I'm just wondering that is there a reason for "CR3 target value" has limitation for just 4 of them are allowed when you try to avoid VM-exit from everytime process switching occured. According to manual it says "if future implementation support more than 4 CR3-target values, blah blah" as I understand, Intel has a plan to support more than 4 CR3 target values then why the hell it's not implemented this time?
Anyway, if I want to avoid VM-exit as few as possible for the performance issuewhat technique I can use of?
The CR3-target values are CPU resources that are used in VMX non-root operation. Intel evaluated algorithms using these values and determined that, for these algorithms, use of more than 4 values provided only marginal benefit to performance. For that reason, Intel elected to devote CPU resources to other features that may provide greater benefit. Intel reserves the right to support more than 4 CR3-target values in the future if it transpires that they would provide more significant benefit.
To hopefully answer your second question, Intel corporation is bringing EPT to market soon, and that will address most performance issues with page-table shadowing in the future (e.g., will eliminate need for any CR3 exits).
