Software Archive
Read-only legacy content
17060 Discussions
Parallel Studio via Eclipse ... how?
Rob_J_
Last night I installed Eclipse as a GUI front end to Parallel Studio. Despite this being a suggested configuration by Intel it apparently can't work because Parallel Studio is installed as root. Eclipse therefore isn't capable of seeing the directory or files at /opt/intel
Is there any know solution to this, or is CLI (eek!) the only usable option?
Rob_J_
Solved. I had already done what I thought should fix the problem:
chown root ~/Desktop/eclipse
but doing this simply set the original executable to root's ownership. I also needed to delete the desktop link and replace it, which then gave me a shortcut link also owned by root.
Linux. It's weird. And none of this was documented in
https://software.intel.com/en-us/get-started-with-cpp-compiler-18.0-for-linux-parallel-studio-xe-2018
