Software Archive
Read-only legacy content
17060 Discussions
Memory Allocation Problems
sprasad
I have a dual Athlon machine with 2 GB of physical RAM and 3 GB of virtual memory. When I try to allocate 2 double precision arrays of size greater than 11250 by 11250, the application exits with an insufficient virtual memory error. This is very strange!!! At 11250,11250 size, 8 bytes per array gives me a total memory requirement of only 1.93 GB. So what is going on? I have searched the Compaq knowledge base without success. Any help is much appreciated.
p.s. increasing the VM allocation to 4 GB did not help either.
Jugoslav_Dujic
Valued Contributor II
You hit the OS limit. 32 bits can address 4GB of memory, of which Windows reserves 2 GB for itself. What's left is in theory 2GB but in practice you can hardly get more than about 1.7.
Jugoslav
sprasad
Windows reserves 2 GB for itself???? I didn't know that - I knew about the 4 GB addressable limit, but didn't realise that applications were limited to a max of 2 GB. I may have to seriously consider moving to Linux now.
Jogoslav is correct. More specifically, process address space is 2GB, and system (shared) address space is 2GB. This is a popular design in 32-bit operating systems.
If you want more, you'll need a 64-bit processor such as Alpha and a 64-bit OS (Linux will do). WIndows NT on Alpha was 32-bits. Linux and Windows on Itanium are 64-bit, but this may or may not be an appropriate solution for you now.
Steve
jhp
From Steves answer one can conclude that working with 32 bits we will found the same limit in memory addresable under windows and under linux?
If you're talking x86 Linux, yes. Alpha Linux and Itanium Linux are 64-bit.
Steve
