Software Archive
Read-only legacy content
17060 Discussions
Named user Fortran license error
Brian_H_
I have a named-user license for Intel Fortran that used to work, but is now giving me the error message copied below when I try to compile.
I had to do an offline installation of my license because my company is behind a proxy that requires a password, and the Intel Software Manager doesn't allow me to enter a proxy password.
I'm not sure what changed that let to the errors.  I am using the same computer, so my license file shouldn't need to be updated as far as I can tell.  Any help would be greatly appreciated.
1>Compiling with Intel(R) Visual Fortran Compiler 16.0 [IA-32]...
1>hello.f90
1>Error: A license for Comp-FW is not available now (-15,10,10061).
1>A connection to the license server could not be made.  You should
1>make sure that your license daemon process is running: both an
1>lmgrd.exe process and an INTEL.exe process should be running
1>if your license limits you to a specified number of licenses in use
1>at a time.  Also, check to see if the wrong port@host or the wrong
1>license file is being used, or if the port or hostname in the license
1>file has changed.
1>License file(s) used were (in this order):
1>    1.  Trusted Storage
1>    2.  C:\Program Files (x86)\Common Files\Intel\Licenses\COM_W__FOR_XXXX-XXXXXXXX.lic
1>    3.  C:\Program Files (x86)\Common Files\Intel\Licenses\USE_SERVER.lic
1>    4.  C:\Program Files\Common Files\Intel\Licenses
1>    5.  C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016\windows\bin\ia32\*.lic
1>Please visit http://software.intel.com/sites/support/ if you require technical assistance.
1>ifort: error #10052: could not checkout FLEXlm license
Alexandra_S_Intel
Great, glad to hear it!
Since your issue has been resolved, I'm going to close this thread; anyone who has a related question should create a new thread.
- Alex
