Software Archive
Read-only legacy content
17060 Discussions
OpenMPI Segmentation Fault at runtime using Intel XE 2011 SP1
albertofalzone
trying to use OpenMPI 1.2.8 and higher version as such as 1.4.1, 1.4.2 (but also with 1.4.3) with Intel Parallel Studio XE 2011 SP1 released in Sep 2011, after successfully build (with the same Intel compiler) and installation, running the simple command mpicc -V I got a "Segmentation fault" error message.
No change also setting the stack size to unlimited value.
Also, all OFED layer has been rebuilt with the same compiler in order have aligned the binaries of libverbs and so on, but the behaviour was the same.
In addiction, shutting down the openibd service, the simple command works, and starting the service again, I got the segmentation fault.
Other MPI flavors does not present this issue, i.e. mvapich , mvapich2.
For what reason I got this error message with OpenMPI ?
Is there an OpenMPI version that is Intel 2011 SP1 (12.1.0.233) compliant ?
Below a dump of strace command hoping that can help to evaluate this issue:
[root@cresco2x015 ~]# icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
[root@cresco2x015 ~]# which icc
/opt/intel12/composer_xe_2011_sp1.6.233/bin/intel64/icc
[root@cresco2x015 ~]# which mpicc
/usr/mpi/intel/openmpi-1.4.1/bin/mpicc
[root@cresco2x015 ~]# mpicc -V
Segmentation fault
[root@cresco2x015 ~]# strace mpicc -V
execve("/usr/mpi/intel/openmpi-1.4.1/bin/mpicc", ["mpicc", "-V"], [/* 38 vars */]) = 0
brk(0) = 0x181f5000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3764e93000
uname({sys="Linux", node="cresco2x015.portici.enea.it", ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3764e94000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/usr/mpi/intel/openmpi-1.4.1/lib64/tls/x86_64/libopen-pal.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/mpi/intel/openmpi-1.4.1/lib64/tls/x86_64", 0x7fff2199e7b0) = -1 ENOENT (No such file or directory)
open("/usr/mpi/intel/openmpi-1.4.1/lib64/tls/libopen-pal.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/mpi/intel/openmpi-1.4.1/lib64/tls", 0x7fff2199e7b0) = -1 ENOENT (No such file or directory)
open("/usr/mpi/intel/openmpi-1.4.1/lib64/x86_64/libopen-pal.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/usr/mpi/intel/openmpi-1.4.1/lib64/x86_64", 0x7fff2199e7b0) = -1 ENOENT (No such file or directory)
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libopen-pal.so.0", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\300\\345\\0\\0\\0\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1198231, ...}) = 0
mmap(NULL, 2706888, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b3764e95000
mprotect(0x2b3764f04000, 2093056, PROT_NONE) = 0
mmap(0x2b3765103000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6e000) = 0x2b3765103000
mmap(0x2b3765107000, 142792, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b3765107000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64", {st_mode=S_IFDIR|0755, st_size=8192, ...}) = 0
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/gcc433/lib64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/gcc433/lib64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/gcc433/lib64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/gcc433/lib64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/gcc433/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/hypre/lib/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/hypre/lib/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/hypre/lib/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/hypre/lib/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/hypre/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/libsbml/lib/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/libsbml/lib/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/libsbml/lib/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/libsbml/lib/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/libsbml/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/tls/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/tls/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/tls/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/tls", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/x86_64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/x86_64", 0x7fff2199e780) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=213932, ...}) = 0
mmap(NULL, 213932, PROT_READ, MAP_PRIVATE, 3, 0) = 0x2b376512a000
close(3) = 0
open("/lib64/libdl.so.2", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\20\\16 \\2029\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=23360, ...}) = 0
mmap(0x3982200000, 2109696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x3982200000
mprotect(0x3982202000, 2097152, PROT_NONE) = 0
mmap(0x3982402000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x3982402000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib64/libnsl.so.1", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\240@\\200\\2149\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=114352, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b376515f000
mmap(0x398c800000, 2194096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x398c800000
mprotect(0x398c815000, 2093056, PROT_NONE) = 0
mmap(0x398ca14000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x398ca14000
mmap(0x398ca16000, 6832, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x398ca16000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libutil.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib64/libutil.so.1", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\200\\16`\\2219\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=18152, ...}) = 0
mmap(0x3991600000, 2105616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x3991600000
