Software Archive
Read-only legacy content
17060 Discussions
Offload problem
natapon_p_
I am very new to Intel Xeon/Phi. I have tried to do programming with the card on Ubuntu 16.04. I have successfully installed MPSS and run the native program. However, when I tried to run as offload method. It's failed.
The error message is
The remote process indicated that the following libraries could not be loaded:    libiomp5.so liboffload.so.5 libcilkrts.so.5
offload error: cannot start process on the device 0 (error code 19)
I have NFS mount /opt/intel... with the card and also set LD_LIBRARY_PATH to the libraries folder.
What should I do to solve this problem?
Sebastian_S_Intel
as you probably know Ubuntu is not one of supported operating systems so probably no one did the experiment.
The full list of supported OSs can be found here: https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss
I'd try to examine MIC_LD_LIBRARY_PATH.
Sebastian
