Software Archive
Read-only legacy content
17060 Discussions
Microsoft Sql database Connectivity
sai_krishna_R_
Is it possible to connect the intel xdk to external databases like Microsoft SQL server??
If possible , please provide me some solution to establish the connectivity
Amrita_C_Intel
You can use one of the following methods for using database:
1- Using HTML5 client side databases. HTML5 provides four different types of Storage of data on a local client's machine. They are
Local Storage. Web SQL Storage. Session Storage Indexed DB
It depends on your demands you can use one of them. If you need a persistent database for saving values less than 5 Mb, I recommend you LocalStorage as implementation of that is very easy. The data you saved in HTML5 localstorage will not be deleted even in case of phone shut down or reset. The data will be deleted only when you remove it by localStorage.removeItem(); Client side database is not recommended if you have huge amount of data or you need a central database which you should show to everybody who use this app in the world. in these cases its better, you use server side database
You can read a very nice article about how to use html5 local databases in XDK website:https://software.intel.com/en-us/articles/html5-local-storage
2- You can use server database like MySQL or SQL server. however you need to connect your html codes to a PHP or asp.net script in a server by AJAX. You may use JSON for transfer data from PHP in server side to JS in the client side.
3- You can use cloud databases like Parse.com however there are some limitation depends of pricing plan you choose.