mprotect(0x3991602000, 2093056, PROT_NONE) = 0
mmap(0x3991801000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x3991801000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib64/libm.so.6", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0`>\\340\\2019\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=615136, ...}) = 0
mmap(0x3981e00000, 2629848, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x3981e00000
mprotect(0x3981e82000, 2093056, PROT_NONE) = 0
mmap(0x3982081000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x81000) = 0x3982081000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0`'\\0\\0\\0\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=478623, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3765160000
mmap(NULL, 2188824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b3765161000
mprotect(0x2b3765177000, 2097152, PROT_NONE) = 0
mmap(0x2b3765377000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x2b3765377000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib64/libpthread.so.0", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\200W`\\2029\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=145592, ...}) = 0
mmap(0x3982600000, 2204528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x3982600000
mprotect(0x3982616000, 2093056, PROT_NONE) = 0
mmap(0x3982815000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x3982815000
mmap(0x3982817000, 13168, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x3982817000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/../compiler/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/ipp/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/tbb/lib/intel64//cc4.1.0_libc2.4_kernel2.6.16.21/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/gcc433/lib64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/hypre/lib/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/libsbml/lib/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/x86_64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("tls/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("x86_64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/debugger/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/mpirt/lib/intel64/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib64/libc.so.6", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0p\\332\\241\\2019\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1713160, ...}) = 0
mmap(0x3981a00000, 3494168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x3981a00000
mprotect(0x3981b4c000, 2097152, PROT_NONE) = 0
mmap(0x3981d4c000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14c000) = 0x3981d4c000
mmap(0x3981d51000, 16664, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x3981d51000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libimf.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libimf.so", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\300\\301\\0\\0\\0\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=3152633, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3765378000
mmap(NULL, 3976400, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b3765379000
mprotect(0x2b3765600000, 1048576, PROT_NONE) = 0
mmap(0x2b3765700000, 278528, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x287000) = 0x2b3765700000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libsvml.so", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libsvml.so", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0\\240u\\1\\0\\0\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=7220500, ...}) = 0
mmap(NULL, 7810736, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b3765744000
mprotect(0x2b3765db5000, 1048576, PROT_NONE) = 0
mmap(0x2b3765eb5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x671000) = 0x2b3765eb5000
close(3) = 0
open("/usr/mpi/intel/openmpi-1.4.1/lib64/libintlc.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/opt/intel12/composer_xe_2011_sp1.6.233/compiler/lib/intel64/libintlc.so.5", O_RDONLY) = 3
read(3, "\\177ELF\\2\\1\\1\\0\\0\\0\\0\\0\\0\\0\\0\\0\\3\\0>\\0\\1\\0\\0\\0@p\\0\\0\\0\\0\\0\\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=295094, ...}) = 0
mmap(NULL, 1321856, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x2b3765eb7000
mprotect(0x2b3765ef7000, 1044480, PROT_NONE) = 0
mmap(0x2b3765ff6000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3f000) = 0x2b3765ff6000
mmap(0x2b3765ff9000, 2944, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2b3765ff9000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3765ffa000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2b3765ffb000
arch_prctl(ARCH_SET_FS, 0x2b3765ffb620) = 0
mprotect(0x3981d4c000, 16384, PROT_READ) = 0
mprotect(0x3982815000, 4096, PROT_READ) = 0
mprotect(0x3982081000, 4096, PROT_READ) = 0
mprotect(0x3991801000, 4096, PROT_READ) = 0
mprotect(0x398ca14000, 4096, PROT_READ) = 0
mprotect(0x3982402000, 4096, PROT_READ) = 0
mprotect(0x398181b000, 4096, PROT_READ) = 0
munmap(0x2b376512a000, 213932) = 0
set_tid_address(0x2b3765ffb6b0) = 23781
set_robust_list(0x2b3765ffb6c0, 0x18) = 0
futex(0x7fff2199f2dc, FUTEX_WAKE_PRIVATE, 1) = 0
rt_sigaction(SIGRTMIN, {0x3982605370, [], SA_RESTORER|SA_SIGINFO, 0x398260e4c0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x39826052b0, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x398260e4c0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=RLIM_INFINITY, rlim_max=RLIM_INFINITY}) = 0
stat("/sys/class/infiniband", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
Hubert_H_Intel
I didn't fully investigate your trace, but it sounds like being the same issuerecently found with the Intel Composer XE Update 6 (formerly known as SP1) and OpenMPI.
