Software Archive
Read-only legacy content
17060 Discussions
Problems compiling with MicroAV Renderer
postaquestion
Hello. I've tried to compile the UPnP Win32_MmrRslMp Micro AV Renderer with the Microsoft Visual Studio 2005 Ccompiler, and I get these errors (in French, because... I am French !) :
Gnration de code en cours...
Compilation en cours...
mediaplayer1.cpp
MicroMediaRendererApp.cpp
MicroMediaRendererDlg.cpp
c:program filesmicrosoft visual studio
8vcplatformsdkincludewinsock2.h(3791) : error C2371: 'fd_set' :
redfinition ; types de base diffrents
8vcplatformsdkincludewinsock2.h(115) : voir la dclaration de
'fd_set'
stdafx.cpp
MediaPlayerVersions_Methods.cpp
c:intel authoring tools for upnpstacks and applicationsmicro av
renderer\_devicebuilderwin32_winsock2ilibparsers.h(138) : error C2061:
erreur de syntaxe : identificateur 'fd_set'
renderer\_devicebuilderwin32_winsock2ilibparsers.h(139) : error C2061:
I tried many ways, I searched during many hours on the web why fd_set from winsock2.h causes such a problem, but I failed ;-)
Can you help me ?
Intel_Software_Netw1
If you look at PlaylistManagerS.c
Youll notice near the top, youll find the line:
// PDA: Somehow this got broke would no longer build, commenting it out fixed the issue.
If you uncomment the block below it, it will fix the problem. Most likely this code comment was a referencing an issue on thelocal machine.
Theinstaller will be updatedto correct this in future versions. (You can uncomment this block in the ComponentsPlaylistTrackManager folder of where you installed the DHDCW tool, and it will generate the code correctly if you need to regenerate code, untilthe installer is updated.
Gina B.
Intel Software Network Support
http://www.intel.com/software
email: [email protected]
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
