Software Archive
Read-only legacy content
17060 Discussions
Problem when installing flexlm* on Debian amd64 server
William_Jalby
I have a problem in installing flexlm* on a Linux Debian amd64 server.
I've download the tgz on intel website, but, when I run :
./Install_INTEL
I have the following message :
*** ./Install_INTEL, version 9.2 / : Install_INTEL,v 1.14.2.3 2005/02/03 16:50:24 sbhandar Exp $
*** Installation started on: mercredi 3 novembre 2010, 14:15:17 (UTC+0100)
*** System uname -a output: Linux palestrina 2.6.26-2-xen-amd64 #1 SMP Thu Aug 19 01:12:45 UTC 2010 x86_64 GNU/Linux
*** Error: installed software will not run; package might be for the wrong platform, or corrupted
*** Command: /opt/flexlm/lmutil > /dev/null 2>&1
Further information is available in the documentation:
END_USER_LICENSE - End User License Agreement
README, HowTo.html - general installation information
enduser.pdf - FLEXlm* End Users Manual
A detailed log of the installation process can be found in the file:
/opt/flexlm/Install_INTEL.log
An installation can be [re]started from this directory.
If you have any questions or encountered any problems during this installation,
please contact customer support at:
*Other brands and names are the property of their respective owners.
--------------------------------------------------------------------------------*** ./Install_INTEL, version 9.2 / : Install_INTEL,v 1.14.2.3 2005/02/03 16:50:24 sbhandar Exp $*** Installation started on: mercredi 3 novembre 2010, 14:15:17 (UTC+0100)*** System uname -a output: Linux palestrina 2.6.26-2-xen-amd64 #1 SMP Thu Aug 19 01:12:45 UTC 2010 x86_64 GNU/Linux*** Error: installed software will not run; package might be for the wrong platform, or corrupted*** Command: /opt/flexlm/lmutil > /dev/null 2>&1
Further information is available in the documentation: END_USER_LICENSE - End User License Agreement README, HowTo.html - general installation information enduser.pdf - FLEXlm* End Users Manualand from http://www.macrovision.com.
A detailed log of the installation process can be found in the file: /opt/flexlm/Install_INTEL.logAn installation can be [re]started from this directory.
If you have any questions or encountered any problems during this installation,please contact customer support at: http://support.intel.com/support/performancetools/support.htm
Do you have an idea ?
I can't install my Debian on a 32 bits machine.
And if possible, i prefer not to install a Redhat Linux.
Thanks for your help
Feilong_H_Intel
Hi William,
What's the version of your Debian? Also, please let me know which flexlm license manager you were using. Flexlm license manager for RHEL 3/4/5?
Feilong
William_Jalby
Thanks for your answer,
It's a Debian Lenny under a Xen virtualization system
(kernel2.6.26-2-xen-amd64)
I've downloaded this Flexlm* :
For IA-32 Architecture and Intel 64 (Intel EM64T) Architecture on RedHat* EL3, RedHat* EL4, EL5, SLES 9 and SLES 10flexlm.Linux.EL3.tar.gz
Thanks for your help,
Feilong_H_Intel
William,
Flexlm* License Manager doesn't support virtual machine officially, although one engineer in our team successfully made it running on an OS on top ofVMWare. I'd suggest you to try to install it on Debian Lenny in a real environment rather than a virual one. See if the license manager works.
Feilong
