Software Archive
Read-only legacy content
17060 Discussions
Memory remapping with Core Duo
kerecsen
My (embedded) software is on the memory-hungry side, so I'm looking for a board that would let me use the Core Duo with a full 4 GB memory configuration. The Core Duo would be preferrable over the P4 series due to cooling considerations.
It is my understanding that only the higher-end (such as 955x and the upcoming p965) chipsets support memory remapping (ie: pushing the last gig of memory to the 4..5 GB range), and without that feature I lose the last half or full gig of memory to the BIOS and PCIX MMIO ranges. I would naively imagine that the CPU has to have a 36 bit physical address bus (and PAE support, obviously) for the remapping to work even on those chipsets. From the pin layour section of the data sheets it looked like Core Duo is strictly 32 bit.
Am I missing something, or is the Core Duo only practical to use for 3 GB of RAM or less?
Intel_Software_Netw1
If the information you seek is notlinked from thetechnical documentation pages at http://www.intel.com/design/mobile/core/duodocumentation.htm, our recommendation here would be to chat with an Intel rep in your region to determine what will work best for you.If your company has its own Intel representative, you may wish to inquire whether they are able to assist with this inquiry. Your company's Purchasing Department will normally have your Intel representative's contact information. If you have no contact, please see http://www.intel.com/buy/networking/design.htm under "Design Components".
If your location is not listed, please see an Intel Authorized Distributor and ask for a Field Application Engineer (FAE). Our Intel Authorized Distributor list is also linked from the URL above.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
princechennai
So then how to get the PC to be addressed the full memory size. How to remap the memory..
princechennai
