Software Archive
Read-only legacy content
17060 Discussions
Problem to install
gapalo_g_
hi,
I installed the software but when click on icon there is this message:
The intel XDK encountered a problem and must restart
Our apologies for this inconvenience. Please upload log to help us improve our product.
xdk:client (1404308433663): Intel XDK: 0876
xdk:client (1404308433664): Platform: darwin-ia32 (13.3.0)
xdk:client (1404308433685): Starting client process initialization
xdk:client (1404308433692): OS version: 10.9.4
xdk:server (1404308434111): Starting server process initialization
xdk:server (1404308434217): Unable to start HTTP server: Error: getaddrinfo ENOTFOUND
xdk:server (1404308434218): Writing an error to the server data file: [object Object]
xdk:server (1404308434220): Wrote server data to "/Users/raulstefanati/Library/Application Support/XDK/server-data.txt"
xdk:client (1404308434471): Server data file has an error description
[Log closed from xdk:client]
g
Elroy_A_Intel
This message reports data back to our engineering team for further research and analysis as well as keep you aware. As more updates for Intel XDK becomes available, the bug counts/alerts should be minimized.
You mentioned that you installed XDK, but the title of this post says "Problem to Install". Was it successfully installed? What desktop OS are you using?
gapalo_g_
hi Elroy, xdk was "installed", but when i click on icon to open: doesn't work.
I use osx 10.9.4
Elroy_A_Intel
We have released a new update for Intel XDK version 1199. You can download it from http://xdk-software.intel.com/.
Give this a try.
Ali_M_1
I downloaded and installed the latest XDK release 1536. I see all the options to create a new project disabled on the left of the screen. The menu under projects tab does not respond to click. The option at the bottom left corner "OPEN AND INTEL XDK PROJECT" responds to the click but I do not have any project to open.
Any advice
-Ali
PaulF_IntelCorp
Can you create a new project by:
-- select the Projects tab
-- select "start a new project"
-- choose a template
p.s. Please update to the 1621 release here: http://xdk.intel.com
Enzo_C_
XDK not installed on my win7 64bit
Log file:
[t1050 2015.02.05 09.37.59 00000000] [logger]: INFO: Logger started
[t1050 2015.02.05 09.37.59 00000001] [getopt]: INFO: Command line: "C:\Users\carfore\Downloads\xdk_web_win_master_1621 (1).exe"
[t1050 2015.02.05 09.37.59 00000002] [getopt]: INFO: Skip first argument: it seems this is process name -- C:\Users\carfore\Downloads\xdk_web_win_master_1621 (1).exe
[t1050 2015.02.05 09.37.59 00000003] [getopt]: INFO: command line parameters:
[t1050 2015.02.05 09.37.59 00000004] [getopt]: INFO: formatted command line:
[t1050 2015.02.05 09.37.59 00000005] [getopt]: INFO: Setting pre-defined parameter: child-params = --no-progress
[t1050 2015.02.05 09.37.59 00000006] [getopt]: INFO: Setting pre-defined parameter: change-dir =
[t1050 2015.02.05 09.37.59 00000007] [getopt]: INFO: Setting pre-defined parameter: smart-splash =
[t1050 2015.02.05 09.37.59 00000008] [message_processor]: INFO: Registered: action (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000009] [message_processor]: INFO: Registered: catalog (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000a] [message_processor]: INFO: Registered: core/core (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000b] [message_processor]: INFO: Registered: db (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000c] [message_processor]: INFO: Registered: dialog/cancel (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000d] [message_processor]: INFO: Registered: dialog/progress_billboard (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000e] [message_processor]: INFO: Registered: dialog/progress_dlg (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000000f] [message_processor]: INFO: Registered: dialog_custom_action (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000010] [message_processor]: INFO: Registered: dllcall (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000011] [message_processor]: INFO: Registered: dumper (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000012] [message_processor]: INFO: Registered: dumper_unit_msi (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000013] [message_processor]: INFO: Registered: feature_tree (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000014] [message_processor]: INFO: Registered: getopt (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000015] [message_processor]: INFO: Registered: install_progress_manager (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000016] [message_processor]: INFO: Registered: logger (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000017] [message_processor]: INFO: Registered: meta-data (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000018] [message_processor]: INFO: Registered: meta-data script (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000019] [message_processor]: INFO: Registered: mutex script (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001a] [message_processor]: INFO: Registered: progress2 script (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001b] [message_processor]: INFO: Registered: rtf initialization (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001c] [message_processor]: INFO: Registered: script logger (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001d] [message_processor]: INFO: Registered: splash (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001e] [message_processor]: INFO: Registered: string_formatter (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000001f] [message_processor]: INFO: Registered: v8 (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000020] [message_processor]: INFO: Registered: v8::bind::base_objects (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000021] [message_processor]: INFO: Registered: v8e::bind::action (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000022] [message_processor]: INFO: Registered: v8e::bind::create process (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000023] [message_processor]: INFO: Registered: v8e::bind::db (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000024] [message_processor]: INFO: Registered: v8e::bind::dumper_action (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000025] [message_processor]: INFO: Registered: v8e::bind::msi (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000026] [message_processor]: INFO: Registered: v8e::bind::shell (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000027] [message_processor]: INFO: Registered: v8e::bind::splash (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000028] [message_processor]: INFO: Registered: v8e::bind::storage (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000029] [message_processor]: INFO: Registered: v8e::bind::stringlist (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002a] [message_processor]: INFO: Registered: v8e::bind::wi (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002b] [message_processor]: INFO: Registered: v8e::bind::wizard (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002c] [message_processor]: INFO: Registered: v8e::bind::wmi (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002d] [message_processor]: INFO: Registered: v8e::bind::xml (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002e] [message_processor]: INFO: Registered: wi_presenter (0.0.0.0)
[t1050 2015.02.05 09.37.59 0000002f] [message_processor]: INFO: Registered: win bind progress (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000030] [message_processor]: INFO: Registered: win32/sheet_owner (0.0.0.0)
[t1050 2015.02.05 09.37.59 00000031] [message_processor]: CRITICAL: Failed to load plugin: cache
[t1050 2015.02.05 09.37.59 00000032] [message_processor]: CRITICAL: Failed to load plugin: error_container
[t1050 2015.02.05 09.37.59 00000033] [message_processor]: CRITICAL: Failed to load plugin: feature manager
[t1050 2015.02.05 09.37.59 00000034] [message_processor]: CRITICAL: Failed to load plugin: gdi-plus-service
[t1050 2015.02.05 09.37.59 00000035] [message_processor]: CRITICAL: Failed to load plugin: sizer
[t1050 2015.02.05 09.37.59 00000036] [message_processor]: CRITICAL: Failed to load plugin: system/string list
[t1050 2015.02.05 09.37.59 00000037] [message_processor]: CRITICAL: Failed to load plugin: wizard
PaulF_IntelCorp
Are you trying to install to a non-standard location?
soumaya_b_
Problem : intel xdk encountered a problem and must restart : The intel is closed suddenly every 5 minutes
xdk:client:[2016-05-15T08:46:31.666Z]: (1463301991667): memlim: 767557632
xdk:client:[2016-05-15T08:46:31.677Z]: (1463301991677): Setting NW crash dump to: C:\Users\ASUS\AppData\Local\XDK
xdk:client:[2016-05-15T08:46:32.155Z]: (1463301992155): Intel XDK: 3240
xdk:client:[2016-05-15T08:46:32.155Z]: (1463301992155): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-05-15T08:46:32.155Z]: (1463301992155): System Info:  CPU: 4 X Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz Physical Memory: 8467734528
xdk:client:[2016-05-15T08:46:32.155Z]: (1463301992155): NW: 0.11.7-rc10-dev
xdk:client:[2016-05-15T08:46:32.253Z]: (1463301992253): Created new theme: base
xdk:client:[2016-05-15T08:46:32.253Z]: (1463301992253): Registered new theme: base
xdk:client:[2016-05-15T08:46:32.255Z]: (1463301992255): Current theme is now: base
xdk:client:[2016-05-15T08:46:32.255Z]: (1463301992255): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-05-15T08:46:32.257Z]: (1463301992257): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-05-15T08:46:32.567Z]: (1463301992567): Starting client process initialization
xdk:client:[2016-05-15T08:46:32.603Z]: (1463301992603): NW Cache is up-to-date.
xdk:server:[2016-05-15T08:46:33.256Z]: (1463301993257): memlim: 767557632
xdk:server:[2016-05-15T08:46:33.262Z]: (1463301993262): Setting NW crash dump to: C:\Users\ASUS\AppData\Local\XDK
xdk:server:[2016-05-15T08:46:33.621Z]: (1463301993621): Starting server process initialization
xdk:server:[2016-05-15T08:46:33.932Z]: (1463301993932): Http server started on the standard port 58889
xdk:server:[2016-05-15T08:46:34.984Z]: (1463301994984): NW Cache is up-to-date.
xdk:server:[2016-05-15T08:46:35.588Z]: (1463301995588): Component "core:assert" starting import
xdk:client:[2016-05-15T08:46:36.669Z]: (1463301996669): memmrk:    16493612    35318016
xdk:server:[2016-05-15T08:46:35.588Z]: (1463301995588): Component "core:assert" finished initialization
xdk:server:[2016-05-15T08:46:35.588Z]: (1463301995588): Component "core:component-error" starting import
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:component-error" finished initialization
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:command-line-options" starting import
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:command-line-options" finished initialization
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:service-error" starting import
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:service-error" finished initialization
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:buffer" starting import
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:buffer" finished initialization
xdk:server:[2016-05-15T08:46:35.592Z]: (1463301995592): Component "core:signaler" starting import
xdk:server:[2016-05-15T08:46:35.612Z]: (1463301995612): Component "core:signaler" finished initialization
xdk:server:[2016-05-15T08:46:35.612Z]: (1463301995612): Component "core:signaler-group" starting import
xdk:server:[2016-05-15T08:46:35.624Z]: (1463301995624): Component "core:signaler-group" finished initialization
xdk:server:[2016-05-15T08:46:35.624Z]: (1463301995624): Component "core:logger" starting import
xdk:server:[2016-05-15T08:46:35.636Z]: (1463301995636): Component "core:logger" finished initialization
xdk:server:[2016-05-15T08:46:35.636Z]: (1463301995636): Component "core:http-request" starting import
xdk:server:[2016-05-15T08:46:35.644Z]: (1463301995644): Component "core:http-request" finished initialization
xdk:server:[2016-05-15T08:46:35.644Z]: (1463301995644): Component "core:database" starting import
xdk:server:[2016-05-15T08:46:35.652Z]: (1463301995652): Component "core:database" finished initialization
xdk:server:[2016-05-15T08:46:35.652Z]: (1463301995652): Component "core:version" starting import
xdk:server:[2016-05-15T08:46:35.652Z]: (1463301995652): Component "core:version" finished initialization
xdk:server:[2016-05-15T08:46:35.652Z]: (1463301995652): Component "core:userfs-name-converter" starting import
xdk:server:[2016-05-15T08:46:35.660Z]: (1463301995660): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-05-15T08:46:35.660Z]: (1463301995660): Component "core:crash-handler" starting import
xdk:server:[2016-05-15T08:46:35.668Z]: (1463301995668): Component "core:crash-handler" finished initialization
xdk:server:[2016-05-15T08:46:35.668Z]: (1463301995668): Component "core:i18n-support" starting import
xdk:server:[2016-05-15T08:46:35.668Z]: (1463301995668): Component "core:i18n-support" finished initialization
xdk:server:[2016-05-15T08:46:35.668Z]: (1463301995668): Component "core:theme" starting import
xdk:server:[2016-05-15T08:46:35.735Z]: (1463301995735): Component "core:theme" finished initialization
xdk:server:[2016-05-15T08:46:35.736Z]: (1463301995736): Component "server:userfs" starting import
xdk:server:[2016-05-15T08:46:35.750Z]: (1463301995751): Component "server:userfs" calling init()
xdk:server:[2016-05-15T08:46:35.829Z]: (1463301995829): Component "server:userfs" finished initialization
xdk:server:[2016-05-15T08:46:35.829Z]: (1463301995829): Component "server:user-profile" starting import
xdk:server:[2016-05-15T08:46:35.838Z]: (1463301995838): Component "server:user-profile" calling init()
xdk:server:[2016-05-15T08:46:35.838Z]: (1463301995838): Component "server:user-profile" finished initialization
xdk:server:[2016-05-15T08:46:35.838Z]: (1463301995838): Component "server:ui-builder" starting import
xdk:server:[2016-05-15T08:46:36.045Z]: (1463301996045): Component "server:ui-builder" calling init()
xdk:server:[2016-05-15T08:46:36.046Z]: (1463301996046): Component "server:ui-builder" finished initialization
xdk:server:[2016-05-15T08:46:36.046Z]: (1463301996046): Component "server:emulator-notification" starting import
xdk:server:[2016-05-15T08:46:36.055Z]: (1463301996055): Component "server:emulator-notification" calling init()
xdk:server:[2016-05-15T08:46:36.056Z]: (1463301996056): Component "server:emulator-notification" finished initialization
xdk:server:[2016-05-15T08:46:36.056Z]: (1463301996056): Component "server:emulator-webserver" starting import
xdk:server:[2016-05-15T08:46:36.060Z]: (1463301996060): Component "server:emulator-webserver" calling init()
xdk:server:[2016-05-15T08:46:36.062Z]: (1463301996062): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-05-15T08:46:36.062Z]: (1463301996062): Component "server:zip-util" starting import
xdk:server:[2016-05-15T08:46:36.070Z]: (1463301996070): Component "server:zip-util" calling init()
xdk:server:[2016-05-15T08:46:36.070Z]: (1463301996070): Component "server:zip-util" finished initialization
xdk:server:[2016-05-15T08:46:36.070Z]: (1463301996070): Component "server:uuid-server" starting import
xdk:server:[2016-05-15T08:46:36.078Z]: (1463301996078): Component "server:uuid-server" calling init()
xdk:server:[2016-05-15T08:46:36.078Z]: (1463301996078): Component "server:uuid-server" finished initialization
xdk:server:[2016-05-15T08:46:36.078Z]: (1463301996078): Component "server:force-download" starting import
xdk:server:[2016-05-15T08:46:36.086Z]: (1463301996086): Component "server:force-download" calling init()
xdk:server:[2016-05-15T08:46:36.086Z]: (1463301996086): Component "server:force-download" finished initialization
xdk:server:[2016-05-15T08:46:36.086Z]: (1463301996086): Component "server:updater" starting import
xdk:server:[2016-05-15T08:46:36.097Z]: (1463301996097): Component "server:updater" calling init()
server:updater:[2016-05-15T08:46:36.097Z]: (1463301996097): config.base-auto
server:updater:[2016-05-15T08:46:36.098Z]: (1463301996098): url=auto
xdk:server:[2016-05-15T08:46:36.098Z]: (1463301996098): Component "server:updater" finished initialization
xdk:server:[2016-05-15T08:46:36.098Z]: (1463301996098): Component "server:editor-node" starting import
xdk:server:[2016-05-15T08:46:36.184Z]: (1463301996184): Component "server:editor-node" calling init()
xdk:server:[2016-05-15T08:46:36.185Z]: (1463301996185): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-05-15T08:46:36.185Z]: (1463301996185): Component "server:cordova-lib" starting import
xdk:server:[2016-05-15T08:46:37.654Z]: (1463301997654): Component "server:cordova-lib" calling init()
xdk:server:[2016-05-15T08:46:37.824Z]: (1463301997824): Component "server:cordova-lib" finished initialization
xdk:server:[2016-05-15T08:46:37.824Z]: (1463301997824): Component "server:api-explorer" starting import
xdk:server:[2016-05-15T08:46:37.839Z]: (1463301997839): Component "server:api-explorer" calling init()
xdk:server:[2016-05-15T08:46:37.968Z]: (1463301997968): Component "server:api-explorer" finished initialization
xdk:server:[2016-05-15T08:46:37.968Z]: (1463301997968): Component "server:plugin-listener" starting import
xdk:server:[2016-05-15T08:46:37.975Z]: (1463301997975): Component "server:plugin-listener" calling init()
xdk:server:[2016-05-15T08:46:37.976Z]: (1463301997976): Component "server:plugin-listener" finished initialization
xdk:server:[2016-05-15T08:46:37.976Z]: (1463301997976): Component "server:git-runner" starting import
xdk:server:[2016-05-15T08:46:37.984Z]: (1463301997984): Component "server:git-runner" calling init()
xdk:server:[2016-05-15T08:46:37.985Z]: (1463301997985): Component "server:git-runner" finished initialization
server:editor-node:[2016-05-15T08:46:37.986Z]: (1463301997986): Starting Brackets node process C:\Users\ASUS\AppData\Local\Intel\XDK\bin\node.exe C:\Users\ASUS\AppData\Local\Intel\XDK\bin\node-core
server:editor-node:[2016-05-15T08:46:38.204Z]: (1463301998204): Brackets node is running on port 49766
xdk:server:[2016-05-15T08:46:38.208Z]: (1463301998208): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-05-15T08:46:38.208Z]: (1463301998208): Component "server:ui-builder" calling start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Component "server:ui-builder" finished start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Component "server:emulator-webserver" calling start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Component "server:emulator-webserver" finished start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Component "server:editor-node" calling start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Component "server:editor-node" finished start()
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Intel XDK is initialized now
xdk:server:[2016-05-15T08:46:38.212Z]: (1463301998212): Writing to the server data file
xdk:server:[2016-05-15T08:46:38.216Z]: (1463301998216): Wrote server data to "C:\Users\ASUS\AppData\Local\XDK\server-data.txt"
xdk:server:[2016-05-15T08:46:38.260Z]: (1463301998260): memmrk:    26888800    44434816
xdk:client:[2016-05-15T08:46:38.373Z]: (1463301998373): Successfully read server data file
xdk:client:[2016-05-15T08:46:38.645Z]: (1463301998645): Component "core:assert" starting import
xdk:client:[2016-05-15T08:46:38.645Z]: (1463301998645): Component "core:assert" finished initialization
xdk:client:[2016-05-15T08:46:38.645Z]: (1463301998645): Component "core:component-error" starting import
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:component-error" finished initialization
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:command-line-options" starting import
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:command-line-options" finished initialization
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:service-error" starting import
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:service-error" finished initialization
xdk:client:[2016-05-15T08:46:38.646Z]: (1463301998646): Component "core:buffer" starting import
xdk:client:[2016-05-15T08:46:38.647Z]: (1463301998647): Component "core:buffer" finished initialization
xdk:client:[2016-05-15T08:46:38.647Z]: (1463301998647): Component "core:signaler" starting import
xdk:client:[2016-05-15T08:46:38.648Z]: (1463301998648): Component "core:signaler" finished initialization
xdk:client:[2016-05-15T08:46:38.648Z]: (1463301998648): Component "core:signaler-group" starting import
xdk:client:[2016-05-15T08:46:38.651Z]: (1463301998651): Component "core:signaler-group" finished initialization
xdk:client:[2016-05-15T08:46:38.651Z]: (1463301998651): Component "core:logger" starting import
xdk:client:[2016-05-15T08:46:38.652Z]: (1463301998652): Component "core:logger" finished initialization
xdk:client:[2016-05-15T08:46:38.652Z]: (1463301998652): Component "core:http-request" starting import
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:http-request" finished initialization
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:version" starting import
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:version" finished initialization
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:exit-notifier" starting import
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:exit-notifier" finished initialization
xdk:client:[2016-05-15T08:46:38.654Z]: (1463301998654): Component "core:userfs-name-converter" starting import
xdk:client:[2016-05-15T08:46:38.655Z]: (1463301998655): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-05-15T08:46:38.655Z]: (1463301998655): Component "core:crash-handler" starting import
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:crash-handler" finished initialization
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:analytics" starting import
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:analytics" finished initialization
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:i18n-support" starting import
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:i18n-support" finished initialization
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:theme" starting import
xdk:client:[2016-05-15T08:46:38.657Z]: (1463301998657): Component "core:theme" finished initialization
xdk:client:[2016-05-15T08:46:38.673Z]: (1463301998673): Analytics ID: b0ae5b60-2c9f-4e04-9126-4f7c067b8c08
xdk:client:[2016-05-15T08:46:38.676Z]: (1463301998676): onExit listener 0:
