Software Archive
Read-only legacy content
17060 Discussions
OpenGL image to bitmap file
ssf
I have a Windows openGL application for display of offshore structures and I want to give users the option to save an image as a bitmap file for use in other applications.
Quickwin offers this option in SAVEIMAGE and SAVEIMAGE_W, but the simple option is not present in a Windows application. Several CVF samples shows how to read a bitmap file, but no examples show how to save a bitmap file.
I would appreciate to se a code example showing the steps to perform to save an openGL image (an other windows images) as a bitmap file.
Regards Soren Fredsgaard
(I tried to post this message on december 29, but it has not appeared on the message board)
ssf
I have now solved my problem. The attached subroutine SAVEBMI will save a bitmapimage in a bitmap file if the bitmap uses 24 or 32 bit colors. I hope it will be usefull for others.
subroutine SAVEBMI(hDC,bmfu,bmfnam,retcod)
!-- Save bitmapimage in a Windows bitmap file (bmp)
    use dfwina
    use dfopngl
    implicit none
    integer(4)    hDC    !handle to device context
    integer(4)    bmfu   !file unit for bitmap file
    character*(*) bmfnam !file name for bitmap file
    integer(4)    retcod !return code:
                         != 0, unsupported display, bitmap not saved
                         !> 0, bitmap saved (file size in bytes returned)
    type(T_BITMAPFILEHEADER) bmfh
    type(T_BITMAPINFOHEADER) bmih
    type(T_BITMAP)           bm
    integer(4)  hbmComp,hbmold,hdcComp,retint
    integer(4)  vp(4),width,height,ppix,ppiy,bmsize,rdim,rdimdw,rdimbm
    integer(4)  ih,iw,jw,kw
    integer(1), allocatable :: bmbits(:,:),bmrow(:)
!-- Get dimensions of ViewPort and allocate arrays for bitmap bits
    call fglGetIntegerv_array(GL_VIEWPORT,vp)
    width  = vp(3)
    height = vp(4)
    bmsize = width*height*3
    rdim   = width*3        !bitmap file always saved as 24 bit bitmap
    rdimdw = rdim           !row dimension ending on a dword boundary
    if (MOD(rdimdw,4) .ne. 0) rdimdw = rdimdw+4-MOD(rdimdw,4)
!-- Get pixel information
    ppix = GetDeviceCaps(hDC,LOGPIXELSX)  !no of pixels/inch, x-dir
    ppiy = GetDeviceCaps(hDC,LOGPIXELSY)  !no of pixels/inch, y-dir
!-- Create compatible DC and get bitmap
    hdcComp = CreateCompatibleDC(hDC)
    hbmComp = CreateCompatibleBitmap(hDC,Width,Height)
    hbmold  = SelectObject(hdcComp,hbmComp)
    retint  = BitBlt(hdcComp,0,0,width,height,hDC,0,0,SRCCOPY)
    retint  = GetObject(hbmComp,24,LOC(bm))
    if (bm%bmBitsPixel .eq. 24) then
        rdimbm = rdim       !row dimension ending on a word boundary
        if (MOD(rdimbm,2) .ne. 0) rdimbm = rdimbm+1
    else if (bm%bmBitsPixel .eq. 32) then
        rdimbm  = width*4
    else
        retint = MessageBox(NULL,'Display properties not supported, bitmap not saved'C, &
                           'RosaGL message'C,MB_OK+MB_ICONEXCLAMATION)
        retcod = 0
        go to 900
    end if
    allocate(bmbits(rdimbm,height))
    retint  = GetBitmapBits(hbmComp,rdimbm*height,LOC(bmbits))
!-- Create bitmap file header
    bmfh%bfType          = 'BM'
    bmfh%bfSize          = SIZEOF(bmfh)+SIZEOF(bmih)+rdimdw*height
    bmfh%bfReserved1     = 0
    bmfh%bfReserved2     = 0
    bmfh%bfOffBits       = SIZEOF(bmfh)+SIZEOF(bmih)
!-- Create bitmap info header
    bmih%biSize          = SIZEOF(bmih)
    bmih%biWidth         = width
    bmih%biHeight        = height
    bmih%biPlanes        = bm%bmPlanes
    bmih%biBitCount      = MIN(24,bm%bmBitsPixel)
    bmih%biCompression   = BI_RGB
    bmih%biSizeImage     = rdimdw*height
    bmih%biXPelsPerMeter = NINT(ppix/0.0254)   !(1 inch = 0.0254 m)
    bmih%biYPelsPerMeter = NINT(ppiy/0.0254)   !(1 inch = 0.0254 m)
    bmih%biClrUsed       = 0
    bmih%biClrImportant  = 0
!-- Open file for bitmap
    open(unit=bmfu,file=bmfnam,access='sequential',status='unknown',form='binary')
!-- Save
 bitmap
    allocate(bmrow(rdimdw))
    bmrow  = 0
    write(bmfu) bmfh,bmih
    do ih=height,1,-1
          bmrow(1:rdimbm) = bmbits(:,ih)
      else
          jw = 1
          kw = 1
          do iw=1,width
            bmrow(jw:jw+2) = bmbits(kw:kw+2,ih)
            jw = jw+3
            kw = kw+4
          end do
      end if
      write(bmfu)
I edited your response to add PRE tags so that the source appeared properly. There seems to be source lines missing at the end, though...
Steve
Intel_C_Intel
Steve,
Could you add [font size='+0'] tags inside the
tags? The code will be more readable. Then if we just had the last few lines .... :-)
Feel free to remove this message afterwards to eliminate clutter.
-John
Intel_C_Intel
I'm writing a graphics post-processor at the moment, and I'd love to be able to save bitmaps. I've tried incorporating the above code, but something seems to be missing (apart from the obvious). Was the full version ever posted?? or has anyone got a better way of doing it?
all the best
Steve Brown
Intel_C_Intel
OK
I've worked out the obvious missing piece myself
do ih=height,1,-1
else
jw = 1
kw = 1
do iw=1,width
jw = jw+3
kw = kw+4
end do
end if
write(bmfu) bmrow
end do
close(unit=bmfu)
900 end
works for me
thanks
Steve
kvrichardson
Wow...thanks for that code. Works beautifully for my CREATE SCREENSHOT button in my troubleshooting area. I just had to put in my own width and height data (you call your own subroutine in your code for that, I believe).
Thanks!!!
Keith Richardson
