Software Archive
Read-only legacy content
17060 Discussions
Problem with Scatter/Gather operations
shiva_rama_krishna_b
Hi, i am vectorizing some code using the MIC intrinsics. But i am getting segmentation fault on MIC (offload error: process on the device 0 was terminated by signal 11 (SIGSEGV) ). Some one please tell me where am i doing mistake. It seems like a simple error. but i am stuck here.
Normal code:
for(curIdx = 0; curIdx < index; curIdx++)
          outreal[cidxarray[curIdx]] += inrealvalue*valuearray[curIdx];
Vectorized code:
int remain = index %16;
int indexSize = index-remain;
v1 = _mm512_set1_ps(inrealvalue);
for(int curIdx = 0; curIdx < indexSize; curIdx = curIdx+16)
      v1i = _mm512_load_epi32(cidxarray+curIdx);
      v2 = _mm512_load_ps((void*)(valuearray+curIdx));
      v3 = _mm512_mul_ps(v1,v2);                                                   // doing inrealvalue*valuearray[curIdx];
      v4 = _mm512_i32gather_ps(v1i,(void*)outreal,sizeof(float));      // access values from outreal and store in v4;
      v5 = _mm512_add_ps(v3,v4);                                             // doing outreal[cidxarray[curIdx]] += inrealvalue*valuearray[curIdx] and stores in v5
      _mm512_i32scatter_ps((void*)outreal,v1i,v5,sizeof(float));     // storing it back into outreal array
    for(curIdx = indexSize; curIdx < index; curIdx++)
sivaramakrishna
jimdempseyatthecove
Hard to tell. Insert some ASSERTs to assert that the arrays are cache line aligned.
If this doesn't expose something then insert some trace code to see at which point it fails (though this may alter the behavior).
Jim Dempsey
TimP
Are you saying you don't want to vectorize the C (e.g. with directives or CEAN)?  Doing so would give you something to compare against.