    at Object.exports.onExit (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:app" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:help-helper" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:nativefs" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:document-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:project-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:aa-controller" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:build-validator" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:projects-renderers" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:active-sync" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:apk-installer" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:appcenter-options" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-cocos2d" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-phaser" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-pixi" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-easeljs" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-plain" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-render-frame" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:resource-util" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:bower-package-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:services-tab" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:editor" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:live-preview" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:backend-services" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:backend-feeds" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:merged-feed" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:backend-services-ext" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:backend-service-utils" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:cert-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:account-settings" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:ui-builder-client" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:project-meta" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:contenttype-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:editor-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:platform-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:projecttype-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:library-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:cordova-registry" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:service-method" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:settings-db" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:adb" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:iosdb" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:device" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:device-discovery" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:dialog-box" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:test-local-server" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:quick-tour" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:hot-keys" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:persistance" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:tabs" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:hash-utils" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:file-watcher" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:tool-tip" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:cordova" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:settings-ui" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:external-links" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:external-editors-runner" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:project-list-load" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:upload-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:git-manager" starting import
xdk:client:[2016-05-15T08:46:38.717Z]: (1463301998717): Component "client:new-project-creator" starting import
xdk:client:[2016-05-15T08:46:38.755Z]: (1463301998755): Component "client:nativefs" finished initialization
xdk:client:[2016-05-15T08:46:38.757Z]: (1463301998757): Component "client:help-helper" finished initialization
xdk:client:[2016-05-15T08:46:38.795Z]: (1463301998795): Component "client:apk-installer" calling init()
xdk:client:[2016-05-15T08:46:38.795Z]: (1463301998795): Component "client:apk-installer" finished initialization
xdk:client:[2016-05-15T08:46:38.806Z]: (1463301998806): Component "client:active-sync" calling init()
xdk:client:[2016-05-15T08:46:38.806Z]: (1463301998806): Component "client:active-sync" finished initialization
xdk:client:[2016-05-15T08:46:38.839Z]: (1463301998839): Component "client:resource-render-frame" calling init()
xdk:client:[2016-05-15T08:46:38.839Z]: (1463301998839): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.840Z]: (1463301998840): Component "client:resource-util" calling init()
xdk:client:[2016-05-15T08:46:38.841Z]: (1463301998841): Component "client:resource-util" finished initialization
xdk:client:[2016-05-15T08:46:38.850Z]: (1463301998850): Component "client:backend-services" calling init()
xdk:client:[2016-05-15T08:46:38.852Z]: (1463301998852): Component "client:backend-services" finished initialization
xdk:client:[2016-05-15T08:46:38.855Z]: (1463301998855): Component "client:backend-feeds" calling init()
xdk:client:[2016-05-15T08:46:38.855Z]: (1463301998855): Component "client:backend-feeds" finished initialization
xdk:client:[2016-05-15T08:46:38.857Z]: (1463301998857): Component "client:merged-feed" finished initialization
xdk:client:[2016-05-15T08:46:38.858Z]: (1463301998858): Component "client:backend-services-ext" calling init()
xdk:client:[2016-05-15T08:46:38.858Z]: (1463301998858): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-05-15T08:46:38.861Z]: (1463301998862): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-05-15T08:46:38.867Z]: (1463301998867): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-05-15T08:46:38.882Z]: (1463301998882): Component "client:project-meta" calling init()
xdk:client:[2016-05-15T08:46:38.882Z]: (1463301998882): Component "client:project-meta" finished initialization
xdk:client:[2016-05-15T08:46:38.892Z]: (1463301998892): Component "client:settings-db" calling init()
xdk:client:[2016-05-15T08:46:38.892Z]: (1463301998892): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.894Z]: (1463301998894): Component "client:service-method" finished initialization
xdk:client:[2016-05-15T08:46:38.895Z]: (1463301998895): Component "client:iosdb" calling init()
xdk:client:[2016-05-15T08:46:38.895Z]: (1463301998895): Component "client:iosdb" finished initialization
xdk:client:[2016-05-15T08:46:38.899Z]: (1463301998899): Component "client:adb" calling init()
xdk:client:[2016-05-15T08:46:38.935Z]: (1463301998935): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.946Z]: (1463301998946): Component "client:persistance" calling init()
xdk:client:[2016-05-15T08:46:38.946Z]: (1463301998946): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.948Z]: (1463301998948): Component "client:file-watcher" calling init()
xdk:client:[2016-05-15T08:46:38.948Z]: (1463301998948): Component "client:file-watcher" finished initialization
xdk:client:[2016-05-15T08:46:38.955Z]: (1463301998955): Component "client:external-links" finished initialization
xdk:client:[2016-05-15T08:46:38.955Z]: (1463301998955): Component "client:project-list-load" calling init()
xdk:client:[2016-05-15T08:46:38.955Z]: (1463301998955): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.959Z]: (1463301998959): Component "client:upload-manager" calling init()
xdk:client:[2016-05-15T08:46:38.960Z]: (1463301998960): Component "client:upload-manager" finished initialization
xdk:client:[2016-05-15T08:46:38.961Z]: (1463301998961): Component "client:external-editors-runner" calling init()
xdk:client:[2016-05-15T08:46:38.961Z]: (1463301998961): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-05-15T08:46:38.963Z]: (1463301998963): Component "client:git-manager" calling init()
client:git-manager:[2016-05-15T08:46:38.963Z]: (1463301998963): git path =  C:\Users\ASUS\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-05-15T08:46:38.963Z]: (1463301998963): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:38.972Z]: (1463301998972): Component "client:new-project-creator" calling init()
xdk:client:[2016-05-15T08:46:38.972Z]: (1463301998972): Component "client:new-project-creator" finished initialization
xdk:client:[2016-05-15T08:46:38.974Z]: (1463301998974): Component "client:document-manager" calling init()
xdk:client:[2016-05-15T08:46:38.974Z]: (1463301998974): Component "client:document-manager" finished initialization
xdk:client:[2016-05-15T08:46:38.991Z]: (1463301998991): Component "client:hot-keys" calling init()
xdk:client:[2016-05-15T08:46:38.991Z]: (1463301998991): Component "client:hot-keys" finished initialization
xdk:client:[2016-05-15T08:46:39.040Z]: (1463301999040): Component "client:build-validator" finished initialization
xdk:client:[2016-05-15T08:46:39.057Z]: (1463301999057): Component "client:test-local-server" calling init()
xdk:client:[2016-05-15T08:46:39.133Z]: (1463301999133): Component "client:test-local-server" finished initialization
xdk:client:[2016-05-15T08:46:39.521Z]: (1463301999521): Component "client:cert-manager" finished initialization
client:adb:[2016-05-15T08:46:39.524Z]: (1463301999524): Using existing adb at "C:\Users\ASUS\AppData\Local\Intel\XDK\bin\adb\adb.exe"
xdk:client:[2016-05-15T08:46:39.540Z]: (1463301999540): Component "client:appcenter-options" calling init()
xdk:client:[2016-05-15T08:46:39.540Z]: (1463301999540): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.552Z]: (1463301999552): Component "client:ui-builder-client" calling init()
xdk:client:[2016-05-15T08:46:39.552Z]: (1463301999552): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-05-15T08:46:39.552Z]: (1463301999552): Component "client:dialog-box" finished initialization
xdk:client:[2016-05-15T08:46:39.556Z]: (1463301999556): Component "client:tabs" finished initialization
xdk:client:[2016-05-15T08:46:39.560Z]: (1463301999560): Component "client:tool-tip" finished initialization
xdk:client:[2016-05-15T08:46:39.564Z]: (1463301999564): Component "client:app" calling init()
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:app" finished initialization
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:navbar" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:tweets" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:projects-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:test-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:profilingTab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:emulator" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:remote-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:build-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:build-service" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:bower-client" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:editor-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:account" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:project-selector" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:publish-tab" starting import
xdk:client:[2016-05-15T08:46:39.576Z]: (1463301999576): Component "client:settings-ui" finished initialization
xdk:client:[2016-05-15T08:46:39.617Z]: (1463301999617): Component "client:aa-controller" calling init()
xdk:client:[2016-05-15T08:46:39.618Z]: (1463301999618): Component "client:aa-controller" finished initialization
xdk:client:[2016-05-15T08:46:39.691Z]: (1463301999691): Component "client:services-tab" calling init()
xdk:client:[2016-05-15T08:46:39.692Z]: (1463301999692): Component "client:services-tab" finished initialization
xdk:client:[2016-05-15T08:46:39.696Z]: (1463301999700): Component "client:editor-registry" finished initialization
xdk:client:[2016-05-15T08:46:39.714Z]: (1463301999714): Component "client:library-registry" calling init()
xdk:client:[2016-05-15T08:46:39.715Z]: (1463301999715): Component "client:library-registry" finished initialization
xdk:client:[2016-05-15T08:46:39.716Z]: (1463301999716): Component "client:contenttype-registry" calling init()
xdk:client:[2016-05-15T08:46:39.717Z]: (1463301999717): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-05-15T08:46:39.727Z]: (1463301999727): Component "client:device-discovery" calling init()
xdk:client:[2016-05-15T08:46:39.727Z]: (1463301999727): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.835Z]: (1463301999835): Component "client:cordova" calling init()
xdk:client:[2016-05-15T08:46:39.835Z]: (1463301999835): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.836Z]: (1463301999836): Component "client:hash-utils" finished initialization
xdk:client:[2016-05-15T08:46:39.842Z]: (1463301999842): Component "client:quick-tour" calling init()
xdk:client:[2016-05-15T08:46:39.842Z]: (1463301999842): Component "client:quick-tour" finished initialization
xdk:client:[2016-05-15T08:46:39.853Z]: (1463301999853): Component "client:project-manager" calling init()
xdk:client:[2016-05-15T08:46:39.854Z]: (1463301999854): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.857Z]: (1463301999857): Component "client:adb" finished delayed initialization
xdk:client:[2016-05-15T08:46:39.880Z]: (1463301999880): Component "client:resource-manager" calling init()
xdk:client:[2016-05-15T08:46:39.880Z]: (1463301999880): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.889Z]: (1463301999889): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-05-15T08:46:39.889Z]: (1463301999889): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-05-15T08:46:39.890Z]: (1463301999890): Component "client:resource-pixi" calling init()
xdk:client:[2016-05-15T08:46:39.890Z]: (1463301999890): Component "client:resource-pixi" finished initialization
xdk:client:[2016-05-15T08:46:39.892Z]: (1463301999892): Component "client:resource-easeljs" calling init()
xdk:client:[2016-05-15T08:46:39.892Z]: (1463301999892): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-05-15T08:46:39.893Z]: (1463301999893): Component "client:resource-phaser" calling init()
xdk:client:[2016-05-15T08:46:39.893Z]: (1463301999893): Component "client:resource-phaser" finished initialization
xdk:client:[2016-05-15T08:46:39.893Z]: (1463301999893): Component "client:resource-plain" calling init()
xdk:client:[2016-05-15T08:46:39.893Z]: (1463301999893): Component "client:resource-plain" finished initialization
xdk:client:[2016-05-15T08:46:39.902Z]: (1463301999902): Component "client:cordova-registry" calling init()
xdk:client:[2016-05-15T08:46:39.902Z]: (1463301999902): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.929Z]: (1463301999929): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-05-15T08:46:39.930Z]: (1463301999930): Component "client:build-service" calling init()
xdk:client:[2016-05-15T08:46:39.930Z]: (1463301999930): Component "client:build-service" finished initialization
xdk:client:[2016-05-15T08:46:39.960Z]: (1463301999960): Component "client:projects-renderers" calling init()
xdk:client:[2016-05-15T08:46:39.960Z]: (1463301999960): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.960Z]: (1463301999960): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-05-15T08:46:39.961Z]: (1463301999961): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-05-15T08:46:39.982Z]: (1463301999982): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-05-15T08:46:39.982Z]: (1463301999982): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:39.997Z]: (1463301999997): Component "client:account-settings" calling init()
xdk:client:[2016-05-15T08:46:39.997Z]: (1463301999997): Component "client:account-settings" finished initialization
xdk:client:[2016-05-15T08:46:40.003Z]: (1463302000003): Component "client:platform-registry" calling init()
xdk:client:[2016-05-15T08:46:40.004Z]: (1463302000004): Component "client:platform-registry" finished initialization
xdk:client:[2016-05-15T08:46:40.011Z]: (1463302000011): Component "client:device" calling init()
xdk:client:[2016-05-15T08:46:40.376Z]: (1463302000376): Component "client:device" finished initialization
xdk:client:[2016-05-15T08:46:40.378Z]: (1463302000378): Component "client:projecttype-registry" calling init()
xdk:client:[2016-05-15T08:46:40.378Z]: (1463302000378): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-05-15T08:46:40.384Z]: (1463302000384): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.384Z]: (1463302000384): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.386Z]: (1463302000386): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-05-15T08:46:40.428Z]: (1463302000428): Custom Git Client Path is C:\Users\ASUS\AppData\Local\Intel\XDK\bin\git\bin\git.exe
client:git-manager:[2016-05-15T08:46:40.428Z]: (1463302000428): Auto-Proxy setting is true
xdk:client:[2016-05-15T08:46:40.472Z]: (1463302000472): Component "client:account" getting UI region for "account"
xdk:client:[2016-05-15T08:46:40.473Z]: (1463302000473): Component "client:account" calling init()
xdk:client:[2016-05-15T08:46:40.476Z]: (1463302000476): Component "client:account" finished initialization
xdk:client:[2016-05-15T08:46:40.478Z]: (1463302000478): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-05-15T08:46:40.479Z]: (1463302000479): Component "client:project-selector" calling init()
xdk:client:[2016-05-15T08:46:40.479Z]: (1463302000479): Component "client:project-selector" finished initialization
xdk:client:[2016-05-15T08:46:40.492Z]: (1463302000492): Component "client:bower-package-manager" calling init()
xdk:client:[2016-05-15T08:46:40.493Z]: (1463302000493): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:40.493Z]: (1463302000493): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.504Z]: (1463302000504): Component "client:tweets" finished initialization
xdk:client:[2016-05-15T08:46:40.506Z]: (1463302000506): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-05-15T08:46:40.506Z]: (1463302000506): Component "client:projects-tab" calling init()
xdk:client:[2016-05-15T08:46:40.508Z]: (1463302000508): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:40.526Z]: (1463302000526): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-05-15T08:46:40.526Z]: (1463302000526): Component "client:emulator" calling init()
xdk:client:[2016-05-15T08:46:40.531Z]: (1463302000531): Component "client:emulator" finished initialization
xdk:client:[2016-05-15T08:46:40.538Z]: (1463302000538): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-05-15T08:46:40.538Z]: (1463302000538): Component "client:remote-tab" calling init()
xdk:client:[2016-05-15T08:46:40.796Z]: (1463302000796): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:40.798Z]: (1463302000798): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-05-15T08:46:40.798Z]: (1463302000798): Component "client:test-tab" calling init()
xdk:client:[2016-05-15T08:46:40.798Z]: (1463302000798): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:40.836Z]: (1463302000836): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.842Z]: (1463302000842): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.851Z]: (1463302000851): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-05-15T08:46:40.851Z]: (1463302000851): Component "client:navbar" calling init()
client:navbar:[2016-05-15T08:46:40.851Z]: (1463302000851): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-05-15T08:46:40.851Z]: (1463302000851): Component "client:navbar" finished initialization
xdk:client:[2016-05-15T08:46:40.921Z]: (1463302000921): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-05-15T08:46:40.921Z]: (1463302000921): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-05-15T08:46:40.929Z]: (1463302000929): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-05-15T08:46:40.929Z]: (1463302000929): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-05-15T08:46:40.969Z]: (1463302000969): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-05-15T08:46:40.969Z]: (1463302000969): Component "client:build-tab" calling init()
xdk:client:[2016-05-15T08:46:40.980Z]: (1463302000980): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-05-15T08:46:40.982Z]: (1463302000982): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:40.993Z]: (1463302000993): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-05-15T08:46:40.993Z]: (1463302000993): Component "client:publish-tab" calling init()
xdk:client:[2016-05-15T08:46:41.001Z]: (1463302001001): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-05-15T08:46:41.003Z]: (1463302001003): Component "client:publish-tab" finished initialization
xdk:client:[2016-05-15T08:46:41.006Z]: (1463302001006): Component "client:live-preview" calling init()
xdk:client:[2016-05-15T08:46:41.006Z]: (1463302001006): Component "client:live-preview" finished initialization
xdk:client:[2016-05-15T08:46:41.007Z]: (1463302001007): Component "client:editor" calling init()
xdk:client:[2016-05-15T08:46:41.007Z]: (1463302001007): Component "client:editor" finished initialization
xdk:client:[2016-05-15T08:46:41.007Z]: (1463302001007): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-05-15T08:46:41.007Z]: (1463302001007): Component "client:editor-tab" calling init()
xdk:client:[2016-05-15T08:46:41.019Z]: (1463302001019): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-05-15T08:46:41.028Z]: (1463302001028): Component "client:cordova" finished delayed initialization
xdk:client:[2016-05-15T08:46:41.045Z]: (1463302001045): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-05-15T08:46:41.045Z]: (1463302001045): Component "client:bower-client" calling init()
xdk:client:[2016-05-15T08:46:41.045Z]: (1463302001045): Component "client:bower-client" finished initialization
xdk:client:[2016-05-15T08:46:41.213Z]: (1463302001213): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-05-15T08:46:41.213Z]: (1463302001213): Component "client:profilingTab" calling init()
xdk:client:[2016-05-15T08:46:41.217Z]: (1463302001217): Component "client:profilingTab" finished initialization
xdk:client:[2016-05-15T08:46:41.670Z]: (1463302001670): memmrk:    33071804    50586496
client:appcenter-options:[2016-05-15T08:46:41.926Z]: (1463302001926): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-05-15T08:46:41.926Z]: (1463302001926): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-05-15T08:46:41.938Z]: (1463302001938): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-05-15T08:46:42.574Z]: (1463302002574): Component "client:cordova-registry" finished delayed initialization
xdk:server:[2016-05-15T08:46:43.263Z]: (1463302003263): memmrk:    28935892    44434816
xdk:client:[2016-05-15T08:46:46.671Z]: (1463302006671): memmrk:    33799408    50586496
xdk:server:[2016-05-15T08:46:48.264Z]: (1463302008264): memmrk:    20829752    44434816
xdk:client:[2016-05-15T08:46:51.673Z]: (1463302011673): memmrk:    33801848    50586496
xdk:server:[2016-05-15T08:46:53.267Z]: (1463302013267): memmrk:    19475556    25671296
xdk:client:[2016-05-15T08:46:56.674Z]: (1463302016674): memmrk:    33804272    50586496
xdk:server:[2016-05-15T08:46:58.336Z]: (1463302018336): memmrk:    18785556    24667776
xdk:client:[2016-05-15T08:47:01.674Z]: (1463302021674): memmrk:    33806712    50586496
xdk:server:[2016-05-15T08:47:03.337Z]: (1463302023337): memmrk:    18800176    24667776
xdk:client:[2016-05-15T08:47:06.675Z]: (1463302026675): memmrk:    34047800    50586496
xdk:server:[2016-05-15T08:47:08.341Z]: (1463302028341): memmrk:    16942736    23664256
xdk:client:[2016-05-15T08:47:11.677Z]: (1463302031677): memmrk:    34055400    50586496
xdk:server:[2016-05-15T08:47:13.382Z]: (1463302033382): memmrk:    16852168    23664256
xdk:client:[2016-05-15T08:47:16.678Z]: (1463302036678): memmrk:    27540996    50586496
xdk:server:[2016-05-15T08:47:18.385Z]: (1463302038385): memmrk:    17186220    24712832
xdk:client:[2016-05-15T08:47:18.560Z]: (1463302038560): Component "client:persistance" finished delayed initialization
xdk:client:[2016-05-15T08:47:22.209Z]: (1463302042209): memmrk:    34427680    51602176
xdk:server:[2016-05-15T08:47:23.386Z]: (1463302043386): memmrk:    21916092    43455616
xdk:client:[2016-05-15T08:47:27.209Z]: (1463302047209): memmrk:    42827908    60743296
xdk:server:[2016-05-15T08:47:28.387Z]: (1463302048387): memmrk:    30629856    50553216
