Software Archive
Read-only legacy content
17060 Discussions
Orientation doesnt work on iOS
Leo_N_Ng_
My game worked well with Android exported. Then I exported it to iOS, everythings is good except Orientation . I tried to change the Build option and added all Plugins to my project but It didnt work. I also put the code "intel.xdk.device.setRotateOrientation("landscape");" to everywhere of my source file without working. Im making game by Contruct 2 software. Every else exporters dont work well with my game. I can use only XDK. I tested my game on iPhone 5  OS 8. Please help me to fix this issue. Thank you.
PaulF_IntelCorp
Beginning with CLI 5, another solution is to use the following preference in your intelxdk.config.additions.xml file:
<platform name="ios">
    <!-- so iPhone and iPad rotate freely (CLI 5.1.1 and above) -->
    <!-- values include "default", "landscape" and "portrait" -->
    <!-- "default" means "portrait" for iPhone and "free" for iPad -->
    <preference name="Orientation" value="all" />
</platform>
See https://cordova.apache.org/docs/en/5.1.1/config_ref/index.html for more information.
Leo_N_Ng_
Jason_C_4
Hi... :)
I wonder if my ios orientation symptom is the same: though I specify landscape via Intel Xdk [such as 1) 'build settings: orientation' and 2) 'launch icons and splash screens: orientation], I still get portrait on my ios device.
Will your kind lead to 'Intel XDK Orientation Sample' resolve my situation?  If so, can there be more explaination, since I'm a noob to patching code?  ;)  (Interestingly enough, phonegap-build does honor my landscape choice.)
Thx in advance.  :)  Jason
PaulF_IntelCorp
There is a known issue regarding iOS orientation and Cordova. An interim fix is available, see this forum thread: https://forums.html5dev-software.intel.com/viewtopic.php?f=29&t=7830#p31421
Jason_C_4
Thanks Paul for the helpful link.
Since my goal is to have 'landscape', should I use everything in their solution, except replace their solution of ' 'UIInterfaceOrientationPortrait' with 'UIInterfaceOrientationLandscapeRight'?
Special Regards... :)  Jason
PaulF_IntelCorp
You'll have to look up the names on the Apple developer site, I don't know what they are, off-hand. Also, the plugin referenced in this thread might help: https://forums.html5dev-software.intel.com/viewtopic.php?f=34&t=8974
PaulF_IntelCorp
</platform>
Romain_C_1
Do someone know if this problem has been solved ? And what to do ?
Thank you
Nhat_N_
It is solved. I'm using the lastest version of XDK, and never meet this problem again ^ ^
