Software Archive
Read-only legacy content
17060 Discussions
Passing allocatable arrays
Intel_C_Intel
How do I pass allocatable arrays? The following code compiles in CVF version 6.6 on NT, but the array is not passed properly from the main routine to subroutine and back.
Eddie Breeveld
      module generator
       implicit none
       interface
         subroutine WZDMG(WZMPTR)
          double precision, allocatable :: WZMPTR(:)
         end subroutine
       end interface
      end module
ccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc
      program main
      use generator
      implicit none
      allocate(WZMPTR(1))
      wzmptr(1) = 8.7654d0
      print *,'1: Main', shape(WZMPTR), wzmptr(1)
      call WZDMG(WZMPTR)
      print *,'2: Main', shape(WZMPTR), wzmptr(1), wzmptr(99)
      stop
      end
      use generator
      implicit none
      print *,'1: wzdmg', shape(WZMPTR), wzmptr(1)
      allocate(WZMPTR(1000))
      WZMPTR(99) = 12.345d0
      print *,'2: wzdmg', shape(WZMPTR), wzmptr(1), wzmptr(99)
      return
      end
Jugoslav_Dujic
Valued Contributor II
That compiles? My CFV5.0D rightfully complains that dummy argument cannot be allocatable, as the standard says. You have to replace ALLOCATABLE attributes with POINTER attributes and it will work.
Also, note that you have a memory leak in the example -- wzmptr allocated in the PROGRAM can never be deallocated since its association with allocated memory is lost when it's allocated again in the subroutine.
Jugoslav
Intel_C_Intel
Great! Thanks Jugoslav
Eddie
Yes, it would compile in 6.6 - 6.6 partially implements a new Fortran 2000 feature called "Allocatable components of derived types" which also permits dummy arguments to be ALLOCATABLE. There are a number of bugs in the implementation, which is why we haven't documented it yet, though the next update will fix a lot of them.
Your source looks like it should be ok to me - I'll run it past our expert in this area to see what he thinks.
Steve
Intel_C_Intel
You can work around this problem till the next release by making WZMPTR assumed-shape in the interface block (i.e. get rid of the ALLOCATABLE attribute there) and declaring it to be a POINTER rather than ALLOCATABLE in the actual subroutine. You will also have to compile the debug version as this doesn't work in the release version. Of course if you implement this workaround you should comment these illegal declarations so that you can find them easily when CVF fixes the bug(s) you are working around. Probably you are better off making everything POINTERs for now.
rahzan
James or Steve or ...,
I have dang little experience using pointers in CVF.
Is there a complete example of how to pass allocatable array using pointers all within docuemented implementation of CVF6.6?
I especially cannot use the debug code since the compuations get too slow unoptimized.
