Software Archive
Read-only legacy content
17060 Discussions
Problem with CreateProcess
grtoro
My Quickwin program makes repeated calls to another program (which runs minimized) using CreateProcess. I followed the "startp" sample in the samples directory. I have noticed the following sequence of events:
a) During the second and later calls, CreateProcess returns a .false. value, although the called program has executed properly. My program then calls GetLastError, which returns zero (i.e., ERROR_SUCCESS (great name!)).
b) The call to CloseHandle(pi%hThread) returns 0 (error) and a call to GetLast Error returns 6 (ERROR_INVALID_HANDLE).
c) The call to WaitForSingleObject(pi%hProcess, -1) returns -1 and and a call to GetLast Error also returns 6.
d) The call to CloseHandle(pi%hProcess) returns 0 (error) and a call to GetLast Error also returns 6.
In spite of this, the calling and called program seem to be working OK, although I suspect there may be a large memory leak (I have had to reboot once). I have checked all non_null arguments to CreateProcess and nothing changes between the first and later calls. In particular, dwCreate is 144, si is zero except for si%CB=68,
si%DWFLAGS=1, si%WSHOWWINDOW=6, and pi is all zeros.
Does anyone have any suggestion on how to correct this problem?
Gabriel
Jugoslav_Dujic
Valued Contributor II
Hmm, something is really fishy here. Could you post some relevant code please, especially CreateProcess part? (please enclose code in
HTML tags when posting so that it won't be screwed by Forum sogtware). Looks as if something is different in second call to CreateProcess but I cannot figure out why.
Jugoslav
grtoro
! for createProcess
integer res
character szArgs*512 ! new process arguments buffer & temp pointer
character DirName*512 ! current DirName for new process
character szPgmName*(MAX_PATH) ! name of the program
logical(4) fSuccess ! API return code
type(T_STARTUPINFO) si ! used for CreateProcess
type(T_PROCESS_INFORMATION) pi ! used for CreateProcess
logical(4) bMoreParams ! flag end of new process parameter processing
logical(4) bWait ! wait/no wait for new process to end
integer dwResult ! API return code
integer dwCreate ! new process creation flags
integer bExtension ! input filename have an explicit extension?
integer SIZEOFSTARTUPINFO
integer SIZESECURITYATTRIBUTES
! integer i
character*5 aExt(4)
type(T_SECURITY_ATTRIBUTES) sa, sb
data DirName /'0'/
! run gs using create process
dwCreate = CREATE_NEW_CONSOLE
dwCreate = IOR(HIGH_PRIORITY_CLASS,dwCreate)!
SIZEOFSTARTUPINFO = 68
call ZeroMemory (LOC (si), SIZEOFSTARTUPINFO)
si%cb= SIZEOFSTARTUPINFO
!pi=T_PROCESS_INFORMATION(0,0,0,0) ! 4 integer*4 quantities
PI%hProcess =0
PI%hThread =0
PI%dwProcessId =0
PI%dwThreadId =0
!minimized
si%wShowWindow = SW_MINIMIZE
si%dwFlags = IOR(STARTF_USESHOWWINDOW, si%dwFlags)
!maximized
! si%wShowWindow = SW_SHOWMAXIMIZED
! si%dwFlags = IOR (STARTF_USESHOWWINDOW, si%dwFlags)
bWait=.true.
SIZESECURITYATTRIBUTES = 12
sa%nLength = SIZESECURITYATTRIBUTES
sa%lpSecurityDescriptor = NULL
sa%bInheritHandle = .true.
! IF ( .not. DlgInit( IDD_MAY_TAKE_TIME , dlg_modeless ) ) THEN
! WRITE (6,*) "Error: dialog not found: IDD_MAY_TAKE_TIME"
! ENDIF
! istat = DlgModeless( dlg_modeless )
fSuccess=.true.
!note: GS_CMD and GS_LIB are always read from the same file and do not change
fSuccess = CreateProcess( &
TRIM(GS_CMD)//CHAR(0), & ! image file name
TRIM(GS_LIB)//' @tree_tmp.gs'//CHAR(0), & ! command line (including program name)
NULL_security_attributes, & ! security for process
NULL_security_attributes, & ! security for main thread
.FALSE., & ! new process inherits handles?
dwCreate, & ! creation flags
NULL, & ! environment
null_character, & ! new current DirName
si, & ! STARTUPINFO structure
pi) ! PROCESSINFORMATION structure
if (fSuccess .EQV. .FALSE.) then
lasterror=GetLastError()
select case (lasterror) ! process common errors
case ( ERROR_SUCCESS ) ! great name!
continue
WRITE(6,*)'fsuccess was false but GetlastError returns 0'
case (ERROR_FILE_NOT_FOUND)
write (6,*) "Error: Ghostscript program not found"
!CALL DlgExit( dlg_modeless )
!CALL DlgUninit( dlg_modeless )
RETURN
case (ERROR_DIRECTORY)
write (6,*)("Error calling Ghostscript: bad starting directory")
RETURN
case (ERROR_PATH_NOT_F
grtoro
! for createProcess
integer res
! integer i
character*5 aExt(4)
data DirName /'0'/
PI%hProcess =0
PI%hThread =0
PI%dwProcessId =0
PI%dwThreadId =0
!minimized
!maximized
bWait=.true.
! ENDIF
fSuccess=.true.
continue
RETURN
RETURN
grtoro
continuation of code:
            case (ERROR_PATH_NOT_FOUND)
                write (6,*) "Error calling Ghostscript: bad path"
                RETURN
            case DEFAULT
                 write (6,50) lasterror
50               format ('Error  calling Ghostscript: GetLastError=',I5,' CreateProcess')
                RETURN
        end select
    end if
    !  close pipe handle - child's instance will be closed when terminates
    res= CloseHandle(pi%hThread)
    if (res.eq.0) then
      istat=GetLastError()
    endif
    if  (bWait .NEQV. .FALSE.) then !  wait /Wtime wait flag specified?
      !   object to wait for
      dwResult = WaitForSingleObject(pi%hProcess, -1) !  timeout time
      if (dwResult == -1) then
        write (6,150) GetLastError()
150     format ('Error handling Ghostscript exit:  GetLastError=',I5,' WaitForSingleObject')
      end if
    end if
    res= CloseHandle(pi%hProcess) !  close process handle or it won't die
    if (res.eq.0) then
    endif
Jugoslav_Dujic
I've pasted your code with minor changes (actually, I invoked cmd instead of GhostScript because I was lazy to investigate gs command line options and added an infinite loop instead of turning it into a subroutine) -- and it worked beautifully ;-). Btw, is it Win9x or NT/2000?
Jugoslav
grtoro
Jugoslav,
Thanks for your help. I am using W98 SE. Two things I want to add:
a) The Ghostscript program works fine every time, even when I get the (apparently spurious) error messages. I am mainly concerned with memory leaks that may be occuring.
b) After seemingly harmless changes to dirName and other variables from "startp" that appear to be unused, I am finding that the errors occur only occasionaly (not consistently) after the first time.
This is probably a problem my program can live with, but I would like to resolve it, especially because of the possibility of memory leaks.
Thanks again,
Gabriel
