Software Archive
Read-only legacy content
PXCMFaceConfiguration.RecognitionConfiguration.SetDatabaseBuffer(buffer);
Raja_R_
I am having a play with the sample Face Recognition application and I have read on these forums (and in the help documentation) that I am able to Set the Database Buffer at run-time so as to allow me to swap databases.
I have tried to use the following code:
            // Allocate the buffer to save the database
            PXCMFaceData.RecognitionModuleData recognitionModuleData = _faceData.QueryRecognitionModule();
            Int32 nBytes = recognitionModuleData.QueryDatabaseSize();
            Byte[] buffer = new Byte[nBytes];
            // Retrieve the database buffer
            recognitionModuleData.QueryDatabaseBuffer(buffer);
            // Save the buffer to a file
            // (NOTE: production software should use file encryption for privacy protection)
            File.WriteAllBytes(_faceDataReadWriter.FullPathToFiles + DatabaseFilename, buffer);
            _recognitionConfig.SetDatabaseBuffer(buffer);
However when the line to Set the Database Buffer is hit I get this error:
 {"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."}
Please advise as to what I need to do to be able to swap the database buffers at run time.
I am using 2016 R 2 of the SDK
Many thanks
R
Raja_R_
Anyone at Intel able to assist with this?
TIA
R
