Software Archive
Read-only legacy content
17060 Discussions
Mplayer performance with VAAPI support
Rajkumar
Dear All,
I am working on Intel atom board (z530 1.60GHz) & Driver version: Intel Embedded Graphics Driver 10.2 Build 1447.Here I am trying to abserve the CPU utilization of mplayer with VAAPI support i followed steps given in below website
http://www.splitted-desktop.com/~gbeauchesne/mplayer-vaapi/
But while running application with ./mplayer -vo vaapi -va vaapi this option NO DISPLAY IT IS FULL GREEN SCREEN.
can any one give suggesition.
NOTE :- THIS IS ON MOBLIN OS
Thanks in advance
Raj
Neal_Pierman
Valued Contributor I
I'm not able to help you get mplayer to work with your specific configuration (as this forum is dedicated to questions about using Intel's GPA product).
I'm therefore moving this post to a different forum which may be able to help you find an answer to your problem.
Neal
Rajkumar
Thank you for your reply.
Raj
Neal_Pierman
Once you get around some of the initial problems you're encountering, note that if you want to use GPA to analyze mplayer, you'll need to run mplayer in DirectX mode (with DX 9.x or DX 10.0), as GPA only works with these API's. I have seen that mplayer has many different command-line modes controlling how it runs (such as with OpenGL), which is why I am mentioning this (as I haven't scanned the actual code for this special version of mplayer to verify which API it is using).
Also, the graphics chipset you mentioned does not have hardware support for all of the metrics you might be interested in, so you'll have to experiment to see if GPA can help you out for your specific situation.
Neal
Rajkumar
I hope you mistaken the platform specification which i am using. Actually i am trying on Intel atom board (z530 1.60GHz) & I installed Moblin OS (2.6.31.rc6-67.1.moblin2-ivi).
IEGD Version : 10.2.1477
Libva version : 0.29 whith these specification it is displaying green screen.
If use IEGD Version : 10.3.1495 I am getting following error,
[vo_vaapi] vaQuerySubpictureFormats(): unknown libva error
Error opening/initializing the selected video_out (-vo) device.
