Software Archive
Read-only legacy content
17060 Discussions
Offloading virtual functions?
Sanchit_Misra
Hi, Can we offload virtual functions. I am trying to do that using the following code and I am getting seg fault. #include using namespace std; class Polygon { public: #pragma offload_attribute(push, target(mic)) virtual int area (int width, int height) { return 0; } #pragma offload_attribute(pop) int area_wrapper (int width, int height) { int c; #pragma offload target(mic:0) \ in(width, height) \ out(c) { c = this->area(width, height); } return c; } }; class Rectangle: public Polygon { public: #pragma offload_attribute(push, target(mic)) int area (int width, int height) { return width * height; } #pragma offload_attribute(pop) }; class Triangle: public Polygon { public: #pragma offload_attribute(push, target(mic)) int area (int width, int height) { return (width * height / 2); } #pragma offload_attribute(pop) }; int main () { Rectangle * ppoly1 = new Rectangle(); Triangle * ppoly2 = new Triangle(); Polygon * ppoly3 = new Polygon(); cout << ppoly1->area_wrapper(4, 5) << '\n'; cout << ppoly2->area_wrapper(4, 5) << '\n'; cout << ppoly3->area_wrapper(4, 5) << '\n'; return 0; } When I compile and run it, it results in: $ icpc polygon.cpp $./a.out offload error: process on the device 0 was terminated by signal 11 (SIGSEGV) Thanks in advance, Sanchit
Kevin_D_Intel
I believe this may require using _Cilk_shared/_Cilk_offload. Let me inquire with others more knowledgeable.
Kevin_D_Intel
Our C++ Developer confirmed offloading virtual functions requires using _Cilk_shared/_Cilk_for and provided the modified version of your program shown below. The output of the modified program is:
$ icpc t_new.cpp
$ ./a.out
20
10
0
t_new.cpp
#include <iostream>
#include <offload.h>
#pragma offload_attribute(push, _Cilk_shared)
class Polygon {
public:
      return 0;
      int c;
      c = _Cilk_offload this->area(width, height);
      return c;
   public:
   public:
int main ()
   Rectangle * ppoly1 = new (_Offload_shared_malloc(sizeof(Rectangle))) Rectangle();
   Triangle * ppoly2 = new (_Offload_shared_malloc(sizeof(Triangle))) Triangle();
   Polygon * ppoly3 = new (_Offload_shared_malloc(sizeof(Polygon))) Polygon();
   return 0;
Sanchit_Misra
Thanks Kevin!
Will it hurt the performance to have a class instance in virtual shared memory between CPU and MIC using _Offload_shared_malloc(); especially if that class instance is accessed in critical section?
--Sanchit
Kevin_D_Intel
Hi Sanchit - Sorry, we are not clear about your question.
Does "critical section" mean a section of code critical to the code's performance? Or a code section guarded in some fashion for critical or exclusive access?
Or are you asking whether shared memory access is dramatically slower than non-shared memory and will having class objects in shared memory whose access is critical to the code's performance hurt overall performance?
