Software Archive
Read-only legacy content
17060 Discussions
Please Help cant install intel fortran 2016
mehdi_k_
Hi please help me
parallel_studio_xe_2016_update1
I need install Intel fortran compiler 2016 update 1 in linux ubuntu 16.04lts (ifort)
OK When i choiced 3 i install cluster whith intel fortran and its OK untill  (EXPIRED) my .lic
-i choice 4  activate by using a license file
1. Use existing license [default]
2. I want to activate my product using a serial number
3. I want to evaluate Intel(R) Parallel Studio XE 2016 Update 1 Cluster Edition
for Linux* or activate later (EXPIRED)
4. I want to activate by using a license file, or by using Intel(R) Software
License Manager
Activation completed successfully.
Press "Enter" key to continue:
IT DOSENT INTEL FORTRAN COMPILER !!!!!!!!!!!!!!!!!!!!!!!
Step 5 of 7 | Options > Pre-install Summary
Install location:
    /opt/intel
Component(s) selected:
    Intel(R) VTune(TM) Amplifier XE 2016 Update 1                          921MB
        Command line interface
        Sampling Driver kit
        Graphical user interface
    Intel(R) Inspector XE 2016 Update 1                                    316MB
    Intel(R) Advisor XE 2016 Update 1                                      586MB
    Intel(R) C++ Compiler 16.0 Update 1                                    455MB
        Intel C++ Compiler
    Intel(R) Math Kernel Library 11.3 Update 1                             1.9GB
        Intel MKL core libraries
        Intel(R) Xeon Phi(TM) coprocessor support
        Fortran 95 interfaces for BLAS and LAPACK
        GNU* Compiler Collection support
        Cluster support
    Intel(R) Integrated Performance Primitives 9.0 Update 1                1.5GB
        Intel IPP single-threaded libraries: General package
    Intel(R) Threading Building Blocks 4.4 Update 1                         82MB
        Intel TBB
    Intel(R) Data Analytics Acceleration Library 2016 Update 1             1.1GB
    Intel(R) Debugger for Heterogeneous Compute 2016 Update 1               22MB
        GNU* GDB 7.6 (Provided under GNU General Public License v3)
        libelfdwarf.so library and it's sources (Provided under GNU Lesser
General Public License)
    GNU* GDB 7.8                                                           139MB
        GDB Eclipse* Integration on Intel(R) 64 (Provided under Eclipse Public
License v.1.0)
        Source of GDB Eclipse* Integration (Provided under Eclipse Public
License v.1.0)
        GNU* GDB 7.8 on Intel(R) 64 (Provided under GNU General Public License
v3)
Install Space Required:  6.6GB
Driver parameters:
    Sampling driver install type: Driver will be built
    Drivers will be accessible to everyone on this system. To restrict access,
        select Customize Installation > Change advanced options > Driver is acce
ssible to
        and set group access.
    Load drivers: yes
    Reload automatically at reboot: yes
    Per-user collection mode: no
1. Start installation Now [default]
2. Customize installation
        its doesnt Intel fortran compiler in list !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
please help me
TimP
It looks like you're installing the C++ composer update.  That's an outdated version.
mehdi_k_
398 items, totalling 4.3 GB
I am going to move this question to our licensing forum. If you selected evaluation, it should have installed Fortran. Are you sure you didn't customize the install and deselect Fortran?
Feilong_H_Intel
Hi mehdi,
According to our registration database, you have two evaluation licenses.  One is for Intel® Parallel Studio XE Cluster Edition for Linux*, which expired on 5/11/2016.  Another is for Intel® Parallel Studio XE Composer Edition for Fortran and C++ Linux*, which will expire on 7/12/2016.  So you should be able to install IPS XE Composer Edition for Linux.  Since we don't ship IPS XE Composer Edition for Fortran and C++ on Linux, you will have to download either IPS XE Composer Edition for Fortran or and IPS XE Composer Edition for C++ on Linux.
Please log into https://registrationcenter.intel.com/en/products/, and download "Intel® Parallel Studio XE Composer Edition for Fortran Linux*" Version 2016.
Mehdi says that it was the Cluster Edition that was downloaded. Note that Advisor, Inspector and VTune were listed though I don't see any cluster tools. I wonder if the issue is that Mehdi was using the "online installer" and had previously installed with Fortran not selected.
mehdi_k_
I dont know thats is bug or .........!!
Step 1 of 7 | Welcome
Welcome to the Intel(R) Parallel Studio XE 2016 Update 1 for Linux* setup
program.
Install one of the following products:
Intel(R) Parallel Studio XE 2016 Update 1 Cluster Edition for Linux*
Intel(R) Parallel Studio XE 2016 Update 1 Professional Edition for Fortran and
C++ Linux*
Intel(R) Parallel Studio XE 2016 Update 1 Professional Edition for C++ Linux*
Linux*
Intel(R) Parallel Studio XE 2016 Update 1 Composer Edition for Fortran and C++
Linux*
Intel(R) Parallel Studio XE 2016 Update 1 Composer Edition for C++ Linux*
Intel(R) Parallel Studio XE 2016 Update 1 Composer Edition for Fortran Linux*
Missing optional prerequisites
-- Unsupported OS
-- Intel(R) Trace Analyzer and Collector 9.1 Update 2 for Linux* OS: Unsupported
OS
-- Intel(R) Cluster Checker 3.1 for Linux* OS: Unsupported OS
-- Intel(R) VTune(TM) Amplifier XE 2016 Update 1: Unsupported OS
-- Intel(R) Inspector XE 2016 Update 1: Unsupported OS
-- Intel(R) Advisor XE 2016 Update 1: Unsupported OS
1. Skip missing optional prerequisites [default]   and i skip
Step 3 of 7 | Activation > Alternative activation
Please type a selection or press "Enter" to accept default choice [1]: 1
Please type the full path to your license file(s):
/home/mazesta/ifort
Step 4 of 7 | Intel® Software Improvement Program
1. Yes, I am willing to participate and improve Intel software. (Recommended)
2. No, I don't want to participate in the Intel® Software Improvement Program at
i select 2
There is not Intel Fortran !!!!!!!!!!!!!!!!!!!!!!!!!
Install location:
    /opt/intel
        Sampling Driver kit
        Intel C++ Compiler
        Cluster support
        Intel TBB
    GNU* GDB 7.8                                                           139MB
License v.1.0)
License v.1.0)
v3)
Driver parameters:
ssible to
    Load drivers: yes
h. Help
b. Back to the previous menu
q. Quit
What OS (distribution and version) are you running?
You pointed it at a license file, which would be unusual for an evaluation (I don't see that you have any non-evaluation licenses.) Please use "Send author a message" and attach or copy in the license file you are using. (Don't include it here in the forum.)
Light_Intel
This issue has been addressed. If you have a similar question please start a new thread to ensure your issue is being addressed in a timely manner.
