Software Archive
Read-only legacy content
17060 Discussions
Offloading 2d arrays in C/C++ using pragmas - problems
james_B_8
I'm trying to offload a dynamically allocated 2d array of floats. I can't seem to get it to work however. My code is this:
[cpp]
#include <stdio.h>
#include <stdlib.h>
float **alloc_2d(int rows, int cols);
void dealloc_2d(float **array, int rows);
int main()
    /* array size */
    const int d1 = 10;
    const int d2 = 10;
    /* malloc some 2d c arrays */
    float **x;
    x = alloc_2d(d1,d2);
    /* assign some values to them */
    int i,j;
    for (i=0; i<d1; i++)
        for (j=0; j<d2; j++)
            x = i*j;
    printf("x[0][0] = %f\n", x[0][0]);
    /* offload to the mic and check value there */
#pragma offload target(mic:0) in( x[0:d1][0:d2] : alloc( x[0:d1][0:d2] ) )
    dealloc_2d(x, d1);
    return 0;
    float **array;
    array = malloc( rows * sizeof *array );
    int i;
    for (i=0; i<rows; i++)
        array = malloc( cols * sizeof *array );
    return array;
    int i;
        free(array);
    free(array);
[/cpp]
I compile with icc main.c and I get the error:
": internal error: backend signals
compilation aborted for main.c (code 4)
What's the correct way to offload multidimensional arrays in C/C++? Would it be wiser to just store my data as a 1D array and compute the memory locations manually?
Frances_R_Intel
Yes. You cannot offload a pointer to a point with a #pragma offload directive. The best solution is malloc a single block of memory and set up the pointers later. You will need an array of pointers on the host and a separate one on the coprocessor because the actual addresses will be different.
james_B_8
Good. Thanks for confirming that for me.