xdk:client:[2016-05-15T08:47:32.208Z]: (1463302052208): memmrk:    42419968    62774656
xdk:server:[2016-05-15T08:47:33.388Z]: (1463302053388): memmrk:    43504132    57662976
xdk:client:[2016-05-15T08:47:37.209Z]: (1463302057209): memmrk:    31757460    62774656
xdk:server:[2016-05-15T08:47:38.388Z]: (1463302058388): memmrk:    49768384    69838976
xdk:client:[2016-05-15T08:47:42.209Z]: (1463302062209): memmrk:    40422272    62774656
xdk:server:[2016-05-15T08:47:43.393Z]: (1463302063393): memmrk:    57502192    73901696
xdk:client:[2016-05-15T08:47:47.210Z]: (1463302067210): memmrk:    32601912    62774656
xdk:server:[2016-05-15T08:47:48.393Z]: (1463302068393): memmrk:    67781428    81011456
xdk:client:[2016-05-15T08:47:52.210Z]: (1463302072210): memmrk:    39090688    63790336
xdk:server:[2016-05-15T08:47:53.397Z]: (1463302073397): memmrk:    20164268    87105536
xdk:client:[2016-05-15T08:47:57.206Z]: (1463302077206): memmrk:    36342936    66837376
xdk:server:[2016-05-15T08:47:58.398Z]: (1463302078398): memmrk:    27512572    87105536
xdk:client:[2016-05-15T08:48:02.211Z]: (1463302082211): memmrk:    44168532    67853056
xdk:server:[2016-05-15T08:48:03.398Z]: (1463302083398): memmrk:    37667308    87105536
xdk:client:[2016-05-15T08:48:08.211Z]: (1463302088211): memmrk:    47403288    68868736
xdk:server:[2016-05-15T08:48:08.402Z]: (1463302088402): memmrk:    49841792    87105536
xdk:client:[2016-05-15T08:48:13.215Z]: (1463302093215): memmrk:    36825620    68868736
xdk:server:[2016-05-15T08:48:13.403Z]: (1463302093403): memmrk:    55804904    87105536
xdk:server:[2016-05-15T08:48:18.403Z]: (1463302098403): memmrk:    74436116    88121216
xdk:client:[2016-05-15T08:48:19.208Z]: (1463302099208): memmrk:    38117636    68868736
xdk:server:[2016-05-15T08:48:23.403Z]: (1463302103407): memmrk:    24807852    96234496
xdk:client:[2016-05-15T08:48:24.212Z]: (1463302104212): memmrk:    37931388    68868736
xdk:server:[2016-05-15T08:48:28.408Z]: (1463302108408): memmrk:    35881132    96234496
xdk:client:[2016-05-15T08:48:29.208Z]: (1463302109208): memmrk:    32427524    68868736
xdk:server:[2016-05-15T08:48:33.408Z]: (1463302113408): memmrk:    45867868    96234496
xdk:client:[2016-05-15T08:48:34.212Z]: (1463302114212): memmrk:    36847924    68868736
xdk:server:[2016-05-15T08:48:38.408Z]: (1463302118408): memmrk:    53579680    96234496
xdk:client:[2016-05-15T08:48:40.208Z]: (1463302120208): memmrk:    36724440    68868736
xdk:server:[2016-05-15T08:48:43.413Z]: (1463302123413): memmrk:    59460096    96234496
xdk:client:[2016-05-15T08:48:45.209Z]: (1463302125209): memmrk:    39108500    68868736
xdk:server:[2016-05-15T08:48:48.417Z]: (1463302128417): memmrk:    19504828    96234496
xdk:client:[2016-05-15T08:48:50.209Z]: (1463302130209): memmrk:    33700588    68868736
xdk:server:[2016-05-15T08:48:53.419Z]: (1463302133419): memmrk:    23753256    96234496
xdk:client:[2016-05-15T08:48:55.211Z]: (1463302135211): memmrk:    35478856    68868736
xdk:server:[2016-05-15T08:48:58.419Z]: (1463302138419): memmrk:    21019952    64784896
xdk:client:[2016-05-15T08:49:00.211Z]: (1463302140211): memmrk:    40597168    68868736
xdk:server:[2016-05-15T08:49:03.419Z]: (1463302143419): memmrk:    23458464    64784896
xdk:client:[2016-05-15T08:49:05.207Z]: (1463302145207): memmrk:    36249652    68868736
xdk:server:[2016-05-15T08:49:08.420Z]: (1463302148420): memmrk:    30213248    64784896
xdk:client:[2016-05-15T08:49:10.236Z]: (1463302150236): memmrk:    31793176    68868736
xdk:server:[2016-05-15T08:49:13.420Z]: (1463302153420): memmrk:    56693792    72898176
xdk:client:[2016-05-15T08:49:15.748Z]: (1463302155748): Component "client:project-manager" finished delayed initialization
xdk:client:[2016-05-15T08:49:15.760Z]: (1463302155760): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-05-15T08:49:15.796Z]: (1463302155796): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-05-15T08:49:15.796Z]: (1463302155796): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-05-15T08:49:15.796Z]: (1463302155796): Component "client:projects-list" starting import
xdk:client:[2016-05-15T08:49:15.800Z]: (1463302155800): Component "client:projects-info" starting import
xdk:client:[2016-05-15T08:49:15.800Z]: (1463302155800): Component "client:projects-create-list" starting import
xdk:client:[2016-05-15T08:49:15.800Z]: (1463302155800): Component "client:projects-create-info" starting import
xdk:client:[2016-05-15T08:49:16.208Z]: (1463302156208): memmrk:    33812872    68868736
xdk:client:[2016-05-15T08:49:16.268Z]: (1463302156268): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-05-15T08:49:16.272Z]: (1463302156272): Component "client:projects-list" calling init()
xdk:client:[2016-05-15T08:49:16.276Z]: (1463302156276): Component "client:projects-list" finished initialization
xdk:client:[2016-05-15T08:49:16.292Z]: (1463302156292): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-05-15T08:49:16.292Z]: (1463302156292): Component "client:projects-info" calling init()
xdk:client:[2016-05-15T08:49:16.292Z]: (1463302156292): Component "client:projects-info" finished initialization
xdk:client:[2016-05-15T08:49:16.300Z]: (1463302156300): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-05-15T08:49:16.300Z]: (1463302156300): Component "client:projects-create-info" calling init()
xdk:client:[2016-05-15T08:49:16.300Z]: (1463302156300): Component "client:projects-create-info" finished initialization
xdk:client:[2016-05-15T08:49:16.304Z]: (1463302156304): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-05-15T08:49:16.304Z]: (1463302156304): Component "client:projects-create-list" calling init()
xdk:client:[2016-05-15T08:49:16.304Z]: (1463302156304): Component "client:projects-create-list" finished initialization
xdk:server:[2016-05-15T08:49:18.422Z]: (1463302158422): memmrk:    57286952    75945216
xdk:client:[2016-05-15T08:49:21.208Z]: (1463302161208): memmrk:    39051104    74950656
xdk:client:[2016-05-15T08:49:22.559Z]: (1463302162559): onExitRequest listener 1:
    at Object.exports.onExitRequest (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
    at Object.<anonymous> (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
    at Object.context.execCb (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
    at Object.Module.check (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
    at Object.<anonymous> (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
    at each (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
    at Object.Module.emit (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:server:[2016-05-15T08:49:23.423Z]: (1463302163423): memmrk:    57418296    75945216
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : Container provided by brackets :
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-05-15T08:49:25.477Z]: (1463302165477): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-05-15T08:49:25.573Z]: (1463302165573): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-05-15T08:49:25.573Z]: (1463302165573): Component "client:app" calling start()
xdk:client:[2016-05-15T08:49:25.605Z]: (1463302165605): Component "client:app" finished start()
xdk:client:[2016-05-15T08:49:25.605Z]: (1463302165605): Component "client:navbar" calling start()
xdk:client:[2016-05-15T08:49:25.625Z]: (1463302165625): Component "client:navbar" finished start()
xdk:client:[2016-05-15T08:49:25.625Z]: (1463302165625): Component "client:project-manager" calling start()
xdk:client:[2016-05-15T08:49:25.625Z]: (1463302165625): Component "client:project-manager" finished start()
xdk:client:[2016-05-15T08:49:25.625Z]: (1463302165625): Component "client:aa-controller" calling start()
xdk:client:[2016-05-15T08:49:25.625Z]: (1463302165629): Component "client:aa-controller" finished start()
xdk:client:[2016-05-15T08:49:25.629Z]: (1463302165629): Component "client:projects-tab" calling start()
xdk:client:[2016-05-15T08:49:25.637Z]: (1463302165637): Component "client:projects-tab" finished start()
xdk:client:[2016-05-15T08:49:25.637Z]: (1463302165637): Component "client:projects-list" calling start()
xdk:client:[2016-05-15T08:49:25.641Z]: (1463302165641): Component "client:projects-list" finished start()
xdk:client:[2016-05-15T08:49:25.641Z]: (1463302165641): Component "client:projects-info" calling start()
xdk:client:[2016-05-15T08:49:25.645Z]: (1463302165645): Component "client:projects-info" finished start()
xdk:client:[2016-05-15T08:49:25.645Z]: (1463302165645): Component "client:projects-create-list" calling start()
xdk:client:[2016-05-15T08:49:25.721Z]: (1463302165721): Component "client:projects-create-list" finished start()
xdk:client:[2016-05-15T08:49:25.721Z]: (1463302165721): Component "client:projects-create-info" calling start()
xdk:client:[2016-05-15T08:49:25.733Z]: (1463302165733): Component "client:projects-create-info" finished start()
xdk:client:[2016-05-15T08:49:25.733Z]: (1463302165733): Component "client:test-tab" calling start()
xdk:client:[2016-05-15T08:49:25.737Z]: (1463302165737): Component "client:test-tab" finished start()
xdk:client:[2016-05-15T08:49:25.737Z]: (1463302165737): Component "client:profilingTab" calling start()
xdk:client:[2016-05-15T08:49:25.817Z]: (1463302165817): Component "client:profilingTab" finished start()
xdk:client:[2016-05-15T08:49:25.817Z]: (1463302165817): Component "client:emulator" calling start()
xdk:client:[2016-05-15T08:49:25.821Z]: (1463302165821): Component "client:emulator" finished start()
xdk:client:[2016-05-15T08:49:25.821Z]: (1463302165821): Component "client:remote-tab" calling start()
xdk:client:[2016-05-15T08:49:25.825Z]: (1463302165825): onExitRequest listener 2:
    at Object.myExports.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
    at resumeClientInit (C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:12040)
    at C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\main.js:17:1734
xdk:client:[2016-05-15T08:49:25.829Z]: (1463302165829): Component "client:remote-tab" finished start()
xdk:client:[2016-05-15T08:49:25.829Z]: (1463302165829): Component "client:build-tab" calling start()
xdk:client:[2016-05-15T08:49:25.829Z]: (1463302165829): Component "client:build-tab" finished start()
xdk:client:[2016-05-15T08:49:25.829Z]: (1463302165829): Component "client:active-sync" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:active-sync" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:apk-installer" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:apk-installer" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-manager" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-manager" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-phaser" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-phaser" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-pixi" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-pixi" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-easeljs" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-easeljs" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-plain" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-plain" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-render-frame" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-render-frame" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-util" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:resource-util" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:bower-client" calling start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:bower-client" finished start()
xdk:client:[2016-05-15T08:49:25.833Z]: (1463302165833): Component "client:editor" calling start()
xdk:client:[2016-05-15T08:49:25.837Z]: (1463302165837): Component "client:editor" finished start()
xdk:client:[2016-05-15T08:49:25.837Z]: (1463302165837): Component "client:editor-tab" calling start()
xdk:client:[2016-05-15T08:49:25.873Z]: (1463302165873): Component "client:editor-tab" finished start()
xdk:client:[2016-05-15T08:49:25.873Z]: (1463302165873): Component "client:live-preview" calling start()
xdk:client:[2016-05-15T08:49:25.873Z]: (1463302165873): Component "client:live-preview" finished start()
xdk:client:[2016-05-15T08:49:25.873Z]: (1463302165873): Component "client:account" calling start()
xdk:client:[2016-05-15T08:49:25.877Z]: (1463302165877): Component "client:account" finished start()
xdk:client:[2016-05-15T08:49:25.877Z]: (1463302165877): Component "client:project-selector" calling start()
xdk:client:[2016-05-15T08:49:25.877Z]: (1463302165877): Component "client:project-selector" finished start()
xdk:client:[2016-05-15T08:49:25.877Z]: (1463302165877): Component "client:ui-builder-client" calling start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:ui-builder-client" finished start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:project-meta" calling start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:project-meta" finished start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:cordova-registry" calling start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:cordova-registry" finished start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:adb" calling start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:adb" finished start()
xdk:client:[2016-05-15T08:49:25.881Z]: (1463302165881): Component "client:iosdb" calling start()
xdk:client:[2016-05-15T08:49:25.885Z]: (1463302165885): Component "client:iosdb" finished start()
xdk:client:[2016-05-15T08:49:25.885Z]: (1463302165885): Component "client:device-discovery" calling start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): onExitRequest listener 3:
    at Object.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9195)
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:device-discovery" finished start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:test-local-server" calling start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:test-local-server" finished start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:quick-tour" calling start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:quick-tour" finished start()
xdk:client:[2016-05-15T08:49:25.889Z]: (1463302165889): Component "client:hot-keys" calling start()
xdk:client:[2016-05-15T08:49:25.893Z]: (1463302165893): Component "client:hot-keys" finished start()
xdk:client:[2016-05-15T08:49:25.893Z]: (1463302165893): Component "client:persistance" calling start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): onExit listener 4:
    at Object.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:persistance" finished start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:file-watcher" calling start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:file-watcher" finished start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:cordova" calling start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:cordova" finished start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:external-editors-runner" calling start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:external-editors-runner" finished start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:upload-manager" calling start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:upload-manager" finished start()
xdk:client:[2016-05-15T08:49:25.897Z]: (1463302165897): Component "client:publish-tab" calling start()
xdk:client:[2016-05-15T08:49:25.901Z]: (1463302165901): onExitRequest listener 5:
    at AutofillController.registerForEvents_ (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
    at new AutofillController (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
    at Object.myExports.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-05-15T08:49:25.953Z]: (1463302165953): Component "client:publish-tab" finished start()
xdk:client:[2016-05-15T08:49:25.953Z]: (1463302165957): Intel XDK is initialized now
client:build-tab:[2016-05-15T08:49:25.961Z]: (1463302165961): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
  code_: null,
  componentName_: null,
  stack_: 'Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)' }
client:build-tab:[2016-05-15T08:49:25.965Z]: (1463302165965): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2016-05-15T08:49:25.977Z]: (1463302165977): onExitRequest listener 6:
    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/project-manager/project-manager.js:18:10467
    at _fulfilled (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:834:54)
    at self.promiseDispatch.done (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:863:30)
    at Promise.promise.promiseDispatch (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:796:13)
    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:604:44
    at runSingle (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:137:13)
    at flush (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:125:13)
    at process._tickCallback (node.js:393:11)
xdk:client:[2016-05-15T08:49:26.209Z]: (1463302166209): memmrk:    55622276    78989056
client:publish-tab:[2016-05-15T08:49:28.050Z]: (1463302168050): Stores data feed has been successfully loaded.
client:adb:[2016-05-15T08:49:28.379Z]: (1463302168379): Rejected adb command with stderr error: device unauthorized. Please check the confirmation dialog on your device.
 "C:\Users\ASUS\AppData\Local\Intel\XDK\bin\adb\adb.exe" -s 2101c300b846a24a forward tcp:58890 tcp:9090
client:adb:[2016-05-15T08:49:28.383Z]: (1463302168383): Rejected adb command with stderr error: device unauthorized. Please check the confirmation dialog on your device.
 "C:\Users\ASUS\AppData\Local\Intel\XDK\bin\adb\adb.exe" -s 2101c300b846a24a shell cat /system/build.prop
client:adb:[2016-05-15T08:49:28.412Z]: (1463302168412): Rejected adb command with stderr error: device unauthorized. Please check the confirmation dialog on your device.
 "C:\Users\ASUS\AppData\Local\Intel\XDK\bin\adb\adb.exe" -s 2101c300b846a24a forward tcp:58891 tcp:9091
xdk:server:[2016-05-15T08:49:28.434Z]: (1463302168434): memmrk:    65968884    84046336
client:build-tab:[2016-05-15T08:49:28.458Z]: (1463302168458): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
  code_: null,
  stack_: 'Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:2905\n    at Promise.apply (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1165:26)\n    at Promise.promise.promiseDispatch (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:788:41)\n    at C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1391:14\n    at runSingle (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:137:13)\n    at flush (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:125:13)' }
client:build-tab:[2016-05-15T08:49:28.460Z]: (1463302168460): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
client:navbar:[2016-05-15T08:49:28.467Z]: (1463302168467): pollForUpdates called
client:services-tab:[2016-05-15T08:49:29.946Z]: (1463302169946): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2016-05-15T08:49:29.946Z]: (1463302169946): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2016-05-15T08:49:29.946Z]: (1463302169946): Both iframes loaded promise resolved.
client:services-tab:[2016-05-15T08:49:29.966Z]: (1463302169966): Calling postmessage for user refresh.
client:services-tab:[2016-05-15T08:49:29.966Z]: (1463302169966): main container window : true
client:services-tab:[2016-05-15T08:49:29.966Z]: (1463302169966): main container document : true
client:services-tab:[2016-05-15T08:49:29.966Z]: (1463302169966): component:services-tab:postMessageToWindow target = user
client:navbar:[2016-05-15T08:49:30.870Z]: (1463302170870): polling up-to-date
xdk:client:[2016-05-15T08:49:31.210Z]: (1463302171210): memmrk:    55665964    77961216
xdk:server:[2016-05-15T08:49:33.437Z]: (1463302173437): memmrk:    39089456    98253696
xdk:client:[2016-05-15T08:49:36.210Z]: (1463302176210): memmrk:    42838204    56199296
xdk:server:[2016-05-15T08:49:38.440Z]: (1463302178440): memmrk:    39100556    98253696
xdk:client:[2016-05-15T08:49:41.208Z]: (1463302181208): memmrk:    41900140    54192256
xdk:server:[2016-05-15T08:49:43.443Z]: (1463302183443): memmrk:    24759856    92159616
xdk:client:[2016-05-15T08:49:46.209Z]: (1463302186209): memmrk:    40633900    53188736
xdk:server:[2016-05-15T08:49:48.445Z]: (1463302188445): memmrk:    24771832    92159616
xdk:client:[2016-05-15T08:49:51.212Z]: (1463302191212): memmrk:    40944396    53188736
xdk:server:[2016-05-15T08:49:53.447Z]: (1463302193447): memmrk:    23113752    55138176
xdk:client:[2016-05-15T08:49:56.211Z]: (1463302196211): memmrk:    40931352    54237312
xdk:server:[2016-05-15T08:49:58.449Z]: (1463302198449): memmrk:    22184840    38887296
xdk:client:[2016-05-15T08:50:01.210Z]: (1463302201210): memmrk:    39414260    54237312
xdk:server:[2016-05-15T08:50:03.452Z]: (1463302203452): memmrk:    22204200    38887296
xdk:client:[2016-05-15T08:50:06.211Z]: (1463302206211): memmrk:    39600408    54237312
xdk:server:[2016-05-15T08:50:08.457Z]: (1463302208457): memmrk:    21521256    29758336
xdk:client:[2016-05-15T08:50:11.244Z]: (1463302211244): memmrk:    39778572    54237312
client:cordova:[2016-05-15T08:50:11.989Z]: (1463302211989): { xdkProjectStatus: 'all_same',
  pluginStatus:
   { 'cordova-plugin-device': 'same',
     'cordova-plugin-file': 'same',
     'cordova-plugin-splashscreen': 'same' } }
client:build-tab:[2016-05-15T08:50:12.861Z]: (1463302212861): [refreshPage] projectId wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg
client:build-tab:[2016-05-15T08:50:12.861Z]: (1463302212861): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2016-05-15T08:50:12.869Z]: (1463302212869): [getBuildTargets] Getting available targets for project wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg
client:build-tab:[2016-05-15T08:50:12.869Z]: (1463302212869): [refreshProjectInfo] Getting project info.
client:build-tab:[2016-05-15T08:50:12.873Z]: (1463302212873): [refreshBuildAssetsDate] Getting latest upload date for project files
builds:[2016-05-15T08:50:12.993Z]: (1463302212993): Error building UI for: certificateId
uib-client:[2016-05-15T08:50:13.157Z]: (1463302213157): gradeHTMLFile 1 /E/PFE/Source/MOBILESAMPLING-V1/www/index.html
client:build-tab:[2016-05-15T08:50:13.193Z]: (1463302213193): [getBuildTargets] Targets retrieved for project wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg
client:build-tab:[2016-05-15T08:50:13.241Z]: (1463302213241): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-05-15T08:50:13.241Z]: (1463302213241): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-05-15T08:50:13.245Z]: (1463302213245): [startUpdateStatusProcess] Starting build pulling process. Project: wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg
client:build-tab:[2016-05-15T08:50:13.245Z]: (1463302213245): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2016-05-15T08:50:13.249Z]: (1463302213249): [startUpdateStatusProcess] Starting polling. Project: wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg
xdk:server:[2016-05-15T08:50:13.457Z]: (1463302213457): memmrk:    23168500    30806912
client:remote-tab:[2016-05-15T08:50:13.725Z]: (1463302213725): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T08:50:13.725Z]: (1463302213725): emulator is shown for the project
client:emulator:[2016-05-15T08:50:13.725Z]: (1463302213725): MOBILESAMPLING-V1
client:emulator:[2016-05-15T08:50:14.093Z]: (1463302214093): Device Emulator :: Environment Warming Up (Tea. Earl Gray. Hot.)
