Software Archive
Read-only legacy content
17060 Discussions
Menu Short cuts
davidgraham
I want to be able to access menu items by pressing a single key on the keyboard - say "M" for a "Move" command, rather than having to select the "Edit" then the "Move" menu items, or instead of using the "Move" button on the tool bar.
How do I trap these keyboard characters in a Windows API project to achieve this?
David
isn-removed200637
It is straightforward to program 'accelerator keys' using Visual Fortran.
Use the Resource Editor to create an 'accelerator table', defining key combinations for frequently-used menu items, and give it a name (e.g.'GENERIC') and then in your WInMain function add
character*100 lpszAcceltabname
lpszAcceltabname="Generic"C
After registering your window class, load your menu and accelerator table resources and create your main window
hmenu		= LoadMenu(hInstance, LOC(lpszMenuName))
haccel		= LoadAccelerators(hInstance, LOC(lpszAcceltabname))
ghInstance	= hInstance
hWnd = CreateWindow(	lpszClassName,                      &
                        lpszAppName,                           &
                        INT(WS_OVERLAPPEDWINDOW),              &
                        50,                         &
                        50,                                     &
                        800,                                   &
                        575,                                   &
                        NULL,                                  &
                        hmenu,                                 &
                        hInstance,                             &
                        NULL                                   &
i = ShowWindow( hWnd, SW_SHOWNORMAL)
ghWnd=hWnd
then start your message loop and include a reference to the TranslateAccelerator function to trap keyboard accelerators
! Start a message loop
do while( GetMessage (mesg, NULL, 0, 0) .NEQV. .FALSE.)
! look for accelerator key-strokes - returns TRUE if key-stroke found and processed
!  do not process message further if accelerotor key processed
if (TranslateAccelerator( hwnd, haccel, mesg).EQV. .FALSE.) THEN
! process message if accelerator not used
   i =  TranslateMessage( mesg )
   i =  DispatchMessage( mesg )
   ENDIF
end do
WinMain = mesg.wParam
end
HTH
Jugoslav_Dujic
Valued Contributor II
...just an additional remark -- accelerator IDs from resource accelerator table should be the same as corresponding menu IDs. In this case, a) you don't change any of WM_COMMAND handling code b) Windows automatically disables accelerator when menu item is grayed and vice versa.
Jugoslav
davidgraham
Thanks for the reply - I was trying to use WM_KEYUP!
I now have a resource table and have defined lpszAcceltabname - but when I make the call
haccel=LoadAccelerators(hInstance,LOC(lpszAcceltabname))
I get the error -
The specified resource name cannot be found in the image file.
I have not mistyped the accelerator name. Is there something I have missed?
Thanks, David
davidgraham
I managed to fix it myself by forcing the resource ID number rather than the resource name:-
haccel= LoadAccelerators(hInstance,MakeIntResource(127))
Thanks, David
