0] HYDU_sock_connect (./utils/sock/sock.c:264): unable to connect from "gauss-mic0" to "127.0.1.1" (Connection refused)
[proxy:0:0@gauss-mic0] main (./pm/pmiserv/pmip.c:396): unable to connect to server 127.0.1.1 at port 42947 (check for firewalls!)
^CCtrl-C caught... cleaning up processes
[mpiexec@gauss] HYD_pmcd_pmiserv_send_signal (./pm/pmiserv/pmiserv_cb.c:239): assert (!closed) failed
[mpiexec@gauss] ui_cmd_cb (./pm/pmiserv/pmiserv_pmci.c:127): unable to send SIGUSR1 downstream
[mpiexec@gauss] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
[mpiexec@gauss] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:435): error waiting for event
[mpiexec@gauss] main (./ui/mpich/mpiexec.c:900): process manager error waiting for completion"
172.0.1.1 is the IP address of gauss according to your original /etc/hosts on host.
I am guessing that maybe removing these two lines causes this problem. Can you try to put them back in in the host /etc/hosts and try again?
Follow the advice in the output, "check for firewalls!"
It's likely a firewall is preventing the connection from the coprocessor to the host.
See also,
http://software.intel.com/en-us/articles/firewalls-and-mpi
http://software.intel.com/en-us/articles/using-intel-mpi-library-and-intel-xeon-phi-coprocessor-tips
Now, i am getting different error message:
when i run " mpirun -n 2 -host mic0 /tmp/test.mic"
sh: /opt/intel/impi/4.1.3.045/intel64/bin/pmi_proxy: not found
This binary is present on both the machines.
Can you please confirm that I_MPI_MIC is set to either "1" or "enabled"?
Woul you send the output of:
% export I_MPI_MIC=enable; mpirun -v -host mic0 -n 1 hostname |& grep "Launch arguments"
thanks,
Leo.
it gives output
"[mpiexec@gauss] Launch arguments: /usr/bin/ssh -x -q mic0 sh -c 'export I_MPI_ROOT="/opt/intel/impi/4.1.3.045" ; export PATH="/opt/intel/impi/4.1.3.045/intel64/bin//../../mic/bin:${I_MPI_ROOT}:${I_MPI_ROOT}/mic/bin:${PATH}" ; exec "$0" "$@"' pmi_proxy --control-port 127.0.1.1:52573 --debug --pmi-connect lazy-cache --pmi-aggregate -s 0 --enable-mic --i_mpi_base_path /opt/intel/impi/4.1.3.045/intel64/bin/ --i_mpi_base_arch 0 --rmk slurm --launcher ssh --demux poll --pgid 0 --enable-stdin 1 --retries 10 --control-code 107981940 --proxy-id 0 "
when i enabled above variable and run mpirun command i got an output
"/bin/pmi_proxy: line 2: syntax error: unexpected word (expecting ")")"