client:emulator:[2016-05-15T08:50:14.797Z]: (1463302214797): appmobi_plus_cordova :: Emulator changing to project MOBILESAMPLING-V1
client:emulator:[2016-05-15T08:50:14.805Z]: (1463302214805): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
client:emulator:[2016-05-15T08:50:14.805Z]: (1463302214805): appmobi_plus_cordova :: Emulator changing to project MOBILESAMPLING-V1
xdk:client:[2016-05-15T08:50:16.213Z]: (1463302216213): memmrk:    62342356    78989056
xdk:client:[2016-05-15T08:50:21.217Z]: (1463302221217): memmrk:    62549832    78989056
xdk:server:[2016-05-15T08:50:23.293Z]: (1463302223293): memmrk:    37820524    55619456
xdk:client:[2016-05-15T08:50:26.217Z]: (1463302226217): memmrk:    63243032    78989056
xdk:client:[2016-05-15T08:50:31.220Z]: (1463302231220): memmrk:    63407712    78989056
xdk:client:[2016-05-15T08:50:36.218Z]: (1463302236218): memmrk:    63636212    78989056
xdk:client:[2016-05-15T08:50:41.223Z]: (1463302241223): memmrk:    60341628    80004736
client:build-service:[2016-05-15T08:50:46.258Z]: (1463302246258): [getBuilds] fail { message_: 'Http request timed out',
  code_: 2,
  componentName_: 'core:http-request',
  stack_: 'Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at XMLHttpRequest.<anonymous> (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\service\\http-request-xhr.js:17:2420)',
  status: 500,
  statusText: '500',
  responseText: 'No response body' }
client:build-service:[2016-05-15T08:50:46.262Z]: (1463302246262): [startUpdateStatusProcess] fail { statusCode: 500,
  projectId: 'wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg',
  data: undefined }
client:build-service:[2016-05-15T08:50:46.262Z]: (1463302246262): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2016-05-15T08:50:46.262Z]: (1463302246262): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
client:build-tab:[2016-05-15T08:50:46.266Z]: (1463302246266): [onBuildProcessFinish] failed 500
xdk:client:[2016-05-15T08:50:47.210Z]: (1463302247210): memmrk:    54639160    81020416
xdk:client:[2016-05-15T08:50:52.211Z]: (1463302252211): memmrk:    51760156    64288256
xdk:client:[2016-05-15T08:50:57.211Z]: (1463302257211): memmrk:    49829292    64288256
xdk:client:[2016-05-15T08:51:02.213Z]: (1463302262213): memmrk:    47603328    57239296
xdk:client:[2016-05-15T08:51:07.209Z]: (1463302267209): memmrk:    47051808    57239296
xdk:server:[2016-05-15T08:51:09.084Z]: (1463302269084): memmrk:    71027668    89076096
client:build-tab:[2016-05-15T08:51:10.767Z]: (1463302270771): [refreshBuildAssetsDate] latest upload date Thu Apr 21 2016 17:14:07 GMT+0200 (Paris, Madrid (heure d’été))
xdk:client:[2016-05-15T08:51:12.212Z]: (1463302272212): memmrk:    46368816    61400704
client:emulator:[2016-05-15T08:51:12.892Z]: (1463302272892): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T08:51:12.911Z]: (1463302272911): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:12.911Z]: (1463302272911): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T08:51:12.911Z]: (1463302272911): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T08:51:12.896Z]: (1463302272896): appmobi_plus_cordova :: frame appended to document
client:services-tab:[2016-05-15T08:51:12.948Z]: (1463302272948): Calling postmessage for project refresh.
client:services-tab:[2016-05-15T08:51:12.948Z]: (1463302272948): sidebar container window : true
client:services-tab:[2016-05-15T08:51:12.948Z]: (1463302272948): sidebar container document : true
client:services-tab:[2016-05-15T08:51:12.948Z]: (1463302272948): main container window : true
client:services-tab:[2016-05-15T08:51:12.952Z]: (1463302272952): main container document : true
client:services-tab:[2016-05-15T08:51:12.952Z]: (1463302272952): component:services-tab:postMessageToWindow target = project
server:emulator-webserver:[2016-05-15T08:51:13.891Z]: (1463302273891): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.891Z]: (1463302273891): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:51:13.891Z]: (1463302273891): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:51:13.895Z]: (1463302273895): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.895Z]: (1463302273895): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T08:51:13.895Z]: (1463302273895): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T08:51:13.899Z]: (1463302273899): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.899Z]: (1463302273899): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T08:51:13.899Z]: (1463302273899): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T08:51:13.903Z]: (1463302273903): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.903Z]: (1463302273903): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T08:51:13.903Z]: (1463302273903): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T08:51:13.915Z]: (1463302273915): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.915Z]: (1463302273915): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T08:51:13.915Z]: (1463302273915): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T08:51:13.919Z]: (1463302273919): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.919Z]: (1463302273919): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T08:51:13.923Z]: (1463302273923): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T08:51:13.927Z]: (1463302273927): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.927Z]: (1463302273927): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T08:51:13.927Z]: (1463302273927): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T08:51:13.935Z]: (1463302273935): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.935Z]: (1463302273935): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T08:51:13.939Z]: (1463302273939): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T08:51:13.939Z]: (1463302273939): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.939Z]: (1463302273939): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:51:13.939Z]: (1463302273939): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:51:13.959Z]: (1463302273959): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:13.959Z]: (1463302273959): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T08:51:13.959Z]: (1463302273959): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
xdk:server:[2016-05-15T08:51:14.087Z]: (1463302274087): memmrk:    87380204    106912384
server:emulator-webserver:[2016-05-15T08:51:15.395Z]: (1463302275395): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.395Z]: (1463302275395): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T08:51:15.395Z]: (1463302275395): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T08:51:15.415Z]: (1463302275415): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.415Z]: (1463302275415): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:51:15.415Z]: (1463302275415): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:51:15.451Z]: (1463302275451): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.451Z]: (1463302275451): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:51:15.451Z]: (1463302275451): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:51:15.451Z]: (1463302275451): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:51:15.455Z]: (1463302275455): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:51:15.475Z]: (1463302275475): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.475Z]: (1463302275475): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:51:15.475Z]: (1463302275475): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:51:15.583Z]: (1463302275583): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.583Z]: (1463302275583): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:51:15.583Z]: (1463302275583): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:51:15.627Z]: (1463302275627): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.627Z]: (1463302275627): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:51:15.627Z]: (1463302275627): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:51:15.671Z]: (1463302275671): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.671Z]: (1463302275671): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:51:15.671Z]: (1463302275671): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:51:15.675Z]: (1463302275675): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.679Z]: (1463302275679): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:51:15.679Z]: (1463302275679): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:51:15.679Z]: (1463302275679): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.679Z]: (1463302275679): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:51:15.679Z]: (1463302275679): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:51:15.683Z]: (1463302275683): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.683Z]: (1463302275683): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:51:15.683Z]: (1463302275683): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:51:15.691Z]: (1463302275691): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.691Z]: (1463302275691): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.691Z]: (1463302275691): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.691Z]: (1463302275691): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:51:15.695Z]: (1463302275695): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:51:15.695Z]: (1463302275695): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.695Z]: (1463302275695): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:51:15.695Z]: (1463302275695): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:51:15.699Z]: (1463302275699): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.699Z]: (1463302275699): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:51:15.699Z]: (1463302275699): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:51:15.703Z]: (1463302275703): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.707Z]: (1463302275707): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:51:15.711Z]: (1463302275711): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:51:15.715Z]: (1463302275715): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.715Z]: (1463302275715): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:51:15.715Z]: (1463302275715): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:51:15.723Z]: (1463302275723): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.723Z]: (1463302275723): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:51:15.723Z]: (1463302275723): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:51:15.727Z]: (1463302275727): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.727Z]: (1463302275727): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.727Z]: (1463302275727): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.731Z]: (1463302275731): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.731Z]: (1463302275731): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:51:15.731Z]: (1463302275731): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:51:15.731Z]: (1463302275731): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:51:15.735Z]: (1463302275735): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:51:15.751Z]: (1463302275751): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.751Z]: (1463302275751): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.755Z]: (1463302275755): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:51:15.755Z]: (1463302275755): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.755Z]: (1463302275755): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:51:15.755Z]: (1463302275755): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:51:15.759Z]: (1463302275759): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:51:15.759Z]: (1463302275759): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T08:51:15.759Z]: (1463302275759): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
client:emulator:[2016-05-15T08:51:15.772Z]: (1463302275772): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T08:51:15.784Z]: (1463302275784): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T08:51:16.212Z]: (1463302276212): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T08:51:16.216Z]: (1463302276216): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2016-05-15T08:51:17.212Z]: (1463302277212): memmrk:    67889616    92217216
xdk:server:[2016-05-15T08:51:19.090Z]: (1463302279090): memmrk:    86477516    108943744
xdk:client:[2016-05-15T08:51:22.211Z]: (1463302282211): memmrk:    68190124    92217216
xdk:server:[2016-05-15T08:51:24.091Z]: (1463302284091): memmrk:    87113292    108943744
xdk:client:[2016-05-15T08:51:27.211Z]: (1463302287211): memmrk:    68401752    92217216
xdk:server:[2016-05-15T08:51:29.092Z]: (1463302289092): memmrk:    87125012    108943744
xdk:client:[2016-05-15T08:51:32.332Z]: (1463302292332): memmrk:    66507736    76488576
xdk:server:[2016-05-15T08:51:34.095Z]: (1463302294095): memmrk:    87133248    108943744
xdk:client:[2016-05-15T08:51:38.210Z]: (1463302298210): memmrk:    66801008    76488576
xdk:server:[2016-05-15T08:51:39.095Z]: (1463302299095): memmrk:    56454328    106318336
xdk:client:[2016-05-15T08:51:43.209Z]: (1463302303209): memmrk:    64111096    76500736
xdk:server:[2016-05-15T08:51:44.097Z]: (1463302304097): memmrk:    52857724    87032576
xdk:client:[2016-05-15T08:51:48.210Z]: (1463302308210): memmrk:    64470324    76500736
xdk:server:[2016-05-15T08:51:49.097Z]: (1463302309097): memmrk:    52866136    87032576
xdk:client:[2016-05-15T08:51:53.208Z]: (1463302313208): memmrk:    60089028    74493696
xdk:server:[2016-05-15T08:51:54.100Z]: (1463302314100): memmrk:    51571504    86016896
xdk:client:[2016-05-15T08:51:58.209Z]: (1463302318209): memmrk:    60433036    74493696
xdk:server:[2016-05-15T08:51:59.102Z]: (1463302319102): memmrk:    51578796    86016896
xdk:client:[2016-05-15T08:52:03.211Z]: (1463302323211): memmrk:    59712180    72474496
xdk:server:[2016-05-15T08:52:04.102Z]: (1463302324102): memmrk:    51585848    86016896
xdk:client:[2016-05-15T08:52:08.211Z]: (1463302328211): memmrk:    59979092    69460352
xdk:server:[2016-05-15T08:52:09.106Z]: (1463302329106): memmrk:    51592900    86016896
xdk:client:[2016-05-15T08:52:13.209Z]: (1463302333209): memmrk:    57352444    69460352
xdk:server:[2016-05-15T08:52:14.106Z]: (1463302334106): memmrk:    51599952    86016896
xdk:client:[2016-05-15T08:52:18.209Z]: (1463302338209): memmrk:    57649384    69460352
xdk:server:[2016-05-15T08:52:19.107Z]: (1463302339107): memmrk:    51606988    86016896
xdk:client:[2016-05-15T08:52:23.209Z]: (1463302343209): memmrk:    57888200    69460352
xdk:server:[2016-05-15T08:52:24.107Z]: (1463302344107): memmrk:    51614040    86016896
xdk:client:[2016-05-15T08:52:28.211Z]: (1463302348211): memmrk:    58102160    69460352
xdk:server:[2016-05-15T08:52:29.108Z]: (1463302349108): memmrk:    51622164    86016896
xdk:client:[2016-05-15T08:52:33.211Z]: (1463302353211): memmrk:    58254000    69460352
xdk:server:[2016-05-15T08:52:34.110Z]: (1463302354110): memmrk:    51629216    86016896
xdk:client:[2016-05-15T08:52:38.215Z]: (1463302358215): memmrk:    58467124    69460352
xdk:server:[2016-05-15T08:52:39.111Z]: (1463302359111): memmrk:    51636268    86016896
xdk:client:[2016-05-15T08:52:43.216Z]: (1463302363216): memmrk:    57868832    69460352
xdk:server:[2016-05-15T08:52:44.112Z]: (1463302364112): memmrk:    51643320    86016896
xdk:client:[2016-05-15T08:52:48.217Z]: (1463302368217): memmrk:    58090444    69460352
xdk:server:[2016-05-15T08:52:49.113Z]: (1463302369113): memmrk:    51650372    86016896
xdk:client:[2016-05-15T08:52:53.218Z]: (1463302373218): memmrk:    58242244    69460352
xdk:server:[2016-05-15T08:52:54.116Z]: (1463302374116): memmrk:    51657424    86016896
xdk:client:[2016-05-15T08:52:58.218Z]: (1463302378218): memmrk:    58465756    69460352
xdk:server:[2016-05-15T08:52:59.117Z]: (1463302379117): memmrk:    51664460    86016896
xdk:client:[2016-05-15T08:53:03.221Z]: (1463302383221): memmrk:    58618900    69460352
xdk:server:[2016-05-15T08:53:04.117Z]: (1463302384117): memmrk:    51671496    86016896
xdk:client:[2016-05-15T08:53:08.223Z]: (1463302388223): memmrk:    58227808    69460352
xdk:server:[2016-05-15T08:53:09.119Z]: (1463302389119): memmrk:    51678548    86016896
xdk:client:[2016-05-15T08:53:13.225Z]: (1463302393225): memmrk:    58379948    69460352
xdk:server:[2016-05-15T08:53:14.121Z]: (1463302394121): memmrk:    51685600    86016896
xdk:client:[2016-05-15T08:53:18.228Z]: (1463302398228): memmrk:    58588060    69460352
xdk:server:[2016-05-15T08:53:19.124Z]: (1463302399124): memmrk:    51692636    86016896
xdk:client:[2016-05-15T08:53:23.229Z]: (1463302403229): memmrk:    58750980    69460352
xdk:server:[2016-05-15T08:53:24.126Z]: (1463302404126): memmrk:    51699672    86016896
xdk:client:[2016-05-15T08:53:28.232Z]: (1463302408232): memmrk:    58994920    69460352
xdk:server:[2016-05-15T08:53:29.129Z]: (1463302409129): memmrk:    51706708    86016896
xdk:client:[2016-05-15T08:53:33.235Z]: (1463302413235): memmrk:    58473684    69460352
xdk:server:[2016-05-15T08:53:34.131Z]: (1463302414131): memmrk:    51713744    86016896
xdk:client:[2016-05-15T08:53:38.235Z]: (1463302418235): memmrk:    58681964    69460352
xdk:server:[2016-05-15T08:53:39.131Z]: (1463302419131): memmrk:    51720780    86016896
xdk:client:[2016-05-15T08:53:43.238Z]: (1463302423238): memmrk:    58833228    69460352
xdk:server:[2016-05-15T08:53:44.132Z]: (1463302424132): memmrk:    51727800    86016896
xdk:client:[2016-05-15T08:53:48.238Z]: (1463302428238): memmrk:    59074652    69460352
xdk:server:[2016-05-15T08:53:49.134Z]: (1463302429134): memmrk:    51736416    86016896
xdk:client:[2016-05-15T08:53:53.242Z]: (1463302433242): memmrk:    59225660    69460352
xdk:server:[2016-05-15T08:53:54.137Z]: (1463302434137): memmrk:    51744668    86016896
xdk:client:[2016-05-15T08:53:58.242Z]: (1463302438242): memmrk:    58800752    71557504
xdk:server:[2016-05-15T08:53:59.139Z]: (1463302439139): memmrk:    51753384    86016896
xdk:client:[2016-05-15T08:54:03.245Z]: (1463302443245): memmrk:    58952688    71557504
xdk:server:[2016-05-15T08:54:04.143Z]: (1463302444143): memmrk:    51761240    86016896
xdk:client:[2016-05-15T08:54:08.247Z]: (1463302448247): memmrk:    59161364    71557504
xdk:server:[2016-05-15T08:54:09.143Z]: (1463302449143): memmrk:    51771320    86016896
xdk:client:[2016-05-15T08:54:13.247Z]: (1463302453247): memmrk:    59312404    71557504
xdk:server:[2016-05-15T08:54:14.146Z]: (1463302454146): memmrk:    51778356    86016896
xdk:client:[2016-05-15T08:54:18.249Z]: (1463302458249): memmrk:    59540964    71557504
xdk:server:[2016-05-15T08:54:19.148Z]: (1463302459148): memmrk:    51785368    86016896
xdk:client:[2016-05-15T08:54:23.250Z]: (1463302463250): memmrk:    59692008    71557504
xdk:server:[2016-05-15T08:54:24.150Z]: (1463302464150): memmrk:    51792380    86016896
xdk:client:[2016-05-15T08:54:28.254Z]: (1463302468254): memmrk:    60059640    71557504
xdk:server:[2016-05-15T08:54:29.149Z]: (1463302469149): memmrk:    51799392    86016896
xdk:client:[2016-05-15T08:54:33.254Z]: (1463302473254): memmrk:    60210664    71557504
xdk:server:[2016-05-15T08:54:34.151Z]: (1463302474151): memmrk:    51806404    86016896
xdk:client:[2016-05-15T08:54:38.256Z]: (1463302478256): memmrk:    60418160    71557504
xdk:server:[2016-05-15T08:54:39.154Z]: (1463302479154): memmrk:    51813416    86016896
xdk:client:[2016-05-15T08:54:43.259Z]: (1463302483259): memmrk:    60567760    71557504
xdk:server:[2016-05-15T08:54:44.154Z]: (1463302484154): memmrk:    51820428    86016896
xdk:client:[2016-05-15T08:54:48.262Z]: (1463302488262): memmrk:    60775272    71557504
xdk:server:[2016-05-15T08:54:49.158Z]: (1463302489158): memmrk:    51827424    86016896
xdk:client:[2016-05-15T08:54:53.264Z]: (1463302493264): memmrk:    62132300    71557504
xdk:server:[2016-05-15T08:54:54.159Z]: (1463302494159): memmrk:    51834436    86016896
xdk:client:[2016-05-15T08:54:58.266Z]: (1463302498266): memmrk:    62395728    71557504
xdk:server:[2016-05-15T08:54:59.161Z]: (1463302499161): memmrk:    51841448    86016896
xdk:client:[2016-05-15T08:55:03.266Z]: (1463302503266): memmrk:    62550116    71557504
xdk:server:[2016-05-15T08:55:04.162Z]: (1463302504162): memmrk:    51850032    86016896
xdk:client:[2016-05-15T08:55:08.270Z]: (1463302508270): memmrk:    62763668    71557504
xdk:server:[2016-05-15T08:55:09.163Z]: (1463302509163): memmrk:    51857076    86016896
xdk:client:[2016-05-15T08:55:13.272Z]: (1463302513272): memmrk:    60426604    72573184
xdk:server:[2016-05-15T08:55:14.163Z]: (1463302514163): memmrk:    51864104    86016896
xdk:client:[2016-05-15T08:55:18.273Z]: (1463302518273): memmrk:    60752296    72573184
xdk:server:[2016-05-15T08:55:19.165Z]: (1463302519165): memmrk:    51871100    86016896
xdk:client:[2016-05-15T08:55:23.276Z]: (1463302523276): memmrk:    60905284    72573184
xdk:server:[2016-05-15T08:55:24.166Z]: (1463302524166): memmrk:    51878112    86016896
xdk:client:[2016-05-15T08:55:28.278Z]: (1463302528278): memmrk:    61116024    72573184
xdk:server:[2016-05-15T08:55:29.166Z]: (1463302529166): memmrk:    51885124    86016896
xdk:client:[2016-05-15T08:55:33.278Z]: (1463302533278): memmrk:    61278336    72573184
xdk:server:[2016-05-15T08:55:34.167Z]: (1463302534167): memmrk:    51892120    86016896
xdk:client:[2016-05-15T08:55:38.281Z]: (1463302538281): memmrk:    60321876    69427456
xdk:server:[2016-05-15T08:55:39.169Z]: (1463302539169): memmrk:    51899132    86016896
xdk:client:[2016-05-15T08:55:43.283Z]: (1463302543283): memmrk:    60517808    69427456
xdk:server:[2016-05-15T08:55:44.170Z]: (1463302544170): memmrk:    51906144    86016896
xdk:client:[2016-05-15T08:55:48.284Z]: (1463302548284): memmrk:    60730112    69427456
xdk:server:[2016-05-15T08:55:49.169Z]: (1463302549169): memmrk:    51913156    86016896
xdk:client:[2016-05-15T08:55:53.285Z]: (1463302553285): memmrk:    60880236    69427456
xdk:server:[2016-05-15T08:55:54.173Z]: (1463302554173): memmrk:    51920152    86016896
xdk:client:[2016-05-15T08:55:58.285Z]: (1463302558285): memmrk:    60037640    69427456
xdk:server:[2016-05-15T08:55:59.176Z]: (1463302559176): memmrk:    51927164    86016896
xdk:client:[2016-05-15T08:56:03.287Z]: (1463302563287): memmrk:    60265288    69427456
xdk:server:[2016-05-15T08:56:04.179Z]: (1463302564179): memmrk:    51934176    86016896
xdk:client:[2016-05-15T08:56:08.287Z]: (1463302568287): memmrk:    60518112    69427456
xdk:server:[2016-05-15T08:56:09.181Z]: (1463302569181): memmrk:    51941220    86016896
xdk:client:[2016-05-15T08:56:13.288Z]: (1463302573288): memmrk:    60669464    69427456
xdk:server:[2016-05-15T08:56:14.184Z]: (1463302574184): memmrk:    51948248    86016896
xdk:client:[2016-05-15T08:56:18.290Z]: (1463302578290): memmrk:    60891508    69427456
xdk:server:[2016-05-15T08:56:19.184Z]: (1463302579184): memmrk:    51955260    86016896
xdk:client:[2016-05-15T08:56:23.292Z]: (1463302583292): memmrk:    60146360    69427456
xdk:server:[2016-05-15T08:56:24.184Z]: (1463302584184): memmrk:    52025200    86016896
xdk:client:[2016-05-15T08:56:28.292Z]: (1463302588292): memmrk:    60402408    69427456
xdk:server:[2016-05-15T08:56:29.187Z]: (1463302589187): memmrk:    52035496    86016896
xdk:client:[2016-05-15T08:56:33.293Z]: (1463302593293): memmrk:    60555712    69427456
xdk:server:[2016-05-15T08:56:34.191Z]: (1463302594191): memmrk:    52048676    86016896
xdk:client:[2016-05-15T08:56:38.295Z]: (1463302598295): memmrk:    60778516    69427456
xdk:server:[2016-05-15T08:56:39.194Z]: (1463302599194): memmrk:    52055688    86016896
xdk:client:[2016-05-15T08:56:43.295Z]: (1463302603295): memmrk:    59944100    69427456
xdk:server:[2016-05-15T08:56:44.197Z]: (1463302604197): memmrk:    52062700    86016896
xdk:client:[2016-05-15T08:56:48.297Z]: (1463302608297): memmrk:    60227528    69427456
xdk:server:[2016-05-15T08:56:49.200Z]: (1463302609200): memmrk:    52069712    86016896
xdk:client:[2016-05-15T08:56:53.296Z]: (1463302613296): memmrk:    60324712    68444672
xdk:server:[2016-05-15T08:56:54.201Z]: (1463302614201): memmrk:    52079396    86016896
xdk:client:[2016-05-15T08:56:58.297Z]: (1463302618297): memmrk:    57685660    68444672
xdk:server:[2016-05-15T08:56:59.201Z]: (1463302619201): memmrk:    52086408    86016896
xdk:client:[2016-05-15T08:57:03.298Z]: (1463302623298): memmrk:    57840284    68444672
xdk:server:[2016-05-15T08:57:04.202Z]: (1463302624202): memmrk:    52093404    86016896
xdk:client:[2016-05-15T08:57:08.300Z]: (1463302628300): memmrk:    58048428    68444672
xdk:server:[2016-05-15T08:57:09.205Z]: (1463302629205): memmrk:    52100448    86016896
xdk:client:[2016-05-15T08:57:13.300Z]: (1463302633300): memmrk:    58198444    68444672
xdk:server:[2016-05-15T08:57:14.205Z]: (1463302634205): memmrk:    52107476    86016896
xdk:client:[2016-05-15T08:57:18.304Z]: (1463302638304): memmrk:    58407928    68444672
xdk:server:[2016-05-15T08:57:19.208Z]: (1463302639208): memmrk:    52114472    86016896
xdk:client:[2016-05-15T08:57:23.305Z]: (1463302643305): memmrk:    58560068    68444672
xdk:server:[2016-05-15T08:57:24.208Z]: (1463302644208): memmrk:    52121484    86016896
xdk:client:[2016-05-15T08:57:28.305Z]: (1463302648305): memmrk:    58017628    68444672
xdk:server:[2016-05-15T08:57:29.211Z]: (1463302649211): memmrk:    52128480    86016896
xdk:client:[2016-05-15T08:57:33.309Z]: (1463302653309): memmrk:    58168652    68444672
xdk:server:[2016-05-15T08:57:34.210Z]: (1463302654210): memmrk:    52135492    86016896
xdk:client:[2016-05-15T08:57:38.308Z]: (1463302658308): memmrk:    58379464    68444672
xdk:server:[2016-05-15T08:57:39.212Z]: (1463302659212): memmrk:    52158104    86016896
xdk:client:[2016-05-15T08:57:43.310Z]: (1463302663310): memmrk:    58531296    68444672
xdk:server:[2016-05-15T08:57:44.212Z]: (1463302664212): memmrk:    52165128    86016896
xdk:client:[2016-05-15T08:57:48.310Z]: (1463302668310): memmrk:    58137388    70541824
xdk:server:[2016-05-15T08:57:49.214Z]: (1463302669214): memmrk:    52171964    86016896
xdk:client:[2016-05-15T08:57:53.312Z]: (1463302673312): memmrk:    58327980    70541824
xdk:server:[2016-05-15T08:57:54.214Z]: (1463302674214): memmrk:    52178816    86016896
xdk:client:[2016-05-15T08:57:58.313Z]: (1463302678313): memmrk:    58539604    70541824
xdk:server:[2016-05-15T08:57:59.216Z]: (1463302679216): memmrk:    52185652    86016896
xdk:client:[2016-05-15T08:58:03.314Z]: (1463302683314): memmrk:    58945708    70541824
xdk:server:[2016-05-15T08:58:04.216Z]: (1463302684216): memmrk:    52192504    86016896
xdk:client:[2016-05-15T08:58:08.316Z]: (1463302688316): memmrk:    59222056    70541824
xdk:server:[2016-05-15T08:58:09.218Z]: (1463302689218): memmrk:    52204612    86016896
xdk:client:[2016-05-15T08:58:13.320Z]: (1463302693320): memmrk:    59426916    70541824
xdk:server:[2016-05-15T08:58:14.221Z]: (1463302694221): memmrk:    52211480    86016896
client:remote-tab:[2016-05-15T08:58:14.864Z]: (1463302694864): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-05-15T08:58:18.341Z]: (1463302698341): memmrk:    62300352    72561024
xdk:server:[2016-05-15T08:58:19.224Z]: (1463302699224): memmrk:    52537672    86016896
