Software Archive
Read-only legacy content
17060 Discussions
Problem with dbgl license
Mike_Beales
Not sure if this is the right forum to post this, I know very little about the products but have been asked to look into a license management problem we are having.
User is using the Intel Compiler studio products on his linux box. It seems that the Dbgl feature from the license server isn`t working for them. Would you be able to advise as to what might be going wrong.
The user is getting the following error
>>>>>> [jd12g09@uos-10450]~> which idbc
>>>>>>> /local/software/intel/composerxe-2011.4.191/bin/intel64/idbc
>>>>>>> [jd12g09@uos-10450]~> idbc
>>>>>>> Intel Debugger for applications running on Intel 64, Version 12.0,
>>>>>>> Build [74.923.2]
>>>>>>> Error: A license for DbgL could not be obtained (-1,359,2).
>>>>>>> Is your license file in the right location and readable?
>>>>>>> The location of your license file should be specified via
>>>>>>> the $INTEL_LICENSE_FILE environment variable.
>>>>>>> License file(s) used were (in this order):
>>>>>>> 1. Trusted Storage
>>>>>>> ** 2. /local/software/intel/composerxe-2011.4.191/licenses
>>>>>>> ** 3. /opt/intel/licenses
>>>>>>> ** 4. /home/jd12g09/intel/licenses
>>>>>>> ** 5. /Users/Shared/Library/Application Support/Intel/Licenses
>>>>>>> ** 6. /local/software/intel/composerxe-2011.4.191/bin/intel64/*.lic
From the license server log files I can see the following error. The user is picking up a license but then immediately handing it back.
>>>>>> 11:22:28 (INTEL) OUT: "IB87C5F90" jd12g09@uos-10450
>>>>>> 11:22:28 (INTEL) OUT: "DbgL" jd12g09@uos-10450
>>>>>> 11:22:38 (INTEL) IN: "IB87C5F90" jd12g09@uos-10450
>>>>>> 11:22:38 (INTEL) IN: "DbgL" jd12g09@uos-10450
>>>>>> 11:23:19 (INTEL) OUT: "IB87C5F90" jd12g09@uos-10450
>>>>>> 11:23:19 (INTEL) OUT: "DbgL" jd12g09@uos-10450
>>>>>> 11:23:21 (INTEL) IN: "IB87C5F90" jd12g09@uos-10450
>>>>>> 11:23:21 (INTEL) IN: "DbgL" jd12g09@uos-10450
We`ve tried the software on some other machines and it seems to be working correctly.
Many Thanks
Mike Beales
Software Services
University of Southampton
