Software Archive
Read-only legacy content
17060 Discussions
Memory error?
ma_poub
The following program crashes on comapq 6.1 and 6.1A (Win NT 2000 and Win 98) for big entries where as it does not with MS fortran 4.0 nor NAG free F90 compiler (Linux)
For small entries (nb_elem) it is fine
size(v1)=1000
size(v2)=10
Big entries
size(v1)=100000
size(v2)=10
Can someone help?
ma_poub
Sorry the program:
program ess
  implicit none
  ! Variables
  complex :: j
  real , parameter :: PI = 3.14159
  integer :: nb_elem
  complex, dimension(:),pointer :: resultat
  complex, dimension(:),allocatable :: v1
  complex, dimension(:),allocatable :: v2
  j=cmplx(0,1)
  write(6,*) "entrer le nb_elem v1 :"
  read(*,*) nb_elem
  !nb_elem=100000
  allocate(v1(nb_elem))
  write(6,*) "entrer le nb_elem v2 :"
  read(*,*) nb_elem
  !nb_elem=10
  allocate(v2(nb_elem))
  v1=1+j
  v2=3+j
  resultat=>conv(v1,v2)
  write(6,*) resultat(size(resultat))
  deallocate (resultat)
CONTAINS
    FUNCTION conv(val_x1,val_x2)
      COMPLEX,dimension(:),pointer :: conv
      COMPLEX,dimension(:),intent(in),target :: val_x1
      COMPLEX,dimension(:),intent(in),target :: val_x2
      COMPLEX,dimension(:),pointer :: x1
      COMPLEX,dimension(:),pointer :: x2
      !COMPLEX,dimension(:),pointer :: temp_conv
      INTEGER :: i
      allocate(conv(size(val_x1)+size(val_x2)-1))
      conv=0
      IF (size(val_x1)>size(val_x2)) THEN
         x1=>val_x1
         x2=>val_x2
      ELSE
         x1=>val_x2
         x2=>val_x1
      END IF
      !write(6,*) ((size(x1)-1)-(size(x2)+1)+1)
      !write(6,*) (size(x1)-size(x2)-2+1)
      !write(6,*) x2
      conv(1:size(x2))=(/ (dot_product(x1(1:i),x2(i:1:-1)),i=1,size(x2)) /)
      conv((size(x2)+1):(size(x1)-1))= &
           & (/ (dot_product(x1(i:i+size(x2)-1),x2(size(x2):1:-1)), &
           & i=2,size(x1)-size(x2)) /)
      conv(size(x1):size(x1)+size(x2)-1) = &
           & (/ (dot_product(x1(size(x1)-size(x2)+i:size(x1)), &
           & x2(size(x2):i:-1)),i=1,size(x2)) /)
      write (6,*) conv(size(conv))
    END FUNCTION conv
end program ess
Steven_L_Intel1
The error message (which you should have mentioned) is Stack Overflow. The compiler is using the stack to create an array temporary that is larger than the default 1MB. I found that by changing the stack reserve to 5000000, it ran ok. This is under Link..Output.
Steve