xdk:client:[2016-05-15T08:58:23.346Z]: (1463302703346): memmrk:    61806504    74592384
xdk:server:[2016-05-15T08:58:24.227Z]: (1463302704227): memmrk:    52544524    86016896
xdk:client:[2016-05-15T08:58:28.349Z]: (1463302708349): memmrk:    62986596    74592384
xdk:server:[2016-05-15T08:58:29.226Z]: (1463302709226): memmrk:    52551376    86016896
xdk:client:[2016-05-15T08:58:33.352Z]: (1463302713352): memmrk:    67462296    79790208
xdk:server:[2016-05-15T08:58:34.229Z]: (1463302714229): memmrk:    52558228    86016896
xdk:client:[2016-05-15T08:58:38.354Z]: (1463302718354): memmrk:    69329116    79790208
xdk:server:[2016-05-15T08:58:39.230Z]: (1463302719230): memmrk:    52565080    86016896
xdk:client:[2016-05-15T08:58:43.367Z]: (1463302723367): memmrk:    68990016    79790208
xdk:server:[2016-05-15T08:58:44.230Z]: (1463302724230): memmrk:    52571932    86016896
xdk:client:[2016-05-15T08:58:48.356Z]: (1463302728356): memmrk:    67459160    80805888
xdk:server:[2016-05-15T08:58:49.234Z]: (1463302729234): memmrk:    52578768    86016896
xdk:client:[2016-05-15T08:58:53.358Z]: (1463302733358): memmrk:    69709504    81809408
xdk:server:[2016-05-15T08:58:54.235Z]: (1463302734235): memmrk:    52585620    86016896
client:remote-tab:[2016-05-15T08:58:57.988Z]: (1463302737988): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T08:58:57.992Z]: (1463302737992): emulator is shown for the project
client:emulator:[2016-05-15T08:58:57.992Z]: (1463302737992): MOBILESAMPLING-V1
client:emulator:[2016-05-15T08:58:57.996Z]: (1463302737996): appmobi_plus_cordova :: Emulator restarting MOBILESAMPLING-V1
client:emulator:[2016-05-15T08:58:58.004Z]: (1463302738004): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
xdk:client:[2016-05-15T08:58:58.360Z]: (1463302738360): memmrk:    71296184    81809408
xdk:server:[2016-05-15T08:59:00.718Z]: (1463302740718): memmrk:    46285988    86016896
client:emulator:[2016-05-15T08:59:00.726Z]: (1463302740726): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T08:59:00.742Z]: (1463302740742): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.742Z]: (1463302740742): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T08:59:00.742Z]: (1463302740742): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T08:59:00.730Z]: (1463302740730): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2016-05-15T08:59:00.834Z]: (1463302740834): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.834Z]: (1463302740834): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:59:00.834Z]: (1463302740834): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:59:00.906Z]: (1463302740906): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.906Z]: (1463302740906): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T08:59:00.910Z]: (1463302740910): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T08:59:00.914Z]: (1463302740914): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.914Z]: (1463302740914): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T08:59:00.914Z]: (1463302740914): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T08:59:00.914Z]: (1463302740914): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T08:59:00.914Z]: (1463302740914): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T08:59:00.926Z]: (1463302740926): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.926Z]: (1463302740926): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T08:59:00.926Z]: (1463302740926): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T08:59:00.934Z]: (1463302740934): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.934Z]: (1463302740934): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T08:59:00.934Z]: (1463302740934): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:59:00.934Z]: (1463302740934): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:59:00.938Z]: (1463302740938): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T08:59:00.946Z]: (1463302740946): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:00.946Z]: (1463302740946): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T08:59:00.946Z]: (1463302740946): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T08:59:02.178Z]: (1463302742178): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.178Z]: (1463302742178): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T08:59:02.178Z]: (1463302742178): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T08:59:02.186Z]: (1463302742186): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.186Z]: (1463302742186): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:59:02.186Z]: (1463302742186): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:59:02.218Z]: (1463302742218): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.218Z]: (1463302742218): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:59:02.218Z]: (1463302742218): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:59:02.222Z]: (1463302742222): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:59:02.222Z]: (1463302742222): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:59:02.250Z]: (1463302742250): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.250Z]: (1463302742250): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:59:02.250Z]: (1463302742250): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:59:02.334Z]: (1463302742334): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.334Z]: (1463302742334): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:59:02.334Z]: (1463302742334): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:59:02.382Z]: (1463302742382): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.382Z]: (1463302742382): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:59:02.382Z]: (1463302742382): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:59:02.422Z]: (1463302742422): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.422Z]: (1463302742422): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:59:02.422Z]: (1463302742422): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:59:02.426Z]: (1463302742426): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.426Z]: (1463302742426): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:59:02.426Z]: (1463302742426): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.430Z]: (1463302742430): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.442Z]: (1463302742442): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.442Z]: (1463302742442): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:59:02.442Z]: (1463302742442): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:59:02.442Z]: (1463302742442): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:59:02.442Z]: (1463302742442): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:59:02.446Z]: (1463302742446): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.446Z]: (1463302742446): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:59:02.446Z]: (1463302742446): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:59:02.446Z]: (1463302742446): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:59:02.446Z]: (1463302742446): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:59:02.450Z]: (1463302742450): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.450Z]: (1463302742450): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.450Z]: (1463302742450): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.458Z]: (1463302742458): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.458Z]: (1463302742458): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:59:02.458Z]: (1463302742458): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:59:02.462Z]: (1463302742462): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.462Z]: (1463302742462): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:59:02.462Z]: (1463302742462): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:59:02.462Z]: (1463302742462): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:59:02.462Z]: (1463302742462): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:59:02.466Z]: (1463302742466): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.466Z]: (1463302742466): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.466Z]: (1463302742466): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.470Z]: (1463302742470): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.470Z]: (1463302742470): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:59:02.470Z]: (1463302742470): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:59:02.482Z]: (1463302742482): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.482Z]: (1463302742482): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:59:02.482Z]: (1463302742482): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:59:02.486Z]: (1463302742486): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.486Z]: (1463302742486): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.486Z]: (1463302742486): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:02.490Z]: (1463302742490): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:02.490Z]: (1463302742490): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:59:02.490Z]: (1463302742490): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:59:02.490Z]: (1463302742490): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T08:59:02.490Z]: (1463302742490): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
client:emulator:[2016-05-15T08:59:02.510Z]: (1463302742510): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T08:59:02.518Z]: (1463302742518): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T08:59:02.534Z]: (1463302742534): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T08:59:02.534Z]: (1463302742534): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2016-05-15T08:59:03.360Z]: (1463302743360): memmrk:    92099904    110462976
xdk:server:[2016-05-15T08:59:05.723Z]: (1463302745723): memmrk:    53515324    86016896
xdk:client:[2016-05-15T08:59:08.362Z]: (1463302748362): memmrk:    92314276    110462976
xdk:server:[2016-05-15T08:59:10.726Z]: (1463302750726): memmrk:    53522192    86016896
xdk:client:[2016-05-15T08:59:13.363Z]: (1463302753363): memmrk:    92566700    110462976
server:emulator-webserver:[2016-05-15T08:59:13.938Z]: (1463302753938): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:13.938Z]: (1463302753938): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T08:59:13.938Z]: (1463302753938): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T08:59:14.006Z]: (1463302754006): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.006Z]: (1463302754006): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:59:14.006Z]: (1463302754006): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T08:59:14.006Z]: (1463302754006): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T08:59:14.010Z]: (1463302754010): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T08:59:14.018Z]: (1463302754018): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.018Z]: (1463302754018): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:59:14.026Z]: (1463302754026): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T08:59:14.026Z]: (1463302754026): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.026Z]: (1463302754026): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T08:59:14.026Z]: (1463302754026): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T08:59:14.026Z]: (1463302754026): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T08:59:14.030Z]: (1463302754030): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T08:59:14.034Z]: (1463302754034): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.034Z]: (1463302754034): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:59:14.034Z]: (1463302754034): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T08:59:14.062Z]: (1463302754062): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.062Z]: (1463302754062): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:59:14.062Z]: (1463302754062): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T08:59:14.074Z]: (1463302754074): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.074Z]: (1463302754074): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:59:14.074Z]: (1463302754074): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T08:59:14.082Z]: (1463302754082): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.082Z]: (1463302754082): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:59:14.082Z]: (1463302754082): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T08:59:14.090Z]: (1463302754090): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.090Z]: (1463302754090): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:59:14.094Z]: (1463302754094): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T08:59:14.178Z]: (1463302754178): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.178Z]: (1463302754178): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:59:14.178Z]: (1463302754178): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T08:59:14.262Z]: (1463302754262): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.262Z]: (1463302754262): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:59:14.262Z]: (1463302754262): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T08:59:14.266Z]: (1463302754266): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.266Z]: (1463302754266): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:59:14.266Z]: (1463302754266): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T08:59:14.270Z]: (1463302754270): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.270Z]: (1463302754270): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:59:14.270Z]: (1463302754270): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T08:59:14.270Z]: (1463302754270): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:59:14.270Z]: (1463302754270): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T08:59:14.278Z]: (1463302754278): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.278Z]: (1463302754278): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.282Z]: (1463302754282): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.286Z]: (1463302754286): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.286Z]: (1463302754286): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:59:14.286Z]: (1463302754286): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T08:59:14.290Z]: (1463302754290): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.290Z]: (1463302754290): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:59:14.290Z]: (1463302754290): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T08:59:14.290Z]: (1463302754290): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:59:14.290Z]: (1463302754290): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T08:59:14.298Z]: (1463302754298): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.298Z]: (1463302754298): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:59:14.298Z]: (1463302754298): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T08:59:14.306Z]: (1463302754306): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.306Z]: (1463302754306): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.306Z]: (1463302754306): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.306Z]: (1463302754310): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.310Z]: (1463302754310): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:59:14.310Z]: (1463302754310): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T08:59:14.310Z]: (1463302754310): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.310Z]: (1463302754310): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:59:14.310Z]: (1463302754310): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T08:59:14.318Z]: (1463302754318): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.318Z]: (1463302754318): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:59:14.318Z]: (1463302754318): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T08:59:14.326Z]: (1463302754326): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.326Z]: (1463302754326): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.326Z]: (1463302754326): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.326Z]: (1463302754326): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:59:14.326Z]: (1463302754326): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T08:59:14.330Z]: (1463302754330): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.330Z]: (1463302754330): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:59:14.330Z]: (1463302754330): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T08:59:14.334Z]: (1463302754334): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.334Z]: (1463302754334): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.334Z]: (1463302754334): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T08:59:14.338Z]: (1463302754338): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.338Z]: (1463302754338): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:59:14.342Z]: (1463302754342): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T08:59:14.346Z]: (1463302754346): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.346Z]: (1463302754346): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T08:59:14.346Z]: (1463302754346): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T08:59:14.442Z]: (1463302754442): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.442Z]: (1463302754442): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T08:59:14.442Z]: (1463302754442): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T08:59:14.446Z]: (1463302754446): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.446Z]: (1463302754446): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T08:59:14.446Z]: (1463302754446): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T08:59:14.474Z]: (1463302754474): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.474Z]: (1463302754474): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T08:59:14.474Z]: (1463302754474): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T08:59:14.478Z]: (1463302754478): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T08:59:14.478Z]: (1463302754478): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T08:59:14.478Z]: (1463302754478): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T08:59:14.478Z]: (1463302754478): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
server:emulator-webserver:[2016-05-15T08:59:14.478Z]: (1463302754478): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
xdk:server:[2016-05-15T08:59:15.727Z]: (1463302755727): memmrk:    53286300    86016896
xdk:server:[2016-05-15T08:59:20.728Z]: (1463302760728): memmrk:    53293312    86016896
client:emulator:[2016-05-15T08:59:21.023Z]: (1463302761023): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T08:59:21.027Z]: (1463302761027): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T08:59:21.031Z]: (1463302761031): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T08:59:21.031Z]: (1463302761031): appmobi_plus_cordova :: [emulator] file watcher started
client:emulator:[2016-05-15T08:59:21.223Z]: (1463302761223): appmobi_plus_cordova :: hideSplashScreen called
xdk:client:[2016-05-15T08:59:24.899Z]: (1463302764899): memmrk:    94259700    111466496
xdk:server:[2016-05-15T08:59:25.729Z]: (1463302765729): memmrk:    53300180    86016896
xdk:client:[2016-05-15T08:59:29.902Z]: (1463302769902): memmrk:    94420940    111466496
xdk:server:[2016-05-15T08:59:30.728Z]: (1463302770728): memmrk:    53307064    86016896
client:remote-tab:[2016-05-15T08:59:32.682Z]: (1463302772682): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-05-15T08:59:34.902Z]: (1463302774902): memmrk:    95306644    111466496
xdk:server:[2016-05-15T08:59:35.732Z]: (1463302775732): memmrk:    53439204    86016896
xdk:client:[2016-05-15T08:59:39.955Z]: (1463302779955): memmrk:    80268856    112482176
xdk:server:[2016-05-15T08:59:40.734Z]: (1463302780734): memmrk:    53446088    86016896
xdk:client:[2016-05-15T08:59:44.961Z]: (1463302784961): memmrk:    85695424    112482176
xdk:server:[2016-05-15T08:59:45.735Z]: (1463302785735): memmrk:    53452972    86016896
xdk:client:[2016-05-15T08:59:49.962Z]: (1463302789962): memmrk:    87128224    112482176
xdk:server:[2016-05-15T08:59:50.737Z]: (1463302790737): memmrk:    53459856    86016896
xdk:client:[2016-05-15T08:59:54.964Z]: (1463302794964): memmrk:    82061980    112482176
xdk:server:[2016-05-15T08:59:55.739Z]: (1463302795739): memmrk:    53466720    86016896
xdk:client:[2016-05-15T08:59:59.962Z]: (1463302799962): memmrk:    84271456    112482176
xdk:server:[2016-05-15T09:00:00.741Z]: (1463302800741): memmrk:    53473556    86016896
xdk:client:[2016-05-15T09:00:04.969Z]: (1463302804969): memmrk:    84939096    112482176
xdk:server:[2016-05-15T09:00:05.743Z]: (1463302805743): memmrk:    53482108    86016896
uib-client:[2016-05-15T09:00:06.046Z]: (1463302806046): gradeHTMLFile 1 /E/PFE/Source/MOBILESAMPLING-V1/www/accueil.html
xdk:client:[2016-05-15T09:00:09.969Z]: (1463302809969): memmrk:    87613028    113497856
xdk:server:[2016-05-15T09:00:10.746Z]: (1463302810746): memmrk:    54001356    86016896
xdk:client:[2016-05-15T09:00:14.970Z]: (1463302814970): memmrk:    88706676    113497856
xdk:server:[2016-05-15T09:00:15.748Z]: (1463302815748): memmrk:    54008216    86016896
xdk:client:[2016-05-15T09:00:19.974Z]: (1463302819974): memmrk:    92292392    114501376
xdk:server:[2016-05-15T09:00:20.751Z]: (1463302820751): memmrk:    54015076    86016896
xdk:client:[2016-05-15T09:00:24.976Z]: (1463302824976): memmrk:    91177480    114501376
xdk:server:[2016-05-15T09:00:25.753Z]: (1463302825753): memmrk:    54021936    86016896
xdk:client:[2016-05-15T09:00:29.978Z]: (1463302829978): memmrk:    94582536    114501376
xdk:server:[2016-05-15T09:00:30.753Z]: (1463302830753): memmrk:    54028780    86016896
xdk:client:[2016-05-15T09:00:34.983Z]: (1463302834983): memmrk:    98225296    114501376
client:remote-tab:[2016-05-15T09:00:35.219Z]: (1463302835219): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:00:35.219Z]: (1463302835219): emulator is shown for the project
client:emulator:[2016-05-15T09:00:35.219Z]: (1463302835219): MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:00:35.223Z]: (1463302835223): appmobi_plus_cordova :: Emulator restarting MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:00:35.227Z]: (1463302835227): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
xdk:server:[2016-05-15T09:00:37.632Z]: (1463302837632): memmrk:    56150800    87032576
client:emulator:[2016-05-15T09:00:37.635Z]: (1463302837635): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T09:00:37.652Z]: (1463302837652): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.652Z]: (1463302837652): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T09:00:37.652Z]: (1463302837652): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T09:00:37.639Z]: (1463302837639): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2016-05-15T09:00:37.716Z]: (1463302837716): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.716Z]: (1463302837716): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:00:37.720Z]: (1463302837720): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:00:37.720Z]: (1463302837720): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.720Z]: (1463302837720): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:00:37.720Z]: (1463302837720): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:00:37.744Z]: (1463302837744): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.744Z]: (1463302837744): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:00:37.744Z]: (1463302837744): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:00:37.772Z]: (1463302837772): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.772Z]: (1463302837772): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:00:37.772Z]: (1463302837772): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:00:37.772Z]: (1463302837772): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:00:37.772Z]: (1463302837772): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:00:37.792Z]: (1463302837792): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.792Z]: (1463302837792): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:00:37.796Z]: (1463302837796): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:00:37.796Z]: (1463302837796): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.796Z]: (1463302837796): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:00:37.796Z]: (1463302837796): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:00:37.796Z]: (1463302837796): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:00:37.800Z]: (1463302837800): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:00:37.808Z]: (1463302837808): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.808Z]: (1463302837808): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:00:37.808Z]: (1463302837808): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:00:37.816Z]: (1463302837816): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:37.816Z]: (1463302837816): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:00:37.820Z]: (1463302837820): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:00:38.696Z]: (1463302838696): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.696Z]: (1463302838696): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:00:38.696Z]: (1463302838696): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:00:38.740Z]: (1463302838740): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.740Z]: (1463302838740): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:00:38.740Z]: (1463302838740): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:00:38.784Z]: (1463302838784): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.784Z]: (1463302838784): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:00:38.784Z]: (1463302838784): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:00:38.784Z]: (1463302838784): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:00:38.788Z]: (1463302838788): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:00:38.832Z]: (1463302838832): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.832Z]: (1463302838832): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:00:38.832Z]: (1463302838832): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:00:38.880Z]: (1463302838880): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.880Z]: (1463302838880): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:00:38.880Z]: (1463302838880): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:00:38.964Z]: (1463302838964): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:00:38.968Z]: (1463302838968): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:00:38.980Z]: (1463302838980): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.980Z]: (1463302838980): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:38.980Z]: (1463302838980): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:38.980Z]: (1463302838980): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:00:38.980Z]: (1463302838980): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:00:38.984Z]: (1463302838984): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:00:38.996Z]: (1463302838996): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:38.996Z]: (1463302838996): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:38.996Z]: (1463302838996): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:39.000Z]: (1463302839000): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:39.000Z]: (1463302839000): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:00:39.000Z]: (1463302839000): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:00:39.000Z]: (1463302839000): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:00:39.000Z]: (1463302839000): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:00:39.004Z]: (1463302839004): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:39.004Z]: (1463302839004): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:00:39.004Z]: (1463302839004): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:00:39.004Z]: (1463302839004): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:39.004Z]: (1463302839004): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:39.016Z]: (1463302839016): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:39.016Z]: (1463302839016): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:00:39.016Z]: (1463302839016): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:00:39.016Z]: (1463302839016): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:00:39.016Z]: (1463302839016): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:00:39.020Z]: (1463302839020): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:39.020Z]: (1463302839020): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:39.020Z]: (1463302839020): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:39.020Z]: (1463302839020): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:00:39.020Z]: (1463302839020): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:00:39.024Z]: (1463302839024): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:39.024Z]: (1463302839024): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:00:39.024Z]: (1463302839024): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
