Software Archive
Read-only legacy content
17060 Discussions
NFS setup issue
jphalimi
I am setting up a Xeon Phi card. Everything works just fine, but for some reason I can't have the nfs to be setup correctly. I am stuck at some point in the README tutorial (this one: http://registrationcenter.intel.com/irc_nas/3407/readme-en.txt). In section 7.6, the tutorial gives the following rules:
b) Set up micuser
   user_prompt> sudo useradd -U -m -u 400 micuser
   user_prompt> sudo groupmod -g 400 micuser
These lines give me the following errors:
useradd: Invalid numeric argument `-m' for `-U'.
I am using SUSE 11 SP2. I could manage to create a micuser using my own useradd command but I am not sure what these options are meaning. Can someone help me?
Thank you for your time,
jphalimi
Ok I just figured out what was wrong. The problem is SUSE which  does not feature a built-in-bash useradd command, therefore using other the appropriate command parameters.
jphalimi
