Software Archive
Read-only legacy content
17060 Discussions
Not local AJAX POST doesn't work
Fatih_Mert_D_
Hi guys,
I new started work with Intel XDK. I like it. But I couldn't ajax post to my web site.
Backend (I'm using FlightPHP micro framework for php)
<?php
Flight::route("POST /islem/mobil",function(){
	$data = array();
	$isim = (string)$_POST['isim'];
	$sisim = (string)$_POST['sisim'];
	$data['yanit'] = $isim." ".$sisim;
	echo json_encode($data);
Frontend
$(document).ready(function(){
    $('.ajaxPost').click(function(){
        var veri = {
            "isim" : $('.getIsim').val(),
            "sisim" : $('.getSoyIsim').val()
        $.ajax({
            url: "http://be-vel.com/islem/mobil",
            dataType:"JSON",
            type:"POST",
            data:veri,
            success: function(cvp){
                $('.sonucYaz').text(cvp.yanit);
Where is the error, I don't understand this, because anything show me errors :/
Thank you for interest.
Good works..
PaulF_IntelCorp
How are you testing this? In the Emulate tab? In the Debug tab? In a built app on a device?
Fatih_Mert_D_
I'm trying on Emulate tab.
PaulF_IntelCorp
Does it work for you if you just use a desktop browser? Make sure it all works there, outside the XDK, first. What you are trying to do is not specific to the XDK, it has to do with making your connection between your client browser and your server work. Once you have that connection working correctly, using a browser, then you should be able to move it to a Cordova app, using the XDK.
Fatih_Mert_D_
How do I try on my browser ? I don't know sorry.
Because, node-webkit doesn't like firebug.
Thank you..
Diego_Calp
Valued Contributor I
Thank you..
Hi, emulate tab has its own debugger, second button top left.
Into debugger, you should see errors in Network section.
Diego
PaulF_IntelCorp
Faith, to try in a browser, just open the index.html file in your project in a browser...
PaulF_IntelCorp
This issue with our iOS build system has been resolved, please try again. See > https://software.intel.com/en-us/forums/intel-xdk/topic/611793