client:emulator:[2016-05-15T09:00:39.052Z]: (1463302839052): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:00:39.056Z]: (1463302839056): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:00:39.064Z]: (1463302839064): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:00:39.064Z]: (1463302839064): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2016-05-15T09:00:39.986Z]: (1463302839986): memmrk:    112185928    132734976
xdk:server:[2016-05-15T09:00:42.634Z]: (1463302842634): memmrk:    55290968    87032576
xdk:client:[2016-05-15T09:00:44.987Z]: (1463302844987): memmrk:    112371764    132734976
xdk:server:[2016-05-15T09:00:47.635Z]: (1463302847635): memmrk:    55311228    87032576
xdk:client:[2016-05-15T09:00:49.986Z]: (1463302849986): memmrk:    112559588    132734976
xdk:server:[2016-05-15T09:00:52.637Z]: (1463302852637): memmrk:    56544636    87032576
xdk:client:[2016-05-15T09:00:54.988Z]: (1463302854988): memmrk:    112823512    132734976
server:emulator-webserver:[2016-05-15T09:00:56.186Z]: (1463302856186): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.186Z]: (1463302856186): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:00:56.186Z]: (1463302856186): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:00:56.251Z]: (1463302856251): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.251Z]: (1463302856251): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:00:56.251Z]: (1463302856251): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:00:56.253Z]: (1463302856253): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.253Z]: (1463302856253): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:00:56.257Z]: (1463302856257): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:00:56.272Z]: (1463302856272): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.272Z]: (1463302856272): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:00:56.272Z]: (1463302856272): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:00:56.275Z]: (1463302856275): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.275Z]: (1463302856275): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:00:56.275Z]: (1463302856275): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:00:56.278Z]: (1463302856278): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.278Z]: (1463302856278): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:00:56.278Z]: (1463302856278): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:00:56.291Z]: (1463302856291): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.291Z]: (1463302856291): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:00:56.292Z]: (1463302856292): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:00:56.325Z]: (1463302856325): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.325Z]: (1463302856325): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:00:56.325Z]: (1463302856325): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:00:56.325Z]: (1463302856325): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:00:56.325Z]: (1463302856325): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:00:56.345Z]: (1463302856345): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.345Z]: (1463302856345): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:00:56.345Z]: (1463302856345): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:00:56.429Z]: (1463302856429): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.429Z]: (1463302856429): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:00:56.433Z]: (1463302856433): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:00:56.513Z]: (1463302856513): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.513Z]: (1463302856513): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:00:56.517Z]: (1463302856517): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:00:56.517Z]: (1463302856517): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.517Z]: (1463302856517): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:00:56.517Z]: (1463302856517): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:00:56.525Z]: (1463302856525): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.525Z]: (1463302856525): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:00:56.525Z]: (1463302856525): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:00:56.533Z]: (1463302856533): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.533Z]: (1463302856533): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:00:56.533Z]: (1463302856533): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:00:56.545Z]: (1463302856545): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.545Z]: (1463302856545): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:00:56.545Z]: (1463302856545): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:00:56.545Z]: (1463302856545): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.549Z]: (1463302856549): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.553Z]: (1463302856553): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.553Z]: (1463302856553): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:00:56.553Z]: (1463302856553): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:00:56.557Z]: (1463302856557): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.557Z]: (1463302856557): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:00:56.557Z]: (1463302856557): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:00:56.565Z]: (1463302856565): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.565Z]: (1463302856565): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:00:56.565Z]: (1463302856565): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:00:56.569Z]: (1463302856569): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.569Z]: (1463302856569): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:00:56.569Z]: (1463302856569): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:00:56.577Z]: (1463302856577): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.577Z]: (1463302856577): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.577Z]: (1463302856577): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.577Z]: (1463302856577): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:00:56.577Z]: (1463302856577): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:00:56.585Z]: (1463302856585): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.585Z]: (1463302856585): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:00:56.585Z]: (1463302856585): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:00:56.589Z]: (1463302856589): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.589Z]: (1463302856589): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:00:56.589Z]: (1463302856589): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:00:56.589Z]: (1463302856589): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.589Z]: (1463302856589): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.601Z]: (1463302856601): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.601Z]: (1463302856601): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:00:56.601Z]: (1463302856601): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:00:56.605Z]: (1463302856605): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.605Z]: (1463302856605): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:00:56.605Z]: (1463302856605): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:00:56.613Z]: (1463302856613): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.613Z]: (1463302856613): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.613Z]: (1463302856613): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:00:56.613Z]: (1463302856613): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:00:56.617Z]: (1463302856617): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:00:56.617Z]: (1463302856617): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.617Z]: (1463302856617): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:00:56.621Z]: (1463302856621): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:00:56.717Z]: (1463302856717): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.717Z]: (1463302856717): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:00:56.717Z]: (1463302856717): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:00:56.721Z]: (1463302856721): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.721Z]: (1463302856721): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:00:56.721Z]: (1463302856721): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:00:56.745Z]: (1463302856745): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.745Z]: (1463302856745): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:00:56.745Z]: (1463302856745): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:00:56.745Z]: (1463302856745): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:00:56.745Z]: (1463302856745): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:00:56.749Z]: (1463302856749): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:00:56.749Z]: (1463302856749): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
server:emulator-webserver:[2016-05-15T09:00:56.749Z]: (1463302856749): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
xdk:server:[2016-05-15T09:00:57.638Z]: (1463302857638): memmrk:    46653712    87032576
client:emulator:[2016-05-15T09:01:01.624Z]: (1463302861624): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:01:01.632Z]: (1463302861632): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:01:01.632Z]: (1463302861632): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:01:01.632Z]: (1463302861632): appmobi_plus_cordova :: [emulator] file watcher started
client:emulator:[2016-05-15T09:01:01.817Z]: (1463302861817): appmobi_plus_cordova :: hideSplashScreen called
xdk:server:[2016-05-15T09:01:02.638Z]: (1463302862638): memmrk:    48007216    87032576
xdk:client:[2016-05-15T09:01:04.858Z]: (1463302864858): memmrk:    114358688    132734976
xdk:server:[2016-05-15T09:01:07.641Z]: (1463302867641): memmrk:    48015804    87032576
xdk:client:[2016-05-15T09:01:09.860Z]: (1463302869860): memmrk:    114525428    132734976
xdk:server:[2016-05-15T09:01:12.640Z]: (1463302872640): memmrk:    46565724    87032576
xdk:client:[2016-05-15T09:01:14.860Z]: (1463302874860): memmrk:    114703316    132734976
client:remote-tab:[2016-05-15T09:01:15.200Z]: (1463302875200): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-05-15T09:01:17.642Z]: (1463302877642): memmrk:    46801496    87032576
xdk:client:[2016-05-15T09:01:19.860Z]: (1463302879860): memmrk:    115613220    132734976
xdk:server:[2016-05-15T09:01:22.645Z]: (1463302882645): memmrk:    46808624    87032576
xdk:client:[2016-05-15T09:01:24.864Z]: (1463302884864): memmrk:    119126124    135769856
client:remote-tab:[2016-05-15T09:01:27.436Z]: (1463302887436): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:01:27.436Z]: (1463302887436): emulator is shown for the project
client:emulator:[2016-05-15T09:01:27.440Z]: (1463302887440): MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:01:27.444Z]: (1463302887444): appmobi_plus_cordova :: Emulator restarting MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:01:27.444Z]: (1463302887444): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:01:29.865Z]: (1463302889865): memmrk:    121854772    135769856
xdk:server:[2016-05-15T09:01:30.417Z]: (1463302890417): memmrk:    46762380    63362304
client:emulator:[2016-05-15T09:01:30.421Z]: (1463302890421): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T09:01:30.437Z]: (1463302890437): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.437Z]: (1463302890437): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T09:01:30.437Z]: (1463302890437): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T09:01:30.425Z]: (1463302890425): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2016-05-15T09:01:30.505Z]: (1463302890505): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.505Z]: (1463302890505): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:01:30.505Z]: (1463302890505): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:01:30.505Z]: (1463302890505): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:01:30.509Z]: (1463302890509): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:01:30.533Z]: (1463302890533): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.533Z]: (1463302890533): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:01:30.533Z]: (1463302890533): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:01:30.561Z]: (1463302890561): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.561Z]: (1463302890561): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:01:30.561Z]: (1463302890561): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:01:30.561Z]: (1463302890561): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:01:30.561Z]: (1463302890561): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:01:30.569Z]: (1463302890569): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.569Z]: (1463302890569): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:01:30.569Z]: (1463302890569): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:01:30.569Z]: (1463302890569): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:01:30.569Z]: (1463302890569): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:01:30.573Z]: (1463302890573): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.573Z]: (1463302890573): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:01:30.577Z]: (1463302890577): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:01:30.585Z]: (1463302890585): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.585Z]: (1463302890585): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:01:30.585Z]: (1463302890585): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:01:30.597Z]: (1463302890597): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:30.597Z]: (1463302890597): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:01:30.597Z]: (1463302890597): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:01:31.565Z]: (1463302891565): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.565Z]: (1463302891565): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:01:31.565Z]: (1463302891565): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:01:31.573Z]: (1463302891573): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.573Z]: (1463302891573): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:01:31.573Z]: (1463302891573): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:01:31.597Z]: (1463302891597): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.597Z]: (1463302891597): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:01:31.597Z]: (1463302891597): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:01:31.601Z]: (1463302891601): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.601Z]: (1463302891601): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:01:31.601Z]: (1463302891601): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:01:31.625Z]: (1463302891625): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.625Z]: (1463302891625): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:01:31.625Z]: (1463302891625): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:01:31.709Z]: (1463302891709): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.709Z]: (1463302891709): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:01:31.709Z]: (1463302891709): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:01:31.749Z]: (1463302891749): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.749Z]: (1463302891749): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:01:31.749Z]: (1463302891749): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:01:31.789Z]: (1463302891789): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.789Z]: (1463302891789): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:01:31.789Z]: (1463302891789): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:01:31.789Z]: (1463302891789): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:01:31.789Z]: (1463302891789): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:01:31.793Z]: (1463302891793): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.797Z]: (1463302891797): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.805Z]: (1463302891805): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.805Z]: (1463302891805): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:01:31.809Z]: (1463302891809): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:01:31.809Z]: (1463302891813): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.813Z]: (1463302891813): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:01:31.813Z]: (1463302891813): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:01:31.813Z]: (1463302891813): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.813Z]: (1463302891813): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:01:31.813Z]: (1463302891813): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:01:31.817Z]: (1463302891817): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.817Z]: (1463302891817): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:01:31.817Z]: (1463302891817): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:01:31.817Z]: (1463302891817): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.817Z]: (1463302891817): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.833Z]: (1463302891833): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.833Z]: (1463302891833): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:01:31.833Z]: (1463302891833): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:01:31.833Z]: (1463302891833): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:01:31.837Z]: (1463302891837): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:01:31.837Z]: (1463302891837): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.837Z]: (1463302891837): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:01:31.837Z]: (1463302891837): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:01:31.837Z]: (1463302891837): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.841Z]: (1463302891841): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.841Z]: (1463302891841): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.841Z]: (1463302891841): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:01:31.845Z]: (1463302891845): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:01:31.853Z]: (1463302891853): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.853Z]: (1463302891853): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:01:31.853Z]: (1463302891853): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:01:31.857Z]: (1463302891857): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.857Z]: (1463302891857): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:31.861Z]: (1463302891861): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:31.861Z]: (1463302891861): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:01:31.861Z]: (1463302891861): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:01:31.861Z]: (1463302891861): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:01:31.861Z]: (1463302891861): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
client:emulator:[2016-05-15T09:01:31.874Z]: (1463302891874): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:01:31.878Z]: (1463302891878): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:01:31.886Z]: (1463302891886): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:01:31.886Z]: (1463302891886): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2016-05-15T09:01:34.867Z]: (1463302894867): memmrk:    107653360    147921536
xdk:server:[2016-05-15T09:01:35.422Z]: (1463302895422): memmrk:    47404716    64365824
xdk:client:[2016-05-15T09:01:39.869Z]: (1463302899869): memmrk:    107851740    147921536
xdk:server:[2016-05-15T09:01:40.425Z]: (1463302900425): memmrk:    48269280    64365824
xdk:client:[2016-05-15T09:01:44.869Z]: (1463302904869): memmrk:    108020224    147921536
xdk:server:[2016-05-15T09:01:45.426Z]: (1463302905426): memmrk:    48281432    64365824
server:emulator-webserver:[2016-05-15T09:01:48.832Z]: (1463302908832): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.832Z]: (1463302908832): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:01:48.832Z]: (1463302908832): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:01:48.884Z]: (1463302908884): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.884Z]: (1463302908884): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:01:48.884Z]: (1463302908884): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:01:48.888Z]: (1463302908888): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.888Z]: (1463302908888): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:01:48.892Z]: (1463302908892): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:01:48.904Z]: (1463302908904): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.904Z]: (1463302908904): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:01:48.904Z]: (1463302908904): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:01:48.912Z]: (1463302908912): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.912Z]: (1463302908912): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:01:48.912Z]: (1463302908912): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:01:48.916Z]: (1463302908916): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.916Z]: (1463302908916): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:01:48.916Z]: (1463302908916): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:01:48.924Z]: (1463302908924): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.924Z]: (1463302908924): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:01:48.924Z]: (1463302908924): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:01:48.952Z]: (1463302908952): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.952Z]: (1463302908952): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:01:48.952Z]: (1463302908952): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:01:48.964Z]: (1463302908964): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:48.964Z]: (1463302908964): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:01:48.964Z]: (1463302908964): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:01:49.020Z]: (1463302909020): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.020Z]: (1463302909020): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:01:49.020Z]: (1463302909020): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:01:49.064Z]: (1463302909064): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.064Z]: (1463302909064): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:01:49.064Z]: (1463302909064): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:01:49.108Z]: (1463302909108): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.108Z]: (1463302909108): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:01:49.108Z]: (1463302909108): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:01:49.160Z]: (1463302909160): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.160Z]: (1463302909160): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:01:49.160Z]: (1463302909160): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:01:49.164Z]: (1463302909164): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.164Z]: (1463302909164): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:01:49.164Z]: (1463302909164): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:01:49.164Z]: (1463302909164): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:01:49.168Z]: (1463302909168): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:01:49.168Z]: (1463302909168): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.168Z]: (1463302909168): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:01:49.168Z]: (1463302909168): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:01:49.180Z]: (1463302909180): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.180Z]: (1463302909180): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.180Z]: (1463302909180): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.180Z]: (1463302909180): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:01:49.180Z]: (1463302909180): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:01:49.184Z]: (1463302909184): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.184Z]: (1463302909184): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:01:49.184Z]: (1463302909184): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:01:49.184Z]: (1463302909184): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:01:49.184Z]: (1463302909184): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:01:49.196Z]: (1463302909196): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.196Z]: (1463302909196): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:01:49.196Z]: (1463302909196): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:01:49.200Z]: (1463302909200): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.200Z]: (1463302909200): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.200Z]: (1463302909200): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.200Z]: (1463302909200): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:01:49.200Z]: (1463302909200): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:01:49.204Z]: (1463302909204): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.204Z]: (1463302909204): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:01:49.204Z]: (1463302909204): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:01:49.216Z]: (1463302909216): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.216Z]: (1463302909216): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:01:49.216Z]: (1463302909216): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:01:49.216Z]: (1463302909216): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.216Z]: (1463302909216): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.220Z]: (1463302909220): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.220Z]: (1463302909220): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:01:49.220Z]: (1463302909220): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:01:49.220Z]: (1463302909220): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:01:49.220Z]: (1463302909220): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:01:49.224Z]: (1463302909224): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.224Z]: (1463302909224): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.224Z]: (1463302909224): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:01:49.236Z]: (1463302909236): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.236Z]: (1463302909236): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:01:49.236Z]: (1463302909236): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:01:49.236Z]: (1463302909236): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:01:49.236Z]: (1463302909236): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:01:49.332Z]: (1463302909332): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.332Z]: (1463302909332): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:01:49.332Z]: (1463302909332): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:01:49.336Z]: (1463302909336): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.336Z]: (1463302909336): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:01:49.336Z]: (1463302909336): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:01:49.360Z]: (1463302909360): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.360Z]: (1463302909360): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:01:49.360Z]: (1463302909360): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:01:49.364Z]: (1463302909364): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:01:49.364Z]: (1463302909364): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:01:49.364Z]: (1463302909364): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:01:49.364Z]: (1463302909364): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
