Software Archive
Read-only legacy content
17060 Discussions
Problema com $.ajax em APP com jQuery
Hamilton_Tenório_da_
Valued Contributor I
Eu tenho 3 APPs similares, todos com acesso a web service (uso $.post para os acessos). Nos 3 uso apenas o XDK, Cordova e Appframework.
Um em um dos APPs  preciso do jQuery para um campo com Drag & Drop (não consegui achar um jeito de fazer esta função sem o jQuery).
Quando eu compilo este APP com o padrão antigo (Legacy), tudo funciona. Já quando eu compilo pelo padrão Cordova, a função $.post acaba sendo tratada pelo jQuery, ocasionando erro (isso apenas no tablet, no emulador funciona corretamente).
Como faço para indicar para que o $.post seja o do appframework e não do jquery?
Ou, se tiver um jeito de trabalhar com Drag & Drop no appframework, melhor ainda, pois neste caso eu retiro o jQuery do APP.
Obrigado.
PaulF_IntelCorp
Your question, posted so I can read it in English:
I have 3 similar PPAs , all with access to web service ( use $ .post for access ) . In 3 use only the XDK , Cordova and Appframework .
One on one of the must jQuery PPAs for a field with Drag & Drop ( could not find a way to make this function without jQuery ) .
When I compile this APP with the old standard ( Legacy ) , everything works . But when I compile the Cordova default, the $ .post function ends up being handled by jQuery , causing error (this only on the tablet, the emulator works properly ) .
How do I indicate that the $ .post is the appframework and not the jquery?
Or , if you have a way of working with Drag & Drop in appframework even better, because in this case I take APP jQuery.
Thank U.
There were some issues around AJAX calls and App Framework. This might require that you update the App Framework files in your project. You can find the most recent builds for App Framework here: https://github.com/01org/appframework/tree/master/build -- just replace the files that App Designer created in your project with these, App Designer will not overwrite your updated files.
