Software Archive
Read-only legacy content
17060 Discussions
OpenMP Tasks not working.
minimax2000
Hello
The following simple example does not work on my OS. I am evaluating the Parallel Studio.
The project properties have OpenMP enabled.
My OS is Vista x64 and the Composer is integrated into VS 2005 Academic Edition.
After starting the console application it goes into an infinite loop forcing me to reboot the OS.
It seems that no synchronisation points (taskwait) and termination conditions are considered.
Any tips on how to solve the issue are welcome.
Frank
#include "stdafx.h"
#include
#include
int fib(int n)
int i, j;
_RPTF1(_CRT_WARN, "Fib no = %d\n", n);
if (n<2)
return n;
else
#pragma omp task shared(i)
i=fib(n-1);
#pragma omp task shared(j)
j=fib(n-2);
#pragma omp taskwait
return i+j;
int _tmain(int argc, _TCHAR* argv[])
#pragma omp parallel
#pragma omp single
fib(20);
return 0;
Hubert_H_Intel
Frank,
I don't see a problem with your code. However, I don't have a Visual Studio* 2005 Academic version available right now; I builtthe code onVisual Studio* 2008 Team SuiteEdition under Vista x64, but I don't think that this makes a difference.
Which is your Composer version? The neweset is Intel Parallel Composer Update 1.063 (in the Visual Studio About dialog).
Could youcheck if the path to the Intel libraries (including the Intel OpenMP* runtime library libiomp5md.dll) is set correctly (look at: Tools -> Options -> Intel Parallel Composer -> Compilers). It should be(default): C:Program Files (x86)IntelParallel StudioComposerlibintel64 Regards,
Hubert.
minimax2000
Frank,
Hubert.
Hello Hubert, thanks for your reply. I will check this as soon as I am at home. Furthermore I will install the Composer on my Windows XP 32-bit system and check how the application behaves there. Frank
Hubert_H_Intel
Frank,
I don't see a problem on Windows XP* 32-bit under Visual Studio* 2005 or 2008 either.
You may have a look at the OpenMP* features of the Parallel Composer, the Intel Parallel Debugger Extension. In debug mode you will see a couple of OpenMP windows active (tasks, locks, barriers, teams, taskwaits).
Under Visual Studio 2005 you need to enable the exceptions manually, due to a technical restriction that cannot be solved:
Select Debug > Exceptions, expand the Win32 Exceptions tree, and enable items:
a1a01db0 Intel Parallel Debugger Extension Exception 0
a1a01db1 Intel Parallel Debugger Extension Exception 1
a1a01db2 Intel Parallel Debugger Extension Exception 2
This needs to be done once per project.
Hubert.
minimax2000
Hello Hubert
Please find below my configuration.
Moreover the dependency walker reported some errors:
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Error: Modules with different CPU types were found.
Please have a look at the attachments.
Thanks for your time.
Frank
Microsoft Visual Studio 2005
Version 8.0.50727.867 (vsvista.050727-8600)
Microsoft .NET Framework
Version 2.0.50727 SP2
Installed Edition: Standard
Microsoft Visual C++ 2005
Intel Parallel Composer Update 1 (Package ID: composer_update1.063), Copyright 2002-2009 Intel Corporation
Microsoft Visual Studio 2005 Standard Edition - ENU Service Pack 1 (KB926601)
This service pack is for Microsoft Visual Studio 2005 Standard Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/926601
Update for Microsoft Visual Studio 2005 Standard Edition - ENU (KB932232)
This Update is for Microsoft Visual Studio 2005 Standard Edition - ENU.
If you later install a more recent service pack, this Update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/932232
minimax2000
Hello
On Windows XP 32-bit the same project runs correctly. Results are correct too. Dependency walker reported no errors.
Frank
Quoting - minimax2000
minimax2000
Hi
I have some news. If I disable my firewall the debugger can connect to the win32 and x64 version of my application.
Otherwise I get an error message that the debugger cannot connect to the remote computer when trying to debug the x64 version. But what baffles me is that I want to debug locally and not remotely.
This thread covers the same problem.
So what settings of my firewall do I have to enable to get this working? I don't want to turn off my firewall during debug sessions. I have NetBios disabled by the way.
Frank
Hubert_H_Intel
Frank,
You can of course locally debug your application by choosing the local debugger instead of remote.
Project Properties -> Configuration Properties -> Debugging -> Choose 'Local Windows Debugger' from the Debugger to launch: drop-down menu.
Hubert.