server:emulator-webserver:[2016-05-15T09:01:49.364Z]: (1463302909364): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
xdk:server:[2016-05-15T09:01:50.427Z]: (1463302910427): memmrk:    48047616    68560128
client:emulator:[2016-05-15T09:01:53.851Z]: (1463302913851): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:01:53.855Z]: (1463302913855): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:01:53.859Z]: (1463302913859): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:01:53.859Z]: (1463302913859): appmobi_plus_cordova :: [emulator] file watcher started
client:emulator:[2016-05-15T09:01:54.055Z]: (1463302914055): appmobi_plus_cordova :: hideSplashScreen called
xdk:client:[2016-05-15T09:01:54.347Z]: (1463302914347): memmrk:    109696284    147921536
xdk:server:[2016-05-15T09:01:55.428Z]: (1463302915428): memmrk:    48057928    68560128
xdk:client:[2016-05-15T09:01:59.348Z]: (1463302919348): memmrk:    109866632    147921536
xdk:server:[2016-05-15T09:02:00.428Z]: (1463302920428): memmrk:    46084644    68560128
xdk:client:[2016-05-15T09:02:04.350Z]: (1463302924350): memmrk:    110022404    147921536
xdk:server:[2016-05-15T09:02:05.430Z]: (1463302925430): memmrk:    46097128    68560128
client:remote-tab:[2016-05-15T09:02:06.701Z]: (1463302926701): About to start needsDebugModule in addTabWatcher
client:remote-tab:[2016-05-15T09:02:07.996Z]: (1463302927996): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:02:07.996Z]: (1463302927996): emulator is shown for the project
client:emulator:[2016-05-15T09:02:07.996Z]: (1463302927996): MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:02:09.351Z]: (1463302929351): memmrk:    111629740    147921536
xdk:server:[2016-05-15T09:02:10.433Z]: (1463302930433): memmrk:    46989372    68560128
server:emulator-webserver:[2016-05-15T09:02:11.153Z]: (1463302931153): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:02:11.153Z]: (1463302931153): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:02:11.153Z]: (1463302931153): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:02:11.305Z]: (1463302931305): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:02:11.305Z]: (1463302931305): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:02:11.305Z]: (1463302931305): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:02:11.309Z]: (1463302931309): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:02:11.309Z]: (1463302931309): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:02:11.309Z]: (1463302931309): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo.all.min.js.map
xdk:client:[2016-05-15T09:02:14.350Z]: (1463302934350): memmrk:    100784448    131792256
xdk:server:[2016-05-15T09:02:15.433Z]: (1463302935433): memmrk:    47426616    63362304
xdk:client:[2016-05-15T09:02:19.351Z]: (1463302939351): memmrk:    102771492    131792256
xdk:server:[2016-05-15T09:02:20.436Z]: (1463302940436): memmrk:    46580692    63362304
xdk:client:[2016-05-15T09:02:24.354Z]: (1463302944354): memmrk:    102897268    131792256
xdk:server:[2016-05-15T09:02:25.440Z]: (1463302945440): memmrk:    45523276    63362304
xdk:client:[2016-05-15T09:02:29.356Z]: (1463302949356): memmrk:    103078964    131792256
xdk:server:[2016-05-15T09:02:30.441Z]: (1463302950441): memmrk:    44539960    63362304
xdk:client:[2016-05-15T09:02:34.358Z]: (1463302954358): memmrk:    103236972    131792256
xdk:server:[2016-05-15T09:02:35.442Z]: (1463302955442): memmrk:    44547200    63362304
xdk:client:[2016-05-15T09:02:39.359Z]: (1463302959359): memmrk:    103423356    131792256
xdk:server:[2016-05-15T09:02:40.446Z]: (1463302960446): memmrk:    44554076    63362304
xdk:client:[2016-05-15T09:02:44.362Z]: (1463302964362): memmrk:    103551424    131792256
xdk:server:[2016-05-15T09:02:45.447Z]: (1463302965447): memmrk:    44560952    63362304
xdk:client:[2016-05-15T09:02:50.154Z]: (1463302970154): memmrk:    86808144    122748416
xdk:server:[2016-05-15T09:02:50.447Z]: (1463302970447): memmrk:    44567828    63362304
xdk:client:[2016-05-15T09:02:55.325Z]: (1463302975325): memmrk:    86900908    123751936
xdk:server:[2016-05-15T09:02:55.449Z]: (1463302975449): memmrk:    44574688    63362304
xdk:server:[2016-05-15T09:03:00.452Z]: (1463302980452): memmrk:    44939028    63362304
xdk:client:[2016-05-15T09:03:00.620Z]: (1463302980620): memmrk:    88062328    123751936
server:emulator-webserver:[2016-05-15T09:03:00.824Z]: (1463302980824): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:00.824Z]: (1463302980824): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:00.824Z]: (1463302980824): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
client:emulator:[2016-05-15T09:03:00.864Z]: (1463302980864): appmobi_plus_cordova :: Emulator restarting MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:03:00.872Z]: (1463302980872): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:03:03.741Z]: (1463302983741): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T09:03:03.781Z]: (1463302983781): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:03.781Z]: (1463302983781): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T09:03:03.781Z]: (1463302983781): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T09:03:03.749Z]: (1463302983749): appmobi_plus_cordova :: frame appended to document
server:emulator-webserver:[2016-05-15T09:03:03.977Z]: (1463302983977): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:03.977Z]: (1463302983977): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:03.981Z]: (1463302983981): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:03.989Z]: (1463302983989): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:03.989Z]: (1463302983989): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:03:03.989Z]: (1463302983989): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.common-material.min.css
server:emulator-webserver:[2016-05-15T09:03:04.013Z]: (1463302984013): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.013Z]: (1463302984013): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:03:04.013Z]: (1463302984013): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.default.min.css
server:emulator-webserver:[2016-05-15T09:03:04.041Z]: (1463302984041): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.041Z]: (1463302984041): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:03:04.045Z]: (1463302984045): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.mobile.all.min.css
server:emulator-webserver:[2016-05-15T09:03:04.045Z]: (1463302984045): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.045Z]: (1463302984045): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:03:04.045Z]: (1463302984045): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/kendo.material.min.css
server:emulator-webserver:[2016-05-15T09:03:04.053Z]: (1463302984053): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.053Z]: (1463302984053): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:03:04.053Z]: (1463302984053): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/jquery.min.js
server:emulator-webserver:[2016-05-15T09:03:04.057Z]: (1463302984057): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.057Z]: (1463302984057): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:03:04.057Z]: (1463302984057): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js
server:emulator-webserver:[2016-05-15T09:03:04.061Z]: (1463302984061): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.061Z]: (1463302984061): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:03:04.065Z]: (1463302984065): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:03:04.073Z]: (1463302984073): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.073Z]: (1463302984073): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:03:04.073Z]: (1463302984073): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:03:04.085Z]: (1463302984085): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:04.085Z]: (1463302984085): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:03:04.085Z]: (1463302984085): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/businessman-xxl.png
server:emulator-webserver:[2016-05-15T09:03:05.245Z]: (1463302985245): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.245Z]: (1463302985245): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:03:05.245Z]: (1463302985245): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/kendo/styles/images/kendoui.woff
server:emulator-webserver:[2016-05-15T09:03:05.261Z]: (1463302985261): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.261Z]: (1463302985261): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:03:05.261Z]: (1463302985261): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:03:05.289Z]: (1463302985289): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.289Z]: (1463302985289): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:03:05.293Z]: (1463302985293): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:03:05.293Z]: (1463302985293): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.293Z]: (1463302985293): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:03:05.293Z]: (1463302985293): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:03:05.313Z]: (1463302985313): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.313Z]: (1463302985313): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:03:05.313Z]: (1463302985313): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:03:05.393Z]: (1463302985393): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.393Z]: (1463302985393): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:03:05.393Z]: (1463302985393): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:03:05.437Z]: (1463302985437): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.437Z]: (1463302985437): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:03:05.437Z]: (1463302985437): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
xdk:server:[2016-05-15T09:03:05.453Z]: (1463302985453): memmrk:    48957612    64365824
server:emulator-webserver:[2016-05-15T09:03:05.493Z]: (1463302985493): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.493Z]: (1463302985493): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:03:05.493Z]: (1463302985493): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:03:05.497Z]: (1463302985497): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.497Z]: (1463302985497): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:03:05.497Z]: (1463302985497): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:03:05.497Z]: (1463302985497): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:03:05.497Z]: (1463302985497): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:03:05.501Z]: (1463302985501): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.501Z]: (1463302985501): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:03:05.501Z]: (1463302985501): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:03:05.501Z]: (1463302985501): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.501Z]: (1463302985501): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.517Z]: (1463302985517): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.517Z]: (1463302985517): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:03:05.517Z]: (1463302985517): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:03:05.517Z]: (1463302985517): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:03:05.521Z]: (1463302985521): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:03:05.525Z]: (1463302985525): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.525Z]: (1463302985525): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.525Z]: (1463302985525): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.537Z]: (1463302985537): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.537Z]: (1463302985537): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:03:05.541Z]: (1463302985541): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:03:05.545Z]: (1463302985545): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.545Z]: (1463302985545): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.545Z]: (1463302985545): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.545Z]: (1463302985545): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:03:05.545Z]: (1463302985545): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:03:05.561Z]: (1463302985561): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.561Z]: (1463302985561): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:03:05.561Z]: (1463302985561): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:03:05.561Z]: (1463302985561): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.561Z]: (1463302985561): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:05.565Z]: (1463302985565): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.565Z]: (1463302985565): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:03:05.565Z]: (1463302985565): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:03:05.569Z]: (1463302985569): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:05.569Z]: (1463302985569): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:03:05.569Z]: (1463302985569): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
client:emulator:[2016-05-15T09:03:05.581Z]: (1463302985581): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:03:05.589Z]: (1463302985589): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:03:05.597Z]: (1463302985597): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:03:05.597Z]: (1463302985597): appmobi_plus_cordova :: [emulator] file watcher started
xdk:client:[2016-05-15T09:03:05.605Z]: (1463302985605): memmrk:    112553548    134875776
xdk:server:[2016-05-15T09:03:10.454Z]: (1463302990454): memmrk:    49496624    68560128
xdk:client:[2016-05-15T09:03:10.608Z]: (1463302990608): memmrk:    112763768    134875776
xdk:server:[2016-05-15T09:03:15.455Z]: (1463302995455): memmrk:    49503904    68560128
xdk:client:[2016-05-15T09:03:15.611Z]: (1463302995611): memmrk:    112966476    134875776
xdk:server:[2016-05-15T09:03:20.455Z]: (1463303000455): memmrk:    49510764    68560128
xdk:client:[2016-05-15T09:03:20.612Z]: (1463303000612): memmrk:    113235820    134875776
server:emulator-webserver:[2016-05-15T09:03:21.765Z]: (1463303001765): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.765Z]: (1463303001765): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:03:21.765Z]: (1463303001765): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html
server:emulator-webserver:[2016-05-15T09:03:21.825Z]: (1463303001825): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.825Z]: (1463303001825): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:21.825Z]: (1463303001825): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:21.829Z]: (1463303001829): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.829Z]: (1463303001829): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js
server:emulator-webserver:[2016-05-15T09:03:21.833Z]: (1463303001833): Send cordova.js from C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\components\server\emulator\resources\cordova.js
server:emulator-webserver:[2016-05-15T09:03:21.849Z]: (1463303001849): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.849Z]: (1463303001849): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:03:21.849Z]: (1463303001849): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js
server:emulator-webserver:[2016-05-15T09:03:21.849Z]: (1463303001849): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:03:21.849Z]: (1463303001849): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/init-app.js
server:emulator-webserver:[2016-05-15T09:03:21.853Z]: (1463303001853): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.853Z]: (1463303001853): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:03:21.853Z]: (1463303001853): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/xdk/init-dev.js
server:emulator-webserver:[2016-05-15T09:03:21.873Z]: (1463303001873): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.873Z]: (1463303001873): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:03:21.873Z]: (1463303001873): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova_plugins.js
server:emulator-webserver:[2016-05-15T09:03:21.901Z]: (1463303001901): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.901Z]: (1463303001901): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:03:21.905Z]: (1463303001905): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-device/www/device.js
server:emulator-webserver:[2016-05-15T09:03:21.913Z]: (1463303001913): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.913Z]: (1463303001913): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:03:21.913Z]: (1463303001913): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-splashscreen/www/splashscreen.js
server:emulator-webserver:[2016-05-15T09:03:21.925Z]: (1463303001925): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.925Z]: (1463303001925): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:03:21.925Z]: (1463303001925): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
server:emulator-webserver:[2016-05-15T09:03:21.933Z]: (1463303001933): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:21.933Z]: (1463303001933): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:03:21.933Z]: (1463303001933): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
server:emulator-webserver:[2016-05-15T09:03:22.017Z]: (1463303002017): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.017Z]: (1463303002017): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:03:22.017Z]: (1463303002017): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Entry.js
server:emulator-webserver:[2016-05-15T09:03:22.097Z]: (1463303002097): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.097Z]: (1463303002097): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:03:22.097Z]: (1463303002097): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/File.js
server:emulator-webserver:[2016-05-15T09:03:22.101Z]: (1463303002101): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.101Z]: (1463303002101): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:03:22.101Z]: (1463303002101): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileEntry.js
server:emulator-webserver:[2016-05-15T09:03:22.101Z]: (1463303002101): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:03:22.105Z]: (1463303002105): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileError.js
server:emulator-webserver:[2016-05-15T09:03:22.105Z]: (1463303002105): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.105Z]: (1463303002105): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:03:22.105Z]: (1463303002105): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileReader.js
server:emulator-webserver:[2016-05-15T09:03:22.113Z]: (1463303002113): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.113Z]: (1463303002113): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.113Z]: (1463303002113): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.117Z]: (1463303002117): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.117Z]: (1463303002117): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:03:22.117Z]: (1463303002117): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
server:emulator-webserver:[2016-05-15T09:03:22.121Z]: (1463303002121): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.121Z]: (1463303002121): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:03:22.121Z]: (1463303002121): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
server:emulator-webserver:[2016-05-15T09:03:22.121Z]: (1463303002121): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:03:22.121Z]: (1463303002121): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/FileWriter.js
server:emulator-webserver:[2016-05-15T09:03:22.129Z]: (1463303002129): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.129Z]: (1463303002129): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:03:22.129Z]: (1463303002129): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Flags.js
server:emulator-webserver:[2016-05-15T09:03:22.137Z]: (1463303002137): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.137Z]: (1463303002137): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.137Z]: (1463303002137): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.137Z]: (1463303002137): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:03:22.141Z]: (1463303002141): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/Metadata.js
server:emulator-webserver:[2016-05-15T09:03:22.141Z]: (1463303002141): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.141Z]: (1463303002141): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:03:22.141Z]: (1463303002141): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
server:emulator-webserver:[2016-05-15T09:03:22.149Z]: (1463303002149): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.149Z]: (1463303002149): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:03:22.149Z]: (1463303002149): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems.js
server:emulator-webserver:[2016-05-15T09:03:22.153Z]: (1463303002153): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.153Z]: (1463303002153): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.157Z]: (1463303002157): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.157Z]: (1463303002157): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.157Z]: (1463303002157): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:03:22.157Z]: (1463303002157): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
server:emulator-webserver:[2016-05-15T09:03:22.161Z]: (1463303002161): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.161Z]: (1463303002161): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:03:22.161Z]: (1463303002161): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/browser/isChrome.js
server:emulator-webserver:[2016-05-15T09:03:22.169Z]: (1463303002169): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.169Z]: (1463303002169): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.169Z]: (1463303002169): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
server:emulator-webserver:[2016-05-15T09:03:22.173Z]: (1463303002173): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.173Z]: (1463303002173): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:03:22.177Z]: (1463303002177): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
server:emulator-webserver:[2016-05-15T09:03:22.177Z]: (1463303002177): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.177Z]: (1463303002177): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:03:22.181Z]: (1463303002181): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
server:emulator-webserver:[2016-05-15T09:03:22.273Z]: (1463303002273): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.273Z]: (1463303002273): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:03:22.277Z]: (1463303002277): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Team-Members-Icon.png
server:emulator-webserver:[2016-05-15T09:03:22.277Z]: (1463303002277): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.277Z]: (1463303002277): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:03:22.277Z]: (1463303002277): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/reservation.png
server:emulator-webserver:[2016-05-15T09:03:22.301Z]: (1463303002301): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.301Z]: (1463303002301): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/case-icon.png
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/folder-documents-icon.png
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
server:emulator-webserver:[2016-05-15T09:03:22.305Z]: (1463303002305): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/images/Icone-chef-de-projet.png
xdk:server:[2016-05-15T09:03:25.459Z]: (1463303005459): memmrk:    48837652    69645568
client:emulator:[2016-05-15T09:03:26.778Z]: (1463303006778): appmobi_plus_cordova :: Emulation frame loaded
client:emulator:[2016-05-15T09:03:26.782Z]: (1463303006782): appmobi_plus_cordova :: fired appMobi.device.ready event!
