Software Archive
Read-only legacy content
Plugins
Flemming_P_
Hi
How esaktly do I use this plugin for lock portrait mode on iPad
   github.com/yoik/cordova-yoik-screenorientation.git
Have to fill in the name and Plugin ID ??
OR this/ Plugin is located in the Apache Cordova Plugins Registry
net.yoik.cordova.plugins.screenorientation
Regards/Flemming
Amrita_C_Intel
I believe that this plugin is not registered. But you can still use it.
You can find here whether the plug in is registered or not.
http://plugins.cordova.io/#/ ;
Flemming_P_
BUT I am asking how to use it - I got the url github.com/yoik/cordova-yoik-screenorientation.git
BUT also have to fill in the name and Plugin ID ??
:-) flemming
PaulF_IntelCorp
Please see the plugin README for usage instructions: https://github.com/yoik/cordova-yoik-screenorientation
If you are asking how to you include it as part of your app, you'll have to use the third-party plugin feature to include it. See this doc page: https://software.intel.com/en-us/xdk/docs/adding-third-party-plugins-to-your-xdk-cordova-app. If the plugin is located in the Cordova registry you can use the plugin ID method (this plugin's ID is net.yoik.cordova.plugins.screenorientation). If you want to reference the GitHub repo you need to provide the repo URL (https://github.com/yoik/cordova-yoik-screenorientation.git) and the same ID as above. The "NAME" is whatever you want it to be.
