Software Archive
Read-only legacy content
17060 Discussions
Problem with reducers and array notation (__sec_reduce_min)
leifblaese
I tried to create an example finding the minimum of values in an array using the __sec_reduce_min()-reducer. However, i got various error messages that i believe point out some bugs. I used the latest version of the cilk-branch (downloaded today, 21:00 EST) only with the flags -lcilkrts and -fcilkplus. I am running a Fedora 16 x86-64.
[cpp]using namespace std;
int main(int argc, char** argv) {
        double* A = new double[5];
        for (int i = 0; i < 5; i++) A = i;
        __sec_reduce_min(A[0:5]);
        return 0;
}[/cpp]
This code produces the following error:
test.cpp: In function ‘int main(int, char**)’:
test.cpp:18:1: internal compiler error: in gimplify_var_or_parm_decl, at gimplify.c:2055
test.cpp: In function ‘int main(int, char**)’:test.cpp:18:1: internal compiler error: in gimplify_var_or_parm_decl, at gimplify.c:2055 } ^
If you change the line with the reducer to
[cpp]double myvar = __sec_reduce_min(A[0:5]);[/cpp]
The error message becomes:
test.cpp:15:1: internal compiler error: in get_expr_operands, at tree-ssa-operands.c:1001
I actually got a third error message in another function. I was trying to build a k-means implementation. Unfortunately, i can't reproduce the error; i used an older version of cilk to compile; now, when i use the latest version, it produces the second error message i wrote. I assume, that the third bug is already fixed. If i find it, i will post it.
Balaji_I_Intel
Hello Leif,
    I have reproduced the problem. I will get back to you as soon as I fix it.
Balaji V. Iyer.
TimP
  1.         double* A = new double[5];
  2.         for (int i = 0; i < 5; i++) A = i;
  3.         __sec_reduce_min(A[0:5]);
Sorry, I still find the notation difficult to remember, particularly with plain C99 or C++ next to CEAN.  In the notations of other languages, you would exceed the array bounds in this reduction.  Of course, in CEAN this means 5 elements, ending with A[4].
Balaji_I_Intel
Hello Tim,
    I am sorry, but I do not understand how we will exceed array bounds..
A[0:5] implies we start at A[0] and access 5 elements starting at A[0], so in essence, we are trying to find the min of A[0], A[1], A[2], A[3] and A[4].
Balaji V. Iyer.
Balaji_I_Intel
Hello Leif,
   I have fixed the problem and checked in a patch to Cilk Plus gcc. Please let me know if you have further issues.
Balaji V. Iyer.
