Software Archive
Read-only legacy content
17060 Discussions
Mac OS 10.6 64 bit Could not run startup script
Alberto_Verga
The installation script of the Fortran compiler (m_fcompxe_2011.2.142.dmg, Fortran Composer XE 2011) gives an error when open in a MacBook Pro (startup 64 bits by default, 64-bit Kernel and Extensions: Yes). The error message: "Could not run startup script".
I could install the *same* package on an iMac, also under Snow Leopard, but with:
64-bit Kernel and Extensions: No
I want to use it in 64 bit mode.
Thank for your help
Alberto.
Alberto_Verga
I solved the problem. I created a directory /Users/Shared/Library/Application\ Support/Intel with chmod 777
and verified that /tmp was also 777
Nothing to do wit 64 bits!
Sorry.
Rob5
New Contributor II
Alberto,
Thank you for the update and solution that resolved the error you received. Much appreciated.
Sincerely,
Rob
Intel Support
Joseph_W_
Please can you explain how to do this simply?
Thanks alot J
