Software Archive
Read-only legacy content
17060 Discussions
Memory Leak with COM Server
brownts
Using COM Wizard, I have developed a Fortran COM server application that is called from Visual Basic. Both the Fortran and VB applications work fine, except that there is a memory leak. Everytime a particular method is called, the memory usage increases ~8K. If the calls to the method are removed from the VB application, there is no memory leak. If all of the function of the method is removed from the Fortran, leaving just a dummy method, the memory leak does still occur. This leads to the conclusion that the problem is in the code generated by the COM Wizard, which leaves me at a bit of a loss as to how to debug.
Has anyone seen this occurring? I am running Version 6.5.A on Windows NT.
Intel_C_Intel
I'm not aware of any leaks. If you'd like to send the COM server and VB client to vf-support, I'll take a look at it.
Leo
brownts
Leo,
I am in the process of paring the project down to bare bones to get something that I can send you complete. Probably send it to Compaq tomorrow.
Trent
Intel_C_Intel
Ive made the same discovery but the other way around. Ive made a COM -dll written in VB and I used the wizard to access it from VF. Everything works fine but there is a memoryleak when using strings and variants. No solution found yet
Im using Windows NT/2000 and VF6.1a
/Martin
Intel_C_Intel
The COM Server Wizard is a different beast than the COM Module Wizard.
Prior to CVF 6.5 the Module Wizard generated code for intent(in) BSTRs that had a memory leak. This was fixed in 6.5. If you don't want to upgrade, then the solution is to call SysFreeString on the local integer (BSTR) variable in the wrapper function $ISomeInterface_MethodFoo after the actual COM method call is made.
Do you have an example of a memory leak with Module Wizard generated code using variants? I'm sure people would be interested in seeing it.
hth,
John
brownts
Martin,
My first note seems to have misdiagnosed the problem. We have been trying, off and on, to isolate the problem down to a concise piece of code. We also are using Fortran to access VB COM objects including passing strings and variants. The memory leak appears to occur when we convert a fortran character strings into a variant and send this to VB. Sounds similar to your problem. When we get it completely isolated we will send the code to Compaq.
Trent
Intel_C_Intel
Trent,
The wrapper code that the Module Wizard generates for variants pretty much just passes what the caller has provided to the COM object's method (sometimes it makes a shallow copy like in the case of an optional arg). I'm having a hard time imagining where it could create a leak. Makes me wonder if the code that calls the wrapper is properly dealing with memory wrt variants and BSTRs.
COM memory management requires that If the argument is intent in, then the caller is required to allocate and deallocate the memory. If the argument is intent out, the method will allocate and the caller gets to deallocate. There's a brief example below if it helps at all.
Just a stab in the dark,
John
! COM memory management
! For intent in args, the caller owns the memory. In this case,
! caller allocates and deallocates memory for the string
function foo_intent_in(pObj, Str) result
use dfcom
implicit none
! dummy vars
integer, intent(in) :: pObj
character(len=*), intent(in) :: Str
integer :: r
! locals
integer :: bstrStr, hr
type (VARIANT) :: vStr
! body
! convert to BSTR for packaging in a variant
bstrStr = ConvertStringToBSTR( Str(1:len_trim(Str)) )
CALL VariantInit(vStr)
vStr%VT = VT_BSTR
vStr%VU%PTR_VAL = bstrStr
hr = $ISomeInterface_MethodFoo_IntentIn(pObj, vStr)
r = hr
hr = VariantClear(vStr)
! calls SysFreeString <=== critical
end function foo_intent_in
! For intent out args, the COM method allocates memory for the string
! and the caller deallocates it.
function foo_intent_out(pObj, Str) result
use dfcom
implicit none
! dummy vars
character(len=*), intent(out) : : Str
integer :: r
! locals
! body
CALL VariantInit(vStr) ! must pass an initialized variant
Str = " "
Intel_C_Intel
Gotta love that forum message size limit. <>
Get the sample at http://www.termine.org/f90/variantmem.f90
-John
