Software Archive
Read-only legacy content
17060 Discussions
NEED HELP with cordova-plugin-navis-background-geolocation
Andrejs_V_
Hello All!
I stopped with problem working with cordova-plugin-navis-background-geolocation .
I can build project for Android, but when I try init this object  window.plugin.backgroundGeoLocation I get undefined.
when I try search how to resolve problem , found only this two similar sites:
https://getsatisfaction.com/apperyio/topics/geolocation_plugin_problem
https://getsatisfaction.com/apperyio/topics/-tutorial-background-geolocation-plugin-installation
It's hard to me correctly reflect to XDK specific .
There need only one simple task:
after get app.ready
document.addEventListener("app.Ready", first_locate, false);
function first_locate(){
    if (navigator.geolocation) {
      navigator.geolocation.getCurrentPosition(function(position){
      alert('Init ok');
    }, function() {
      alert('Error ');
      //handleLocationError(true, infoWindow, map.getCenter());
    {enableHighAccuracy: true});
  } else {
    // Browser doesn't support Geolocation
     alert('Dont support ');
    //handleLocationError(false, infoWindow, map.getCenter());
  //var bgGeo = window.plugin.backgroundGeoLocation;
  var bgGeo = window.plugins.backgroundLocationServices;
   if (typeof bgGeo === 'undefined') {
               alert('Plugin has not been initialized properly!', 'Error');
               //return false;
   if (window.plugin.backgroundGeoLocation) {
             alert('Window.plugin.backg');
    if (window.plugin.backgroundLocationServices) {
             alert('Window.plugin.Servisbackg');
get any alert message , or don't get
message .
Any help are welcome!
Very need .....
All needed version for Android-sdk are OK
XDK 3522
Java SDK 1.08.101
all plugins from npm latest versions
framework F7
PaulF_IntelCorp
I'm guessing you're trying to use this plugin inside of the Simulate tab or in App Preview. It will only work in the Debug tab or in a built app.
Also, looking at the README and the sample app in that plugin repo it appears that the API interface is different. See the code in this sample > https://github.com/ivent/cordova-plugin-background-geolocation/blob/master/example/SampleApp/www/js/index.js < and notice that references are via an object named "backgroundGeoLocation" which would be inside window, not navigator.
I am speculating, I do not know that plugin and am guessing based on a very quick scan, you should take a closer look at the documentation and examples provided by the plugin developer.
Andrejs_V_
Thank's for replay.
But: I build app to apk file and get alert that object not init properly.
Ok,  I'll test one more time for BackgroundGeoLocation object  ( there is so much forked plugin's :)  )
May I sound one wishes?
Background plugins for geolocations and for background task are very needed in common programming tasks - may Your team test and provide two plugins (geo and for tasks) as core plugins for XDK with testing and well know behaviour ?
For geolocation background may use this navis plugin (He builds fine w/o errors and works in Android and iOS)
