I have the error message: offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)
Compiler flags:
icc $(SOURCES) -lOpenCL -fopenmp -O3
Offload code:
void Convolution_Serial_Offload_ExplicitMemCopy(float * pInput, float * pFilter, float * pOutput,
const int nInWidth, const int nWidth, const int nHeight,
const int nFilterWidth)
#pragma offload target(mic) in(pInput:length(nInWidth*nInWidth)) in(pFilter:length(nFilterWidth*nFilterWidth)) inout(pOutput:length(nWidth*nHeight))
//explict copying of data from host to MIC at start
for (int yOut = 0; yOut < nHeight; yOut++)
const int yInTopLeft = yOut;
for (int xOut = 0; xOut < nWidth; xOut++)
const int xInTopLeft = xOut;
float sum = 0;
for (int r = 0; r < nFilterWidth; r++)
const int idxFtmp = r * nFilterWidth;
const int yIn = yInTopLeft + r;
const int idxIntmp = yIn * nInWidth + xInTopLeft;
#pragma ivdep //discards any data dependencies assumed by compiler
#pragma vector aligned //all data accessed in the loop is properly aligned
for (int c = 0; c < nFilterWidth; c++)
const int idxF = idxFtmp + c;
const int idxIn = idxIntmp + c;
sum += pFilter[idxF]*pInput[idxIn];
const int idxOut = yOut * nWidth + xOut;
pOutput[idxOut] = sum;
//end MIC offload: explict copying of data from MIC to host at finish
What could be the problem when I call this function from host?
Dave
This looks like it is the same alignment issue as in http://software.intel.com/en-us/comment/1785377. If there is something else going on here that needs to be looked at, please let us know.