client:emulator:[2016-05-15T09:03:26.790Z]: (1463303006790): appmobi_plus_cordova :: tinyHipposLoaded cleared _loading/_delayedproject
client:emulator:[2016-05-15T09:03:26.790Z]: (1463303006790): appmobi_plus_cordova :: [emulator] file watcher started
client:emulator:[2016-05-15T09:03:26.983Z]: (1463303006983): appmobi_plus_cordova :: hideSplashScreen called
xdk:client:[2016-05-15T09:03:30.078Z]: (1463303010078): memmrk:    114899024    135879296
xdk:server:[2016-05-15T09:03:30.462Z]: (1463303010462): memmrk:    49903312    69645568
xdk:client:[2016-05-15T09:03:35.080Z]: (1463303015080): memmrk:    115051592    135879296
xdk:server:[2016-05-15T09:03:35.465Z]: (1463303015465): memmrk:    49911696    69645568
xdk:server:[2016-05-15T09:03:40.467Z]: (1463303020467): memmrk:    46916700    69645568
xdk:client:[2016-05-15T09:03:42.508Z]: (1463303022508): memmrk:    98208964    130861696
server:emulator-webserver:[2016-05-15T09:03:42.755Z]: (1463303022755): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:42.755Z]: (1463303022755): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:42.755Z]: (1463303022755): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/css/app.css
server:emulator-webserver:[2016-05-15T09:03:42.871Z]: (1463303022871): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:42.871Z]: (1463303022871): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:03:42.871Z]: (1463303022871): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:03:42.875Z]: (1463303022875): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:03:42.875Z]: (1463303022875): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo.all.min.js.map
server:emulator-webserver:[2016-05-15T09:03:42.875Z]: (1463303022875): Other file request, fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/kendo.all.min.js.map
client:remote-tab:[2016-05-15T09:03:43.920Z]: (1463303023920): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-05-15T09:03:45.467Z]: (1463303025467): memmrk:    46743012    61289856
xdk:client:[2016-05-15T09:03:47.487Z]: (1463303027487): memmrk:    104255456    131865216
xdk:server:[2016-05-15T09:03:50.466Z]: (1463303030466): memmrk:    46757720    61289856
xdk:client:[2016-05-15T09:03:52.488Z]: (1463303032488): memmrk:    104639232    131865216
xdk:server:[2016-05-15T09:03:55.468Z]: (1463303035468): memmrk:    46125232    60286336
xdk:client:[2016-05-15T09:03:57.505Z]: (1463303037505): memmrk:    108700220    132868736
xdk:server:[2016-05-15T09:04:00.470Z]: (1463303040470): memmrk:    46132912    60286336
xdk:client:[2016-05-15T09:04:02.542Z]: (1463303042542): memmrk:    104541208    132868736
xdk:server:[2016-05-15T09:04:05.552Z]: (1463303045552): memmrk:    46025864    60286336
xdk:client:[2016-05-15T09:04:07.546Z]: (1463303047546): memmrk:    104871608    132868736
xdk:server:[2016-05-15T09:04:10.554Z]: (1463303050554): memmrk:    46034428    60286336
xdk:client:[2016-05-15T09:04:12.573Z]: (1463303052573): memmrk:    105017544    132868736
xdk:server:[2016-05-15T09:04:15.557Z]: (1463303055557): memmrk:    46042292    60286336
xdk:client:[2016-05-15T09:04:17.576Z]: (1463303057576): memmrk:    105174836    132868736
xdk:server:[2016-05-15T09:04:20.560Z]: (1463303060560): memmrk:    45731640    60286336
xdk:client:[2016-05-15T09:04:22.576Z]: (1463303062576): memmrk:    105320756    132868736
xdk:server:[2016-05-15T09:04:25.559Z]: (1463303065559): memmrk:    45875620    61334912
xdk:client:[2016-05-15T09:04:27.579Z]: (1463303067579): memmrk:    105478032    132868736
xdk:server:[2016-05-15T09:04:30.560Z]: (1463303070560): memmrk:    44918736    61334912
xdk:client:[2016-05-15T09:04:32.587Z]: (1463303072587): memmrk:    105897112    132868736
xdk:server:[2016-05-15T09:04:35.562Z]: (1463303075562): memmrk:    44926036    61334912
xdk:client:[2016-05-15T09:04:37.590Z]: (1463303077590): memmrk:    106557936    132868736
xdk:server:[2016-05-15T09:04:40.564Z]: (1463303080564): memmrk:    44932972    61334912
uib-client:[2016-05-15T09:04:42.547Z]: (1463303082547): gradeHTMLFile 1 /E/PFE/Source/MOBILESAMPLING-V1/www/detailspatients.html
xdk:client:[2016-05-15T09:04:42.591Z]: (1463303082591): memmrk:    114887320    136907136
xdk:server:[2016-05-15T09:04:45.567Z]: (1463303085567): memmrk:    45961624    61334912
xdk:client:[2016-05-15T09:04:47.590Z]: (1463303087590): memmrk:    110477392    136907136
xdk:server:[2016-05-15T09:04:50.569Z]: (1463303090569): memmrk:    45968560    61334912
xdk:client:[2016-05-15T09:04:52.593Z]: (1463303092593): memmrk:    112611720    137910656
xdk:server:[2016-05-15T09:04:55.569Z]: (1463303095569): memmrk:    45975496    61334912
xdk:client:[2016-05-15T09:04:57.593Z]: (1463303097593): memmrk:    112963380    137910656
xdk:server:[2016-05-15T09:05:00.571Z]: (1463303100571): memmrk:    45982400    61334912
xdk:client:[2016-05-15T09:05:02.593Z]: (1463303102593): memmrk:    115557560    137910656
xdk:server:[2016-05-15T09:05:05.572Z]: (1463303105572): memmrk:    45989336    61334912
xdk:client:[2016-05-15T09:05:07.596Z]: (1463303107596): memmrk:    111775692    137910656
xdk:server:[2016-05-15T09:05:10.572Z]: (1463303110572): memmrk:    45996272    61334912
xdk:client:[2016-05-15T09:05:12.596Z]: (1463303112596): memmrk:    111919256    137910656
xdk:server:[2016-05-15T09:05:15.575Z]: (1463303115575): memmrk:    46003176    61334912
xdk:client:[2016-05-15T09:05:17.600Z]: (1463303117600): memmrk:    112112316    137910656
xdk:server:[2016-05-15T09:05:20.577Z]: (1463303120577): memmrk:    46010096    61334912
client:remote-tab:[2016-05-15T09:05:22.185Z]: (1463303122185): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:05:22.185Z]: (1463303122185): emulator is shown for the project
client:emulator:[2016-05-15T09:05:22.189Z]: (1463303122189): MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:05:22.600Z]: (1463303122600): memmrk:    112573696    137910656
xdk:server:[2016-05-15T09:05:25.581Z]: (1463303125581): memmrk:    46148260    61334912
xdk:client:[2016-05-15T09:05:27.603Z]: (1463303127603): memmrk:    113070064    137910656
xdk:server:[2016-05-15T09:05:30.581Z]: (1463303130581): memmrk:    45592296    61334912
xdk:client:[2016-05-15T09:05:32.602Z]: (1463303132602): memmrk:    115909768    137910656
xdk:server:[2016-05-15T09:05:35.584Z]: (1463303135584): memmrk:    46257896    61334912
xdk:client:[2016-05-15T09:05:37.604Z]: (1463303137604): memmrk:    112392428    138926336
xdk:server:[2016-05-15T09:05:40.584Z]: (1463303140584): memmrk:    46264816    61334912
xdk:client:[2016-05-15T09:05:42.607Z]: (1463303142607): memmrk:    112514200    138926336
xdk:server:[2016-05-15T09:05:45.584Z]: (1463303145584): memmrk:    46271720    61334912
xdk:client:[2016-05-15T09:05:47.609Z]: (1463303147609): memmrk:    112697828    138926336
xdk:server:[2016-05-15T09:05:50.584Z]: (1463303150584): memmrk:    46278624    61334912
xdk:client:[2016-05-15T09:05:52.611Z]: (1463303152611): memmrk:    112819592    138926336
xdk:server:[2016-05-15T09:05:55.588Z]: (1463303155588): memmrk:    46285528    61334912
client:remote-tab:[2016-05-15T09:05:56.769Z]: (1463303156769): About to start needsDebugModule in addTabWatcher
xdk:client:[2016-05-15T09:05:57.610Z]: (1463303157610): memmrk:    113532860    138926336
xdk:server:[2016-05-15T09:06:00.591Z]: (1463303160591): memmrk:    46618584    61334912
xdk:client:[2016-05-15T09:06:02.614Z]: (1463303162614): memmrk:    114521712    138926336
uib-client:[2016-05-15T09:06:03.589Z]: (1463303163589): gradeHTMLFile 1 /E/PFE/Source/MOBILESAMPLING-V1/www/index.html
xdk:server:[2016-05-15T09:06:05.591Z]: (1463303165591): memmrk:    46338272    63432064
xdk:client:[2016-05-15T09:06:07.620Z]: (1463303167620): memmrk:    116023648    141961216
uib-client:[2016-05-15T09:06:07.652Z]: (1463303167652): gradeHTMLFile 1 /E/PFE/Source/MOBILESAMPLING-V1/www/accueil.html
xdk:server:[2016-05-15T09:06:10.593Z]: (1463303170593): memmrk:    46683336    63432064
xdk:client:[2016-05-15T09:06:12.626Z]: (1463303172626): memmrk:    117815972    141961216
xdk:server:[2016-05-15T09:06:15.593Z]: (1463303175593): memmrk:    46690256    63432064
xdk:client:[2016-05-15T09:06:17.627Z]: (1463303177627): memmrk:    119487696    142976896
xdk:server:[2016-05-15T09:06:20.593Z]: (1463303180593): memmrk:    46697160    63432064
client:remote-tab:[2016-05-15T09:06:20.880Z]: (1463303180880): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:06:20.880Z]: (1463303180880): emulator is shown for the project
client:emulator:[2016-05-15T09:06:20.880Z]: (1463303180880): MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:06:22.630Z]: (1463303182630): memmrk:    120332076    142976896
xdk:server:[2016-05-15T09:06:25.596Z]: (1463303185596): memmrk:    47030704    63432064
xdk:client:[2016-05-15T09:06:27.630Z]: (1463303187630): memmrk:    121272488    142976896
xdk:server:[2016-05-15T09:06:30.599Z]: (1463303190599): memmrk:    47037624    63432064
xdk:client:[2016-05-15T09:06:32.631Z]: (1463303192631): memmrk:    121691304    142976896
client:remote-tab:[2016-05-15T09:06:32.903Z]: (1463303192903): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-05-15T09:06:35.600Z]: (1463303195600): memmrk:    47371256    63432064
xdk:client:[2016-05-15T09:06:37.631Z]: (1463303197631): memmrk:    122238556    142976896
xdk:server:[2016-05-15T09:06:40.604Z]: (1463303200604): memmrk:    47378176    63432064
xdk:client:[2016-05-15T09:06:42.631Z]: (1463303202631): memmrk:    122374428    142976896
xdk:server:[2016-05-15T09:06:45.607Z]: (1463303205607): memmrk:    47385120    63432064
xdk:client:[2016-05-15T09:06:47.629Z]: (1463303207629): memmrk:    116353940    142976896
xdk:server:[2016-05-15T09:06:50.607Z]: (1463303210607): memmrk:    47392040    63432064
xdk:client:[2016-05-15T09:06:52.635Z]: (1463303212635): memmrk:    118048576    142976896
xdk:server:[2016-05-15T09:06:55.609Z]: (1463303215609): memmrk:    47398944    63432064
client:remote-tab:[2016-05-15T09:06:57.041Z]: (1463303217041): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:06:57.041Z]: (1463303217041): emulator is shown for the project
client:emulator:[2016-05-15T09:06:57.041Z]: (1463303217041): MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:06:57.639Z]: (1463303217639): memmrk:    118722364    143980416
xdk:server:[2016-05-15T09:07:00.611Z]: (1463303220611): memmrk:    47736232    63432064
xdk:client:[2016-05-15T09:07:02.640Z]: (1463303222640): memmrk:    119293776    143980416
xdk:server:[2016-05-15T09:07:05.614Z]: (1463303225614): memmrk:    47743168    63432064
xdk:client:[2016-05-15T09:07:07.641Z]: (1463303227641): memmrk:    119475224    143980416
xdk:server:[2016-05-15T09:07:10.615Z]: (1463303230615): memmrk:    47750104    63432064
xdk:client:[2016-05-15T09:07:12.642Z]: (1463303232642): memmrk:    119596988    143980416
xdk:server:[2016-05-15T09:07:15.614Z]: (1463303235614): memmrk:    47757024    63432064
xdk:client:[2016-05-15T09:07:17.642Z]: (1463303237642): memmrk:    119778420    143980416
xdk:server:[2016-05-15T09:07:20.615Z]: (1463303240615): memmrk:    47763928    63432064
xdk:client:[2016-05-15T09:07:22.643Z]: (1463303242643): memmrk:    119923504    143980416
xdk:server:[2016-05-15T09:07:25.616Z]: (1463303245616): memmrk:    47770832    63432064
xdk:client:[2016-05-15T09:07:27.646Z]: (1463303247646): memmrk:    120318916    143980416
xdk:server:[2016-05-15T09:07:30.617Z]: (1463303250617): memmrk:    47777752    63432064
xdk:client:[2016-05-15T09:07:32.646Z]: (1463303252646): memmrk:    121015740    143980416
xdk:server:[2016-05-15T09:07:35.619Z]: (1463303255619): memmrk:    47784672    63432064
xdk:client:[2016-05-15T09:07:37.650Z]: (1463303257650): memmrk:    121412456    143980416
xdk:server:[2016-05-15T09:07:40.621Z]: (1463303260621): memmrk:    47791592    63432064
xdk:client:[2016-05-15T09:07:42.652Z]: (1463303262652): memmrk:    121534220    143980416
xdk:server:[2016-05-15T09:07:45.621Z]: (1463303265621): memmrk:    47798512    63432064
xdk:client:[2016-05-15T09:07:47.656Z]: (1463303267656): memmrk:    121750640    143980416
xdk:server:[2016-05-15T09:07:50.621Z]: (1463303270621): memmrk:    47805416    63432064
xdk:client:[2016-05-15T09:07:52.707Z]: (1463303272707): memmrk:    121993952    143980416
xdk:server:[2016-05-15T09:07:55.622Z]: (1463303275622): memmrk:    47845732    63432064
xdk:client:[2016-05-15T09:07:57.708Z]: (1463303277708): memmrk:    122302404    143980416
xdk:server:[2016-05-15T09:08:00.625Z]: (1463303280625): memmrk:    47852652    63432064
xdk:client:[2016-05-15T09:08:02.710Z]: (1463303282710): memmrk:    122640044    143980416
xdk:server:[2016-05-15T09:08:05.625Z]: (1463303285625): memmrk:    47865196    63432064
xdk:client:[2016-05-15T09:08:07.714Z]: (1463303287714): memmrk:    108301132    143980416
xdk:server:[2016-05-15T09:08:10.627Z]: (1463303290627): memmrk:    47872116    63432064
xdk:client:[2016-05-15T09:08:12.716Z]: (1463303292716): memmrk:    108425700    143980416
xdk:server:[2016-05-15T09:08:15.630Z]: (1463303295630): memmrk:    47879036    63432064
xdk:client:[2016-05-15T09:08:17.721Z]: (1463303297721): memmrk:    109239200    143980416
xdk:server:[2016-05-15T09:08:20.632Z]: (1463303300632): memmrk:    47885956    63432064
xdk:client:[2016-05-15T09:08:22.724Z]: (1463303302724): memmrk:    109387420    143980416
xdk:server:[2016-05-15T09:08:25.635Z]: (1463303305635): memmrk:    47892876    63432064
xdk:client:[2016-05-15T09:08:27.725Z]: (1463303307725): memmrk:    109575464    143980416
xdk:server:[2016-05-15T09:08:30.638Z]: (1463303310638): memmrk:    47908216    63432064
xdk:client:[2016-05-15T09:08:32.726Z]: (1463303312726): memmrk:    109820932    143980416
xdk:server:[2016-05-15T09:08:35.641Z]: (1463303315641): memmrk:    47915136    63432064
xdk:client:[2016-05-15T09:08:37.728Z]: (1463303317728): memmrk:    110020660    143980416
xdk:server:[2016-05-15T09:08:40.641Z]: (1463303320641): memmrk:    47922056    63432064
xdk:client:[2016-05-15T09:08:42.729Z]: (1463303322729): memmrk:    110265884    143980416
xdk:server:[2016-05-15T09:08:45.645Z]: (1463303325645): memmrk:    47928960    63432064
xdk:client:[2016-05-15T09:08:47.729Z]: (1463303327729): memmrk:    110554872    143980416
xdk:server:[2016-05-15T09:08:50.647Z]: (1463303330647): memmrk:    47976016    63432064
xdk:client:[2016-05-15T09:08:52.729Z]: (1463303332729): memmrk:    110690408    143980416
xdk:server:[2016-05-15T09:08:55.646Z]: (1463303335646): memmrk:    47982936    63432064
xdk:client:[2016-05-15T09:08:57.732Z]: (1463303337732): memmrk:    111252972    143980416
client:remote-tab:[2016-05-15T09:08:57.914Z]: (1463303337914): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-05-15T09:09:00.663Z]: (1463303340663): memmrk:    47810384    63432064
xdk:client:[2016-05-15T09:09:02.734Z]: (1463303342734): memmrk:    111839268    143980416
client:remote-tab:[2016-05-15T09:09:03.161Z]: (1463303343161): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:09:03.161Z]: (1463303343161): emulator is shown for the project
client:emulator:[2016-05-15T09:09:03.161Z]: (1463303343161): MOBILESAMPLING-V1
xdk:server:[2016-05-15T09:09:05.666Z]: (1463303345666): memmrk:    47990716    63432064
xdk:client:[2016-05-15T09:09:07.737Z]: (1463303347737): memmrk:    112541288    143980416
xdk:server:[2016-05-15T09:09:10.668Z]: (1463303350668): memmrk:    46335776    63432064
xdk:client:[2016-05-15T09:09:12.740Z]: (1463303352740): memmrk:    112663076    143980416
xdk:server:[2016-05-15T09:09:15.671Z]: (1463303355671): memmrk:    46345308    63432064
xdk:client:[2016-05-15T09:09:17.742Z]: (1463303357742): memmrk:    112844896    143980416
xdk:server:[2016-05-15T09:09:20.672Z]: (1463303360672): memmrk:    46353092    63432064
xdk:client:[2016-05-15T09:09:22.744Z]: (1463303362744): memmrk:    112966668    143980416
client:remote-tab:[2016-05-15T09:09:25.276Z]: (1463303365276): About to start needsDebugModule in addTabWatcher
xdk:server:[2016-05-15T09:09:25.673Z]: (1463303365673): memmrk:    46155612    60286336
xdk:client:[2016-05-15T09:09:27.747Z]: (1463303367747): memmrk:    114457892    143980416
xdk:server:[2016-05-15T09:09:30.673Z]: (1463303370673): memmrk:    46163240    60286336
xdk:client:[2016-05-15T09:09:32.755Z]: (1463303372755): memmrk:    116432768    144983936
xdk:server:[2016-05-15T09:09:35.675Z]: (1463303375675): memmrk:    45984132    60286336
xdk:client:[2016-05-15T09:09:37.755Z]: (1463303377755): memmrk:    112292136    145999616
xdk:server:[2016-05-15T09:09:40.675Z]: (1463303380675): memmrk:    45993688    60286336
client:remote-tab:[2016-05-15T09:09:41.426Z]: (1463303381426): About to start needsDebugModule in addTabWatcher
client:emulator:[2016-05-15T09:09:41.426Z]: (1463303381426): emulator is shown for the project
client:emulator:[2016-05-15T09:09:41.426Z]: (1463303381426): MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:09:41.434Z]: (1463303381434): appmobi_plus_cordova :: Emulator restarting MOBILESAMPLING-V1
client:emulator:[2016-05-15T09:09:41.442Z]: (1463303381442): appmobi_plus_cordova :: _xdkLoad for project MOBILESAMPLING-V1
xdk:client:[2016-05-15T09:09:42.758Z]: (1463303382758): memmrk:    115007684    145999616
client:emulator:[2016-05-15T09:09:45.022Z]: (1463303385022): appmobi_plus_cordova :: Initialization Finished (Make it so.)
server:emulator-webserver:[2016-05-15T09:09:45.042Z]: (1463303385042): emulator-webserver: got a request for userapp.
server:emulator-webserver:[2016-05-15T09:09:45.042Z]: (1463303385042): req.path = /http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
server:emulator-webserver:[2016-05-15T09:09:45.042Z]: (1463303385042): Main html fullPath = /C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html
client:emulator:[2016-05-15T09:09:45.030Z]: (1463303385030): appmobi_plus_cordova :: frame appended to document
Node Webkit Error log:
[27772:0515/104632:INFO:CONSOLE(17)] ""xdk:client:[2016-05-15T08:46:32.257Z]: (1463301992257): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/104925:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (212)
[27772:0515/104925:INFO:CONSOLE(17)] ""client:build-tab:[2016-05-15T08:49:25.961Z]: (1463302165961): [refreshPage] Unable to generate project hash." {"message_":"no project selected","code_":null,"componentName_":null,"stack_":"Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n    at C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\main.js:17:1734\n    at _fulfilled (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:834:54)\n    at self.promiseDispatch.done (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:863:30)\n    at Promise.promise.promiseDispatch (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:796:13)"}", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/104928:INFO:CONSOLE(17)] ""client:build-tab:[2016-05-15T08:49:28.458Z]: (1463302168458): [refreshPage] Unable to generate project hash." {"message_":"no project selected","code_":null,"componentName_":null,"stack_":"Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at makeError (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at file:///C:/Users/ASUS/AppData/Local/Intel/XDK/xdk/components/client/build-tab/build-tab.js:17:2905\n    at Promise.apply (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1165:26)\n    at Promise.promise.promiseDispatch (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:788:41)\n    at C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:1391:14\n    at runSingle (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:137:13)\n    at flush (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\node_modules\\q\\q.js:125:13)"}", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/105012:INFO:CONSOLE(17)] ""builds:[2016-05-15T08:50:12.993Z]: (1463302212993): Error building UI for: certificateId"", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/105046:INFO:CONSOLE(17)] ""client:build-service:[2016-05-15T08:50:46.258Z]: (1463302246258): [getBuilds] fail" {"message_":"Http request timed out","code_":2,"componentName_":"core:http-request","stack_":"Error\n    at new ComponentError (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\public\\component-error.js:17:1122)\n    at XMLHttpRequest.\u003Canonymous\u003E (C:\\Users\\ASUS\\AppData\\Local\\Intel\\XDK\\xdk\\core-modules\\private\\service\\http-request-xhr.js:17:2420)","status":500,"statusText":"500","responseText":"No response body"}", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/105046:INFO:CONSOLE(17)] ""client:build-service:[2016-05-15T08:50:46.262Z]: (1463302246262): [startUpdateStatusProcess] fail" {"statusCode":500,"projectId":"wTGf4NBrtufMBbdLOKm9pzcy-MxVPEHVqaemzaIUEOg","data":null}", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/105046:INFO:CONSOLE(17)] ""client:build-tab:[2016-05-15T08:50:46.266Z]: (1463302246266): [onBuildProcessFinish] failed" 500", source: C:\Users\ASUS\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105115:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105806:INFO:CONSOLE(114)] "Uncaught TypeError: Cannot read property 'idUtilisateur' of null", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/index.html (114)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105902:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(3)] "Uncaught ReferenceError: jQuery is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js (3)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105914:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/105921:INFO:CONSOLE(146)] "Uncaught ReferenceError: $ is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html?2 (146)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110038:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110039:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(3)] "Uncaught ReferenceError: jQuery is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js (3)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110056:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110101:INFO:CONSOLE(146)] "Uncaught ReferenceError: $ is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html?2 (146)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110131:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(3)] "Uncaught ReferenceError: jQuery is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js (3)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110149:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110153:INFO:CONSOLE(146)] "Uncaught ReferenceError: $ is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html?2 (146)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110305:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.DirectoryEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Entry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.File already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileEntry already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileError already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileReader already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadOptions already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileUploadResult already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.FileWriter already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Flags already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.LocalFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.Metadata already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.ProgressEvent already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(3)] "Uncaught ReferenceError: jQuery is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/js/app.js (3)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.requestFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.isChrome already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.androidFileSystem already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystems-roots already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110322:INFO:CONSOLE(84)] "Uncaught module cordova-plugin-file.fileSystemPaths already defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/cordova.js (84)
[27772:0515/110326:INFO:CONSOLE(146)] "Uncaught ReferenceError: $ is not defined", source: http://127.0.0.1:58889/http-services/emulator-webserver/ripple/userapp/x/C/Users/ASUS/AppData/Local/XDK/xdk-scratchdir/0352fbdd-2773-4b97-9c68-430ae27561ca/platforms/android/assets/www/accueil.html?2 (146)
[27772:0515/110945:INFO:dispatcher_host.cc(151)] [NW.JS]RenderProcessCrashed
[27772:0515/110945:FATAL:render_process_host_impl.cc(479)] Check failed: !g_exited_main_message_loop.
XDK exit code & signal: 2147483651, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\ASUS\AppData\Local\Temp\bec49d49-e940-44fa-a7d5-93a3f6062844.dmp Sun May 15 2016 11:09:45 GMT+0200 (Paris, Madrid (heure d’été))
Size in bytes: 417896
NW Crash Detected.
PaulF_IntelCorp
