Software Archive
Read-only legacy content
17060 Discussions
Problem attempting I/O in offloaded code
Dean_B_
I get the error
On the remote process, dlopen() failed. The error message sent back from the sin
k is /tmp/coi_procs/1/3686/load_lib/testprintMIC.out: undefined symbol: myprint_
On the sink, dlopen() returned NULL. The result of dlerror() is "/tmp/coi_procs/
1/3686/load_lib/testprintMIC.out: undefined symbol: myprint_"
offload error: cannot load library to the device 0 (error code 20)
Press any key to continue . . .
When running this program:
    subroutine myprint()
    print *, "hello from mic"
    end subroutine myprint
    program main
    !DIR$ ATTRIBUTES OFFLOAD:mic :: myprint
    !DIR$ OFFLOAD target(mic)
    call myprint()
    end program main
Thanks in advance for any help,
Dean
Frances_R_Intel
In addition to the attribute statement inside main, put one in front of the subroutine myprint. You must tell the compiler both that main is going to call the subroutine myprint on the coprocessor and  that it needs to make a version of the subroutine myprint to run on the coprocessor.
