Software Archive
Read-only legacy content
17060 Discussions
Offload example in fortran
vincent_b_
I'm trying this simple fortran offload example and I don't understand why it gives me this error :
main_offload1.f90(26): warning #8535: A procedure called in an OFFLOAD region must have the OFFLOAD:TARGET attribute.   [SQUAROOT]
        call squaroot(a,b,c,N)
main_offload1.f90(26): warning #8535: *MIC* A procedure called in an OFFLOAD region must have the OFFLOAD:TARGET attribute.   [SQUAROOT]
Here is the code:
!dir$ attributes offload:mic :: squaroot
        SUBROUTINE squaroot(a,b,c,N)
        REAL, DIMENSION(N,N) :: a, b, c
        INTEGER :: N
        DO j = 1, N
                DO i = 1, N
                        a(i,j) = SQRT( b(i,j) * c(i,j) )
                        write (*,*) a(i,j)
                END DO
        END DO
        END
        PROGRAM MAIN
!dir$ attributes offload:mic ::   a, b, c
        REAL, DIMENSION(:,:), ALLOCATABLE :: a, b, c
        INTEGER :: N
        N = 10
        ALLOCATE (a(N,N), b(N,N), c(N,N))
        DO j = 1, N
                DO i = 1, N
                        c(i,j) = (i+j*N)
                        b(i,j) = c(i,j)
                END DO
        END DO
!dir$ offload target(mic) in(a,b:length(N*N)) inout(c:length(N*N))
        DEALLOCATE (a,b,c)
        END
Thanks you.
Kevin_D_Intel
You must to declare the routine used within the offload region both at the point of definition and within the scope used. So, in the main program scope, add squaroot to attributes directive you already have.
vincent_b_
Thank you Kevin.
That works.