Please disable optimization for
mvapich2-1.7rc2/src/mpid/ch3/channels/common/src/memory/ptmalloc2/mvapich_malloc.c by adding
#pragma optimize("", off)
on top of the file. Let me know if this helps.
Regards, Hubert
hlrs
Dear Hubert,
well, this bug caused some headache on my side: running any Open MPI binary compiled intel v12.1 on a linux x86-64 machine SEGFAULTED in ptmalloc2's code in opal/mca/memory/linux/malloc.c:
[c++]/* remove from unsorted list */
unsorted_chunks(av)->bk = bck;
bck->fd = unsorted_chunks(av);[/c++]
Your reply came just in time ,-]
Inserting the #pragma optimize("", off) fixed this.
FYI, this has been commited to ompi-trunk and will be moved to Open MPI v1.5 (https://svn.open-mpi.org/trac/ompi/ticket/2883).
Hubert_H_Intel
Thanks for feedback. This is a bug in the vectorizer of the 12.1 compiler and will be fixed in one of the next releases. Until the bugfix is implemented you need to applythis workaround.
Regards, Hubert.
larry-baker
I started to look at adding a test for the Intel compiler version around the #pragma that disables optimization for OpenMPI and I found the __ICC and__INTEL_COMPILER predefined macros (compiler version no.) are not properly defined:
$ icc -E -dD hello.c | grep __INTEL_COMPILER
#define __INTEL_COMPILER 9999
#define __INTEL_COMPILER_BUILD_DATE 20110811
$ icc -E -dD hello.c | grep __ICC
#define __ICC 9999
$ icc -v
icc version 12.1.0 (gcc version 4.1.2 compatibility)
Hubert_H_Intel
The build date is currently the only suitable macro.This allows to check for the Intel Compiler and for specific compiler versions. Makes sense? Regards, Hubert.
larry-baker
This is a bug, right?
The 12.1 compiler documentation athttp://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/2011Update/cpp/lin/index.htm says __ICC and__INTEL_COMPILER are predefined compiler version no. macros.
For the previous compiler releases I have, they sort of are (you cannot distinguish the last point release from the macros -- also a bug, I think):
Version 11.1
#define __ICC 1110
#define __INTEL_COMPILER 1110
#define __INTEL_COMPILER_BUILD_DATE 20101201
Version 12.0.3
#define __ICC 1200
#define __INTEL_COMPILER 1200
#define __INTEL_COMPILER_BUILD_DATE 20110309
Version 12.0.4
#define __ICC 1200
#define __INTEL_COMPILER_BUILD_DATE 20110427
Version 12.0.5
#define __ICC 1200
#define __INTEL_COMPILER_BUILD_DATE 20110719
While for the 12.1.0 compiler release, they are nonsense (9999):
#define __ICC 9999
Has this bug already been reported? Either the documentation needs to be fixed, or the macros need to be fixed. They can't both be correct the way they are now.
Hubert_H_Intel
Yes, it's a bug that will be fixed in the next upcoming compiler release. Regards, Hubert.
