Product: Intel® Composer XE for Linux*, Versions 13.0 Initial Release (2013.0.079) and Update 1 (2013.1.117).
Debugger Version: Intel® Many Integrated Core Architecture Debugger (Intel® MIC Debugger) Version 13.0, Initial Release and Update 1
MPSS Version: MPSS Gold Update 1 (2.1.4982-15)
Problem: The MPSS Gold Update 1 contains an error that prevents the MIC debugger from functioning. When the idbserver_mic is launched on the MIC card it reports the following:
$ ./idbserver_mic
Intel(R) Debugger Remote Server, Build [79.944.23]
This version is configured for k1om on Linux
Copyright (C) 2006-2013 Intel Corporation. All rights reserved
Problem Solution: The hotfix provided here has a work-around to allow the MIC debugger to function with MPSS Gold Update 1. To apply the hotfix, you need to replace <instdir>/intel/composer_xe_2013.x.xxx/debugger/mic/lib/idbserver_mic on your host system by the extracted idbserver_mic file attached to this thread. The replacement needs to be done by the user who installed the Intel Composer XE package; the replacement file needs to have the rights rwxr-xr-x of that user.
Please note: The Intel MIC Debugger is a licensed product. The debugger, including the binary posted here, requires that your system has an active license to Intel Compilers and/or Intel Studio XE products. This debugger binary will not function without a valid and up-to-date license on your system. If you do not have a license to Intel compilers, please contact your Intel Application Engineer or post a license request in a separate thread to this forum"
