Software Archive
Read-only legacy content
17060 Discussions
Multipage APP with commom header, footer, sidebar only in AppFramework?
Hamilton_Tenório_da_
Valued Contributor I
I am trying to create an APP with same header in all the pages. I did one using AppFramework. Now, i am trying to do the same with Ionic. I use the same process: create a new project, create the first page with the header, etc.
When I create the second page (sub-page using the same header, footer and sidebar) nothing is present. I need to define everything again. I tried with the others options (Bootstrap, jQuery mobile, etc.) and is the same.
The concept of one header, one footer and one sidebar for all the APP is present only in AppFramework? If not, can you provide me some example or tutorial?
Amrita_C_Intel
I tried to recreate it and facing the same issue. So this issue has been passed to engineering team. Thank you for your patience. trying to resolve ASAP.
ok. Thank you.
Chris_P_Intel
For some reason the sub-pages and headers are being inserted in the wrong order.  I believe you can work around this by going to Code view and moving header to be before the sub-pages for any page.   YMMV.
