Software Archive
Read-only legacy content
17060 Discussions
OpenMP Tasks + Offload possible?
ds534486
when I offload a parallel region, my OpenMP tasks are not executed, is this intended?
The example below gives no output as it is, it seems the tasks are created but not executed. If I omit the offload or the task pragma, I get the expected result. Any idea what I am doing wrong?
Dirk
Example:
int main(){
#pragma offload target(mic)
#pragma omp parallel
#pragma omp task
printf("Hello World!\n");
return 0;
TimP
This question would be more likely to get a reply on the appropriate forum: http://software.intel.com/en-us/forums/intel-many-integrated-core
ds534486
Thanks for the hint, I moved the thread as you suggested. Dirk
Kevin_D_Intel
You have not done anything wrong. There is currently a defect with using omp task inside an offload region that is expected to be fixed in the next update release tentatively scheduled for late January. I confirmed your program runs correctly with a newer (internal-only) build of the compiler.
ds534486
Thanks for the information. I will wait for the compiler update then. Dirk
Kevin_D_Intel
I confirmed this defect is fixed in the Intel Fortran Composer XE 2013 Update 2 (2013.1.146 - Linux) now available for download from the Intel Registration Center (https://registrationcenter.intel.com)
