Software Archive
Read-only legacy content
Make a dial
MULUMBA_F_
Hello everybody, I am new and I have not find a French forum for Intel XDK and my English is not very good. My question is can I create a phone app that make a dial (call) or send an USSD with Intel XDK? If it is possible, how can I do it easily? Thanks.
Chris_P_Intel
If you generate a tel: type link, then that will work when your app runs on a mobile device.  That's the easiest.  ( http://stackoverflow.com/questions/13662175/how-to-create-hyperlink-to-call-phone-number-on-mobile-devices )
There is a tutorial for placing calls with Cordova/Phonegap here:
http://rickluna.com/wp/2012/02/making-a-phone-call-from-within-phonegap-in-android-and-ios/
The XDK uses Cordova, so any information you find on the internet relative to HTML5 or Cordova (aka Phonegap) will work with the XDK
And, if you really need advanced features, you might need a custom Cordova plugin:
http://plugreg.com/plugin/rohfosho/CordovaCallNumberPlugin
Hope this helps,
Chris
Chris_P_Intel
Hope this helps,
Chris
PaulF_IntelCorp
Hello Mulumba -- one thing to note regarding dialing the phone. This is an OS-restricted operation, so your app can typically only cause the dialer to be presented with a phone number, the user must then initiate the call. This is done for security reasons.
MULUMBA_F_
Thank you CHRIS, your second link has all I need about making call and using keywords "cordova" on google help to find many information.
Rethinavel_M_
the above link example is not understand for me..
please help.. how  can I create a phone app that make a dial (call) or send an USSD with Intel XDK?
Am new to intel xdk so please explain detail.. step by step.
example, plugin,js,and code
