Software Archive
Read-only legacy content
17060 Discussions
New Version 1995 debug not working
Nick_F_2
New Contributor III
I have an iPhone IOS 8.3 attached to my Mac. I have App Preview installed.
In the new Debug tab I configure the provisioning profile and P12 file. The application compiles and is saved locally as <appname>.ipa.
I then get an error that says Error Encountered while installing signed App Preview onto your device.Suggestion Retry.
Then it tells me it cannot find a signed version of App Preview on my device, when I check it has been deleted.
Tried 4 times now. Installed App Preview and each time it is deleted.
Nick_F_2
New Contributor III
Even trying to install the new ipa file via iTunes it says installing but never installs.
This is very frustrating as I have to reinstall App Preview again and again to be able to test via Push Files on the test tab. Why is Debug deleting App Preview every time.
The original Debug was so much easier to use with an attached device, it loaded up App Preview and push the files I could fire up the debug console and all was good. This new version is unusable in its current form.
I have removed 1995 and gone back to 1912 for now.
Nick_F_2
New Contributor III
Just reinstalled version 1912 but I still have the same debug issues not had previous to installing 1995
Brandon_K_Intel
It sounds like you haven't added your Device's UDID to your provisioning profile from the behavior you described. I get the same behavior from the XDK when I don't include the current UDID to my provisioning profile. I understand that you had this working with the previous version and that should have allowed it to work with this version. Would you please try regenerating your p12 and provisioning profile and try to run the debugger again?
Nick_F_2
New Contributor III
It is the same provisioning profile I use when compiling my applications. They work fine and compile fine and run fine.
Brandon_K_Intel
The generation process for this provisioning profile/certificate combination is slightly different than the process for generating a certificate for your other applications. You are generating a development certificate and provisioning profile which are used to sign and install app preview. Please go through the process of regenerating these and let me know if you have any issues with it.
Nick_F_2
New Contributor III
Trying to go through this process but when trying to get help via XDK I get the attached screen.
Brandon_K_Intel
What operating system do you have the XDK installed on?
Nick_F_2
New Contributor III
Hi Brandon
I have finally got this to work.
I am running on OS X 10.10.3 Macbook Air i7 with 8GB RAM.
