Software Archive
Read-only legacy content
17060 Discussions
Phi fails after a certain number of offload+alloc calls
Corey_P_
I have noticed what seems to be a bug when trying to run some code which makes a large(ish) number of offload calls. Too many offload (with alloc) calls over the entire program seems to be the problem, leading to a grinding halt (without error). I can replicate the problem with the code below, which just loops over a few thousand offload calls, allocating a very small amount of memory in each. The program stops dead after 1004 iterations, regardless of the upper limit on the loop, the size of the alloc, or any sleep time I put in the loop.
[cpp]int N = 5000;
int size = 100;
float mem = 0.0;
int i;
for ( i = 0; i < N; i++ )
   float *thing = (float *) malloc ( size*sizeof(float) );
   mem += size;
   #pragma offload_transfer target(mic:0) \\
      in ( thing : length(size) alloc_if(1) free_if(0) )
   printf ( "%d Size: %f Meg\\n", i, mem/(1024.0*1000) );
}[/cpp]
With the last few outputs before it halts in its tracks (without error, just a freeze):
[plain]1001 Size: 0.097852 Meg
1002 Size: 0.097949 Meg
1003 Size: 0.098047 Meg
1004 Size: 0.098145 Meg[/plain]
If I put a free_if(1) in the loop (meaning the memory is released when the offload has completed) then it runs perfectly fine, suggesting there is some upper limit on how many (not how much) offloaded memory blocks it can create, or how many host -> MIC indexes it can store.
Any insight into this is much appreciated. Perhaps there is a flag I can set somewhere for the number of offload allocs?
Kevin_D_Intel
I can reproduce this Corey. I reported this to Development (see tracking id below) and will post again when I know more.
(Internal tracking id: DPD200245684)
(Resolution Update on 11/06/2013): This defect is fixed in the MPSS 3.1 release (Oct. 2013) for Linux.
Ruibang_L_
We are suffering from a similar problem, does Intel has any follow up on this problem?
Kevin_D_Intel
For this particular issue, the MPSS Development team identified the root cause. As they described it: "The root cause is that the number of temp files being generated by COI is exceeding the number of allowable fd's in process, by default. i.e. since in the free_if(0) case at exactly 1005 iterations, is when the number of fd's plus the number of open /tmp/coi_procs/<card>/<pid>/.tmp files currently tracked by coi is at 1024."
They indicated increasing the limit for number of open files (ulimit -n) allows COI to continue generating temp files.
I verified to work around this issue one can modify the host file  ( /opt/intel/mic/coi/config/coi )  to add line 30 shown in the snippet below. This file is transferred to the card(s) under ( /etc/init.d/coi ). Where more than ~5000 threads are used, one must increase the open file limit accordingly. With the change shown below, I was able to run the test case where N=5000.
Snippet from (host file): /opt/intel/mic/coi/config/coi:
     30         ulimit -n 5120
     31         $coiexec $coiparams &
     32         echo_ok
An MPSS change will appear in a future release to increase the default limit on the # of open files and provide administrator configuration control of the limit.
Ruibang_L_
Thanks Kevin, it's helpful.
     30         ulimit -n 5120
     32         echo_ok
Kevin_D_Intel
The expected change to the COI configuration in MPSS is present in the latest MPSS 3.1 release (Oct. 2013) for Linux.
Details regarding the MPSS 3.1 for Linux are available at: http://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss#lx31rel
To confirm the change, under the card's OS, inspect the file /etc/init.d/coi that contains the following change:
dmax=10240        #max file descriptors per COI process
                           # linux default is 1024
